Tekno NB48
#436
Found a video of the NB48 in action this weekend
Chad Panek and Mat Dubb are both in this race
| + YouTube Video | |
#439
You need to select a higher quality video if it's too blury for you. I didn't shoot the video, but it is very high quality and if your not able to see it there is no reason to say it sucks.
Maybe your connection is not very good. Click on the gear icon on the lower right hand side of the video player and you can select 720p HD if you want.
#444
i had a old losi starter box clone, used that to get the motor going, with a heat gun of course. Happy to say I have a great time today running the buggy, lots of steering and handles great. Many came around the pit table to have a look after the main. Did not place due to transponder issues but did not care, was having to much fun!
#445
Ran for the first time tonight at ohio rc factory, super tacky and high bite. The stock setup was way off for this traction. I can see the stock setup being amazing on outdoor loose blown out conditions. Made some few changes ie. stiffer rear oil, moved front and rear camber links a bit and limited droop. Car felt much better. There is going to be some more changes I'm going to make to suit my home track and driving style, such as use my trusty fioroni pistons (mostly because I'm used to them and can tune them in well), a stiffer front spring, mess with some oils and shock locations, take the 4 washers out of the steering stops and either run 2 or none. Need to drive it a few more times but the car is excellent and responds to changes very well (Tekno standard
...) pretty excited about getting her dialed in!!! Excellent job once again!!
#448
We are working with our manufacturers on a solution, but it might be a couple weeks before we figure out the exact cause. My thoughts are that they cut the internal fuel line a little short and it is able to move off of the nipple. We'll post more info as it becomes available. Thanks.
#450
12Likes
