Old 05-17-2008, 01:03 AM   #3616
BURATIS-SPP's Avatar
Default drag brake
hi guys,
I need you advice on drag braking. What are the advantages and disadvantages of drag braking? when do you know when you have enough drag brakes? what part of the track is most important to have it( sweeper)?where do you adjust it? Is it better to manipulate on your controller ( throttle and brake trim) or mix of both controller and manually on your car( silicone, springs, and collar)? I have a 3pk and it doesnt have the feature of drag braking, so i just use the abs feature, but I heard some pros and a main guys usually use drag brakes. I just want your input guys, ty ty
BURATIS-SPP is offline   Reply With Quote
Old 05-18-2008, 09:18 PM   #3617
dj apolaro's Avatar
Serpent TQ's both Sedan and 1/8 scale at the 2008 Region 4 Championships this past weekend at the Homestead RC Raceway in Miami Fl. Serpent also takes the Sedan A main win and 2nd place and records the fastest laps in 1/8 scale.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-19-2008, 01:00 AM   #3618
Sow&Steady's Avatar
DJ Apolaro
Well done to Team Serpent USA!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-19-2008, 06:32 AM   #3619
s10dude's Avatar
congrat's to Team Serpent USA .............great job!
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-19-2008, 01:18 PM   #3620
dj
I run a serpent 720 out @ homestead, and was wounding if you would post the setup that you used this weekend?
jlopez92 is offline   Reply With Quote
Old 05-19-2008, 01:25 PM   #3621
gearhead_22's Avatar
Send a message via AIM to gearhead_22
DJ Apolaro
glad to hear that, keep up the good work team serpent!
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 05-19-2008, 04:01 PM   #3622
dj apolaro's Avatar
Originally Posted by jlopez92 View Post
dj
Give me a couple of days and I will post it here for you.
DJ Apolaro
Old 05-19-2008, 04:38 PM   #3623
Congrats DJ, Gianni, Luke and Pete for the outstanding performance this past weekend at the Regionals.
Way to go guys!!
Paolo M is offline   Reply With Quote
Old 05-21-2008, 04:40 PM   #3624
Serpent720's Avatar
Default Cable Management
Just got my Xceed 7.4 LiPo battery and Regulator. Does anyone have any pics of where they mounted their regulator and wires?
Serpent720 is offline   Reply With Quote
Old 05-22-2008, 02:48 AM   #3625
Julius's Avatar
http://www.rctech.net/forum/showpost...postcount=3400
Julius
Julius is offline   Reply With Quote
Old 05-22-2008, 04:07 PM   #3626
gearhead13's Avatar
I run a gear diff on the rear and a ball diff on the front. The serpent manual says to use 30,000 diff oil. When I first put it together all I could find was 5,000 oil and I think its causing me handling problems
Q: I run on a smaller, tight track, should i go lighter or heavier with the diff oil?
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 05-22-2008, 08:36 PM   #3627
fly_wheel's Avatar
if u r runing rear diff with diff oil that's too light will cause u to have a lot of tail out spin (sudden over steer), i've tried running 20,000 diff oil on very low grip track but that's the lowest i'll go, 30,000 diff oil can fit into most of the track conditions, if u get high grip track (sugar treatment), u can even try 40,000...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 05-22-2008, 08:49 PM   #3628
dj apolaro's Avatar
Here is my Regional set-up for the Homestead track.
DJ Apolaro
Old 05-22-2008, 09:38 PM   #3629
gearhead13's Avatar
Thanks,
I do run on sugar treated asphalt, I didnt realize that would be considered high traction.
I havent had the chance to run anywhere else, I dont know any different.
I have 20, 30 and 40 thou serpent diff oils. I guess I will try the 30 thousand.
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
Old 05-22-2008, 10:00 PM   #3630
Q-B0R0 B0MBER's Avatar
DJ WHAT GEARING SHOULD I USE ON MY 720 FOR THE PORT CHARLLETTE TRACK IM RUNNIN THE NEW J L RED DOT IN MY 720 ? AND WHAT SHORE TIRES ARE GOOD FOR OUT THERE ? THXZ
Q-B0R0 B0MBER is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
