Like Tree12Likes
Tekno NB48
Old 12-25-2013 | 09:25 AM
  #466
FastPete's Avatar
Merry Christmas NB48 fans how about some pics?
FastPete is offline
Old 12-25-2013 | 10:19 AM
  #467
Default Setup Tips
Originally Posted by Gwoodrc
I am running 5/5/3 in both the nitro and e-car.
Gwoodrc, sounds like your diffs are too light. You said your track was blue groove and hard pack but didn't say if it is medium to high bite. If it is then try 7-7-5 only use 5-5-3 on loose low bite tracks.
Also please take a look at the latest setup on our site. We recently made two huge discoveries with the NB. We went to a heaver front sway bar, reduced rear tow and moved the rear hubs forward. This made the rear end extremely planted and removed all "edgyness".
The EB and NB are very similar but the weight and balance are much different. They will tune very similarly but the setups will not be exactly the same.
MattDub is offline
Old 12-25-2013 | 12:42 PM
  #468
Thanks for the suggestions, I tried tooling at the set ups online but they keep coming up as blanks (maybe cause I'm on an iPhone, need to try on a PC). I run 5/5/3 on my e-car so I built the NB that way also, I started with 7/7/5 on the e-car and dropped to the lighter cause I like the way it rotated better off throttle with the lighter diffs. I did notice that I was having excessive wheel spin with the light diffs and that was the next thing I was gonna try this week end. I went to 35f/30r in the shocks and then stood them up a hole and the car felt a lot better also.
Gwoodrc is offline
Old 12-25-2013 | 01:03 PM
  #469
Here's a couple pics of my NB48 and one with my EB.
Gwoodrc is offline
Old 12-26-2013 | 01:02 PM
  #470
try 8/7/6 in diffs
PUDDIN is offline
Old 12-26-2013 | 01:06 PM
  #471
Originally Posted by PUDDIN
try 8/7/6 in diffs
Yea I finally got the setup off the website so I'm gonna go to the track tomorrow and try it that way. The set up I have now is good, just have to be careful getting back into the throttle out of the turn. When I started with kit set up it was good but just felt like it didn't carry much corner speed in the turn so I had to free the car up to get it to maintain speed through the corner.
Gwoodrc is offline
Old 12-26-2013 | 01:09 PM
  #472
also try a stiffer sway bar in the front that will help with twitch and edgyness
PUDDIN is offline
Old 12-26-2013 | 01:16 PM
  #473
I'll try it but scared to loose any steering.
Gwoodrc is offline
Old 12-26-2013 | 04:10 PM
  #474
if you get in the throttle a little earlier with that diff setup you will bring the car around and should not lose steering.
PUDDIN is offline
Old 12-26-2013 | 07:01 PM
  #475
FastPete's Avatar
Very nice
FastPete is offline
Old 12-27-2013 | 08:11 AM
  #476
jonw's Avatar
Who else besides you and Brian on the Tekno team in Texas this year?
jonw is offline
Old 12-27-2013 | 08:13 AM
  #477
jonw's Avatar
So who else besides you and Brain are on the Tekno team in Texas?
jonw is offline
Old 12-28-2013 | 11:00 AM
  #478
as of right now I am on my own Dime Jon.
PUDDIN is offline
Old 12-28-2013 | 08:24 PM
  #479
Hoese37's Avatar
What style battery does the buggy use? Hump or flat?
Hoese37 is offline
Old 12-28-2013 | 08:28 PM
  #480
http://www.venom-group.com/10C-2S-12...v-LiPO-RX.html
PUDDIN is offline
