Tekno NT48 Thread
#1141
Savagesam, did you add shims to the center diff between the bearings and cup and bearings and spur gear? I'm assumming that's where the shims need to be. I haven't had any issues yet, but just in case. Also, are you using Tekno or Xray internal diff gears? Thanks.
#1143
The biggest plus is running the X-ray cup gives you the tuning options of Spurs that fit straight on, 46,48,50 so you can gear up or down with out any issue
#1144
Ok here is some footage of the first few laps running the M2C chassis on my current truggy set up, I just changed the stock chassis out and installed the M2C chassis including the 3 piece motor mount and headed to the track. I really like the way the truggy feels very precise with the chassis change, some set up tuning to follow in the coming weeks.
| + YouTube Video | |
#1145
All Canadians that own a Tekno please join here... I'm just trying to get an idea of the number of Tekno owners.
https://www.facebook.com/groups/698636993613372/
#1147
I am currently running both rear braces. I am going to try running the long brace only. I need more tuning time on it. I am fighting a snappy loose problem. So far so good with the spur gears. 3 full race weekends with no issues on the V-2 spur gear.
#1148
I do not think it give you a problem with chassis flex.
AS far as the snapping loose problem, I would start playing with sway bars
and ride height.
this chassis will have different handling than the stock model
#1149
Thanks for the fix. I am running the V2 spur and it held up today with some pretty bad landings.Which weights are folks running with this set up? I must have missed it but does anyone know the weight difference from the stock chassis?
#1150
I got to run the M2C chassis over the weekend. I ran it with the Tekno centre diff and v1 spur gear. No issues with the spur gear at all. This chassis defiantly fixes any spur gear issues. Now I just have to fine tune my setup. Great job M2C.
#1151
Well had a good day out this past weekend with 3 TQ rounds of qualifying and a run away win in the main, having made very few changes to my set up with the M2C chassis fitted the truggy was on rails and you can see from the 15 lap consistance and fastest lap time that i really was able to drive the truggy smooth and fast with this set up.
I added 30 gram weights to the rear of the chassis in front of the rear diff case, was running 3 washers on the C hub and removed 2 and went to 1 washer on the C hub, went up 50 weight in shock oils front and rear, also went up a little in my front & centre diff set up also, shame i didnt get a chance to shot some video on the day.
#1152
Can someone answer this question,,,,,,
I'm running both rear center braces ,, if I take either the long or short one offand run just one brace ,,, can anyone tell me what each one would do and drive like .
I hope that question makes sense ,,, thanks
#1154
to put in?
Seems like the M2C chassis is gonna solve a lot of problems for people with the
spurs. Might be a better option.
#1155
No I don't have anything at the moment. I'm trying to figure out what route to take.
13Likes
