Tekno NT48 Thread
#1067
1st collet - Flywheel slipped off twice. Replaced it.
2nd collet - Appeared to be slipping. Dremel the slit to 1-1.5mm as recommended by Tekno and reinstalled. Still something going on - still sounds like it is slipping. Locked camshaft thru backplate. Couldn't turn flywheel by hand or by applying slight pressure with pliers. After this Sat, tried this again. Applied a lot of pressure with pliers on flywheel. It wouldn't budge. I don't see any signs of slippage. Anyway, replaced collet and flywheel. Again, dremeled the collet slit to 1-1.5mm. Will see what happens. This is my third collet. I have one more collet left (I already dremeled it). I wish I could just buy the collet by itself. Anyway, if this 3rd collet and 2nd flywheel doesn't work, I'm pretty much out of ideas.
the wrong taper on the collet.
And brass collets do wear out.
If it ever spins, then you can have the problems you are describing.
the losi uses a 10 degree tapered collet. it is 6 mm long (.236)
I am not sure what the tekno collet is but odds are that they used the same
collet set up as the flywheels are similar.
A collet should extend out of the tapered hole about 1.5 mm.
If it fits down flush to the back of the flywheel then it is not the correct collet.
next:
mugen uses a 7 degree tapered collet and is about 7 mm long.
These will not interchange.
All engine suppliers use the same basic length of crank shaft from
the end of the crank to the bearing about 29.5 mm (1.261)
this is what we who make aftermarket flywheels systems use as a
standard for our products.
So, you can basicially use about any clutch system out there, but make
sure you have all the correct components for that clutch.
as far as clutch bell go, most will interchange with the after market
flywheel kits to my knowledge.
A proper clutch set should be:
when everything is assembled the outer bearing should be at the end of
the crank shaft + or - about .1 mm.
If you are a bit shy you can use a 4.9 x 3.01 shims (ofna part no. 10210)
I think,on between the bearing and
the clutch bell. this will keep the bearing off the race of the bearing. and allow
the proper play clutch bell.
if you continue to have problems
pm me and I will try to help.
hope this helps
#1068
GUYS,
We have taken the feedback from our test drivers and we think we
have came up with a very durable model.
We have made some major changes to the original design.
We have cut the spur gear clearance thru the chassis. this allows us to
lower the cg of the center diff by 2mm.
We have also changed the motor area and deleted the rear motor shift
option.
We have also adopted a new quick change 3 pc. motor mount and
have deleted the option of using the stock motor mount.
We did this because of the conflict of the slots for the 2 different types
of motor mounts.
This style of motor mount offers a great deal of support and helps take out
the flex in this area.
We have also lowered the cg of the motor mount by 1.5 mm.
this should solve the problem of selection of bump boxes.
by doing these changes we believe that this will greatly help in solving
the broken spur gear problems.
let me know what you guys think of the new changes.
#1069
A problem that we have ran across with this problem is:
next:
hope this helps
next:
hope this helps
#1070
Which is what I prefer
they are also the most adjustable clutch system in in the world
might want to check them out
#1071
#1076
GUYS,
option.
of motor mounts.
#1078
it can sometimes enlarge the tapered hole in the flywheel and not fit
properly.
#1080
M2cracing : HUGE HOME RUN WITH THE PURPOSE BUILT SINGLE MOUNTED CHASSIS.
How do i get my hands on one, take my money, the team M2C has guided Mitch in the golden direction, i can see alot of these popping up everywhere ........
13Likes
