Tekno NB48
#421
I'm not sure who has them or if any were taken. I know we have pics. We swept eBuggy, 1 & 2 in SC 4x4, 1 & 2 in nitro truggy, TQ'd open nitro buggy, and qualified 4th in the expert buggy main. Had engine issues in the buggy mains, but the buggies were awesome all day.
#422
All good. Drew a bit of a crowd actually as a lot of the nitro crowd was out. Beautiful day down here. Box setup may be a little loose for our track, but it could also be the awesome O.S. motor. I'm still learning.
One problem I had was the fuel uptake line and filter came off the nipple in the tank. I flat landed a big single a couple of times, and caught the pipe more than once, but no major wrecks. I managed to get some needle nose pliers in there and it went back on very easily... not a lot of bite if you know what I mean. It may have been loose to begin with. Don't know what to think of this yet. It didn't happen again.
#423
One thing we did this weekend was to go to 3.0 degrees of toe and move the hubs all the way forward. This helped a lot. Then we tried swapping the sway bars so that the front was 2.6mm and the rear was 2.5mm. You could even go higher on the front to further smooth out the car. Our cars have a ton of steering and it is sometimes necessary to limit it.
The other major thing we did, and it's different for everyone, was limit our dual rate / steering travel on the radio so the wheels don't turn as far. Alternatively, you could add another washer or two to the steering stops. Now that I have the steering travel where I want it, I will probably set it solely with the steering stops (not limited on the radio).
#424
Thanks for the feedback. The fuel line coming loose from the nipple in the tank is interesting. We haven't experienced that yet but I could see how it could happen if it was loose from the factory. Hopefully it stays put.
#425
Yes. We've run rear position on a number of occasions but always seem to come back to forward position. The car was designed to have the forward position be the stock position.
We will probably spend some time to get a rear motor setup, but we feel the forward motor will yield better results in almost every condition.
#426
After letting several drivers drive the Tekno Buggy today I can tell you the setup on this car seemed to be good for everybody driven it. Here is the links for three of the people driven the car.
https://www.youtube.com/watch?v=EooO...e_gdata_player
https://www.youtube.com/watch?v=OIju...e_gdata_player
https://www.youtube.com/watch?v=pefh...e_gdata_player
#428
Handled it well!
#430
#431
#433
Found a video of the NB48 in action this weekend
Chad Panek and Mat Dubb are both in this race
| + YouTube Video | |
#435
| + YouTube Video | |
12Likes
