Old 08-28-2007, 05:32 PM   #2851
Sow&Steady's Avatar
Originally Posted by dkracer View Post
hey guys, just got a 3rd one way instaled and was wondering if you can help me with a problem
wen i put the black plastic pulley onto the 3rd one way, there seems to have quite abit of side play (1mm-1.5mm). is this normal???
thanks
and sorry for bad english
There is a bevelled washer (looks like a cone, black) that needs to go on the shaft between the brake disk and the bearing on the right rear bulkhead. Did you put this in?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-29-2007, 09:20 AM   #2852
typer's Avatar
Can someone explain why is it some guys install fuel filter as pressure chamber for the fuel tank? Is it to maintain constant pressure? Or is it to maintain pressure at long fast sweepers? Just wondering...
typer is offline   Reply With Quote
Old 08-29-2007, 09:26 AM   #2853
typer's Avatar
Julius, what steering blocks do you recommend here at jp racetracks in manila? 0 or 1 mm offset?
Old 08-29-2007, 10:43 AM   #2854
hey, i dont mean that, let me try again
first, i put the pulley (Black, where the belt goes around) on the 3rd one way adaptor (silver), then i put the clip on to secure the pulley.
but after i secure the pulley, the pulley doesnt seem secure, it can move side ways, about 1mm-1.5mm.
just wondered if anyone has the same experience
thanks in advance
dkracer is offline   Reply With Quote
Old 08-29-2007, 12:05 PM   #2855
Derby Bros Racing's Avatar
thanks in advance
My bro's 3rd one way did the same and we put an oring. I'm not sure exactly what size (I got it from my old stash of parts) but it's enough to fill the gap for no play.
BTW, I don't think it's really needed and the unit works with the little play but we installed the oring anyway just to have it intact.
Derby Bros Racing is offline   Reply With Quote
Old 08-29-2007, 12:06 PM   #2856
The pressure chamber provides an extra room for consistent pressure from full to empty tank.
Old 08-29-2007, 03:20 PM   #2857
Sow&Steady's Avatar
thanks in advance
Ah OK. Nope, my pulley is locked solid with the clip on, no movement at all.
Old 08-29-2007, 03:25 PM   #2858
rmdhawaii's Avatar
Did Serpent ever come out with a conversion kit for the 720 '07??
If so, does anybody have the part number and street price? Is it still available?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-29-2007, 03:30 PM   #2859
thanks, i'll try find an o ring.
another question, how do u guys fill up shockers properly, i keep getting air in myn and my rebound are all different
thanks in advance
Old 08-29-2007, 03:32 PM   #2860
Sow&Steady's Avatar
Not aware of one being released.
Old 08-29-2007, 03:36 PM   #2861
Sow&Steady's Avatar
thanks in advance
Follow the instructions exactly and be patient. You have to screw in the cap slowly and allow for the oil to overflow and bleed. If the rebound isn't the same redo it but put more or less oil in prior to screwing in depending on whether you need more or less rebound.
Old 08-29-2007, 06:30 PM   #2862
quick question:
do pre-mounted holes in a 710 body fit the 720?
i am about to buy a custom airbrushed body off a 710, but not sure if the body mount holes will fit directly onto my 720
anyone know?
thanks.
implusepro is offline   Reply With Quote
Old 08-29-2007, 08:37 PM   #2863
Originally Posted by implusepro View Post
quick question:
anyone know?
thanks.
No it won't fit directly.
Old 08-30-2007, 01:00 AM   #2864
RevMaxx's Avatar
Send a message via MSN to RevMaxx
thanks in advance
when i bought my 3rd one way set back in april, the shop owner gave me a separate ring (thicker) and specifically told me to install the thicker one instead of the one that came with the set.
he must have known the slight gap with the 3rd-one way set coz he was ready with the thicker o-ring.
RevMaxx is offline   Reply With Quote
Old 08-30-2007, 02:55 AM   #2865
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
RevMaxx: that thicker ring you are mentioning, is that also a Serpent item if so what is the part number and what store did you got it from, thanks
buboy28 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
