Serpent 720
Old 09-07-2006 | 05:26 AM
  #1366
serpentpro28's Avatar
I will go with the novarossi 12-3 CT,This what im runnin' on my 720
and it's a BLAST.
serpentpro28 is offline
Old 09-07-2006 | 05:37 AM
  #1367
M7H's Avatar
M7H
Offcourse you will tell people to go for the Novarossi, because you are running it yourself......
M7H is offline
Old 09-07-2006 | 06:56 AM
  #1368
rcpanama's Avatar
Default Novarossi Plus
This is a comparison of the Novarossi plus 12 3CT with another engine Uriah Murnan did in 3hobby, is not DSII but it give you a very good idea of what the Novarossi is compare to other engines.
RCPANAMA
"Hi. Between the 2 engines (STI) and (+3). Both are great engines, but very different. The STI will produce most of it's power higher in the RPM range between say 30-40 K. The +3 will produce it's max power somewhere around 20-35 K. My team and I have used both engines with success, and the preference between the 2 engines lies with the driver. If you want instant torque that can require a smooth throttle finger the +3 is for you. If you prefer to grip it and rip it the Sirio may help smooth out the throttle responce, due to the fact that the STI comes on smoother than the +3. Both are fuel hungry. The STI will be happier to rev higher than the +3. If you are racing on a short track, the +3 is perfect (If traction is high enough to lay down the power.) The STI will be happier revving on a very large track. Not to say the Sirio is no good for a small track, or the +3 no good on a large track. They are just 2 very different engines that produce very different powerbands. I have found that the Novarossi 2630 Exhaust works extremely well with both engines. I will have both of these engines at my disposal for a given race. I have not had any of the modified STI crankshafts break, I am using the IFMAR crankshaft. Hope this helps."
rcpanama is offline
Old 09-07-2006 | 08:52 AM
  #1369
Team Kamikaze's Avatar
Originally Posted by buboy28
i'm already thinking about it but that Nova plus-3CT is also very tempting got to work overtime to pay for that shipping cost
Do you live in the Philippines? if you are....... why not buy it there? I know that you guys have a distributor of Nova Rossi in the P.I.
Team Kamikaze is offline
Old 09-07-2006 | 02:52 PM
  #1370
rcracerdude's Avatar
Originally Posted by Team Kamikaze
Do you leave in the Philippines? if you are....... why not buy it there? I know that you guys have a distributor of Nova Rossi in the P.I.
hindi sya aalis ng pilipinas, pero malamang dun sya nakatira... j/k
rcracerdude is offline
Old 09-08-2006 | 03:27 AM
  #1371
buboy28's Avatar
yup, we do have a distributor here of Nova rossi in the Philippines ; Dogbone Hobbies already talked to them but there is no stock of the modified plus 3CT
buboy28 is offline
Old 09-08-2006 | 03:30 AM
  #1372
You don't need a modified one, bone stock are already fast or get the Plus 12-5CT
Old 09-08-2006 | 07:36 AM
  #1373
korevo's Avatar
Exclamation
Try the plus 12-5ct, I got one and I have the Jp modified for plus 12-3 and a stock Plus 12-3ct ,it has a solid power band
korevo is offline
Old 09-08-2006 | 07:57 PM
  #1374
buboy28's Avatar
OK THANKS WILL TRY THE PLUS 12-5CT
buboy28 is offline
Old 09-08-2006 | 07:59 PM
  #1375
buboy28's Avatar
THANKS, ALREADY TALKED TO RICKY WILL TRY THE PLUS 12-5CT ITS HIGHLY RECCOMENDED
buboy28 is offline
Old 09-08-2006 | 08:13 PM
  #1376
Bro mas malapit ang Hongkong try mo sa r/cmushroom
Old 09-09-2006 | 05:06 PM
  #1377
buboy28's Avatar
subukan ko rin i try although patay na naman ako sa custom and duties na taxes
buboy28 is offline
Old 09-09-2006 | 09:22 PM
  #1378
korevo's Avatar
Exclamation
Bro,
Remember to use 2630 tuned pipe for plus engines perfect match!
korevo is offline
Old 09-09-2006 | 11:07 PM
  #1379
Pre, Support your LHS
Old 09-10-2006 | 11:25 AM
  #1380
Wolverines71's Avatar
I am looking at buying a 720, I am just wondering where everyone buys their tires from?
Wolverines71 is offline
