Tekno NT48 Thread >
Tekno NT48 Thread
Like Tree13Likes
Tekno NT48 Thread
Old 07-06-2015 | 04:07 PM
  #1171
offroad dude's Avatar
Where does those 3 steel shims go that comes with the M2C chassis kit?
offroad dude is offline
Old 07-06-2015 | 04:20 PM
  #1172
Never mind I know where they go... duh..
Old 07-06-2015 | 07:22 PM
  #1173
jose valadao's Avatar
Where does the sets screews that comes with the m2c chasis go to?
jose valadao is offline
Old 07-07-2015 | 01:52 PM
  #1174
Well i was able to run my truggy for the first time and the truck has a ton of steering. I was able to finish one qualification for a lost steering nut (under the hub twice with 2 different hub) and of course the center diff spur that i couldnt get since it wasnt available anywhere...
Big_one is offline
Old 07-07-2015 | 01:59 PM
  #1175
Huh?
Sounds like the nut, whichever you are referring to, was not properly tightened. Can you explain more?
RokleM is offline
Old 07-09-2015 | 08:21 AM
  #1176
The screw under the front hub that goes through the hub and then the spindle.
At 6'6'' 315 pounds i sure can tighten a screw
Big_one is offline
Old 07-09-2015 | 09:24 AM
  #1177
If I'm understanding the problem correctly, that screw passes thru the chub and attaches to the spindle. Is the hole on the spindle stripped?
qstorm777 is offline
Old 07-09-2015 | 10:58 AM
  #1178
Yes. First time i just swap the crew. Happen again. Change the hub and happened again... Had to put a dab of glue in the spindle and outside of the hub to make ut work...
Big_one is offline
Old 07-10-2015 | 11:59 AM
  #1179
shein95's Avatar
i'm going to walking the pits looking a these trucks this weekend. going to finish the season out with my sworkz but plan on making the switch over the winter. i've decided i can't stand the pillow ball setup and want something more durable and adjustable. hopefully tekno will have the frame issue sorted out before i get around to buying one.
shein95 is offline
Old 07-12-2015 | 05:31 AM
  #1180
HSV427's Avatar
Anyone
HSV427 is offline
Old 07-19-2015 | 11:45 PM
  #1181
Did you ever get an answer to this? I haven't had a chance to install mine yet, but from reading about the motor mount, it sounds like it screws into the motor mounts to help keep the motor mounts from sliding on the chassis. From that, I'm guessing 4 holes on the bottom part of the quick chg should accept the set screws. If you have an answer, please let us know where they go. Thanks.
Old 07-20-2015 | 05:02 PM
  #1182
any gossip on a nt48.3?
nitroal is offline
Old 07-20-2015 | 07:18 PM
  #1183
Lol...i hope not. I just got mine this year. Seriously, I'm curious about this too and what the upgrades would be.
Old 07-21-2015 | 12:34 PM
  #1184
well they have updated every vehicle in their line to .3 status in the last couple months so the nt48 has to be next. im actually waiting to see if they update the truggy. hoping to build one for next season
canelocsta is offline
Old 07-21-2015 | 03:31 PM
  #1185
XT8Truggy's Avatar
The first change they'll make will be the chassis. The rear engine mount option will be deleted like on the buggy.
XT8Truggy is offline
