Tekno NT48 Thread >
Tekno NT48 Thread
Like Tree13Likes
Tekno NT48 Thread
Old 03-25-2015 | 01:26 PM
  #916
Originally Posted by BRIAN77
Has anyone mount a electronic on and off switch on this car , if so where did u mount it .
I did mine very similar to Xt8truggy. I thought about mounting it on the battery cover, but I felt like it be a pain taking the cover on and off. Plus I had the cable running down the back of the box and I didn't like that. However, RokleM seems to have his cable going in the gap between the receiver and battery box. I took the mounting plate off my switch and us parma double side tape to mount the switch. Its clear (red cover), very sticky, but comes off a lot better than those paper type double sided tape. I've used it on my esc's and never had a prob so i fig it would work and so far it has.
qstorm777 is offline
Old 03-25-2015 | 02:58 PM
  #917
XT8Truggy's Avatar
Originally Posted by RokleM
No offense, but I think electronic switches do not work well at the stock location. It is one option, but there are exposed cables, the mounting location is too small, etc. I did this instead, but you also have to be careful. I have screws that are short enough to get into the plastic and flush, but not into the box. Obviously having a pointy screw in a battery box would be a bad idea No solutions are ideal at this point and hopefully we will have some more mounting options in the future to support electronic switches vs mechanical. I've personally had enough mechanical switches fail that I no longer have any interest in using them.
No offence taken. But I think the sky rc switch is perfect in the stock location. It's easy to get to it screws in the stock switch holes. The exposed cables are cable tied and the cable tie goes through the cover. So the switch cable doesn't move. I've been running this setup for 6 months no issues.
XT8Truggy is offline
Old 03-25-2015 | 06:35 PM
  #918
CKmaxx's Avatar
Here's what I ended up with. Cut the switch to fit and siliconed it in place...
CKmaxx is offline
Old 03-26-2015 | 07:25 AM
  #919
Definitely unique! Let us know how it works out.
RokleM is offline
Old 03-26-2015 | 08:11 AM
  #920
Originally Posted by nmdesertracer
Yeah Ofna blue box. I actually just put a new starter wheel on thinking the old one was worn down. We got a Protek sbox from a friend and that one seems to work OK not the best though. On my sons AE rc8t the ofna box worked like a champ no probs.
Hmmm...I have the Ofna truggy blue starter box with a Picco motor. The flywheel is recessed a couple of mm inside the chassis and I'm able to hit it with no problems. I did have a problem getting the flywheel and starter wheel to line up. I was installing the brackets like the picture on the box. Now they are lined up like the picture on Ofna website and it works perfectly.
Old 03-26-2015 | 08:34 AM
  #921
Got thru my first ever truggy and first ever nitro race this weekend at ROCCK Racing in Knoxville, TN. It was an adventure. Practice session went great except for being able to find a spot on the drivers stand. Anyway, I started to get a feel for the truck and how to drive nitro.
On race day I missed the 1st heat. I couldn't hear the heats from my pit spot. By the time I got to the driver stand they were already racing. I need heat to start my motor and they didn't want you to fire them up around the track until the heat before you was done. However, I noticed others were fired up so I was going to fire it up early for the 2nd heat anyway. Btw, I then noticed that my gear box couplers on the front and rear had moved. I had to remove and loctite the grubb screws again. Probably a good thing I didn't run.
2nd heat, stood by track. After heat in front on me got on the track, I went back to my pit stop with intentions of firing up my car and waiting in the staging area with it running. Engine would not fire. Changed plug - nothing. Noticed flywheel was turning freely. I knew my motor wasn't that loose. Had to take motor off and tighten flywheel.
Finally got on the track for the 3rd heat. Once I got in rhythm this truck was a pleasure to drive. I can't push my sc and buggy that hard. Each lap I was just pushing the truck harder and harder and it performed granted I'm not much of a driver. I left the stand pumped up.
B-main, I finished 5th out of 10, but I wasn't expecting much this time. Watching the A-main drivers, I don't know if I wanted any part of that. They were fast.
I did notice if I broke before a corner and turned, this thing turned tighter then my buggy. However, if I was late with the brakes, I ended up with a very wide turn - probably from me on the gas too much in the turn...in a hurry.
Anyway, I can't wait for my next race. No broken parts and I feel like this is a truck I can learn to drive. I don't know about anyone else, but, for me, driving truggy is the best adrenaline rush out of all the cars.
Old 03-26-2015 | 10:10 AM
  #922
Make sure that your engine is coming down to a nice low idle when you get off the gas. If the clutches stay engaged it can cause the truck to push.
masher81 is offline
Old 03-26-2015 | 11:10 AM
  #923
FastPete's Avatar
Great story glad you like it. Im going to try truggy one day.
FastPete is offline
Old 03-26-2015 | 08:51 PM
  #924
Hi all, any updates on the new release for the revised spur gear? I recently went through 2 version 2 spur gears. I was unable to finish my main and fearful of jumping the truck.
I run the truck with all chassis braces and ran a pretty tight gear mesh. Thanks.
Tmachine is offline
Old 03-26-2015 | 09:15 PM
  #925
Danny posted that they were looking into revising it again.
mr240 is offline
Old 03-29-2015 | 12:04 PM
  #926
Mister-E's Avatar
Hi guys,
If using the stock flywheel, what other brand clutch bell fits?
I would like to use a 14T ventilated clutch bell on the truggy for our track.
I tried the X-Ray one (from my buggy), but it doesn't align with the spur gear.
Thanks in advance!
Mister-E is offline
Old 03-29-2015 | 02:56 PM
  #927
XT8Truggy's Avatar
Originally Posted by Mister-E
Hi guys,
Thanks in advance!
The serpent vented clutch bell will fit.
Old 04-04-2015 | 02:08 PM
  #928
rceefreak's Avatar
Ok So I ran my truggy for the first time today and the rear end is real loose. Cant get on power coming out of turns. If I do the rear end comes around. Setup advice please!! Believe my diffs are 10 10 5. What are some setups that will keep the rear end planted
rceefreak is offline
Old 04-04-2015 | 04:07 PM
  #929
Try 7 10 3 and also what tires are you running depends on the track of course loose dirt or pack bumpy or smooth ?
mavdriver is offline
Old 04-04-2015 | 04:10 PM
  #930
rceefreak's Avatar
loose dirt and on grass. Tires were I beams.
