Like Tree12Likes
Tekno NB48
Old 08-13-2014 | 09:37 PM
  #1966
Graham11's Avatar
Originally Posted by 8thwonder
Just finished building my NB48 today... Car is very solid feeling, installed the FX 5k in it and will break in tomorrow,now just gotta wait for my 0801 pipe to come ha-ha I'll be using my 2035 till then....
Great! You will love it, I also run the FX but with 704 medium header and 2100 pipe and .25-.5 head shimming, really smooths out the bottom, great for buggy, overall that engine setup took seconds off my lap times.
Graham11 is offline
Old 08-13-2014 | 09:49 PM
  #1967
DBL15's Avatar
to the guys running rear motor have you tried the forward motor ?
did you have another body or just cut a larger hole where motor sits ?
i would like to try rear but i dont suffer at all with rear traction and i love my steering but its getting the better of me to try rear motor but dont really want a huge gap around the front of the motor by cutting the shell so much
DBL15 is offline
Old 08-13-2014 | 11:31 PM
  #1968
cannonballs's Avatar
Originally Posted by Graham11
Hey buddy, please email [email protected] and Zac will take care of you, you'll have it in a couple days! If you are near philly I can give you one too.
thanks for the info.. email sent. Yeah I know they will Tekno's CS is bar non the best.
cannonballs is offline
Old 08-14-2014 | 03:13 AM
  #1969
Casketman's Avatar
I like the rear engine position. Although since I got my setup the way I have it now,I haven't tried it with the engine forward yet but I have been meaning to. At the time,I didn't have any setup on the car that was working to moving the engine was one of those things so I can't honestly say how much steering I might of lost. It still seems to turn great although I feel I have lost some of it,it's not enough to hurt me. But I needed rear traction.
Yes you can cut a larger hole or have a second body. I would prefer a second body. The hole I had to make was just to large to me so after this season ends in Oct. I plan to send two bodies to my painter so I don't have to deal with the large hole.
Casketman is offline
Old 08-14-2014 | 04:26 AM
  #1970
that pipe is a lot in a buggy. I tried that combo for a few and didn't get the best out of it. it was great in my truggy since that what I have been running in it but its a lot for a buggy. 2100 is decent and a 2090 is awesome
Mo Denton is offline
Old 08-14-2014 | 04:28 AM
  #1971
throw that setup on it posted on the last page. forward motor.
Old 08-14-2014 | 07:23 AM
  #1972
madweazl's Avatar
Here is a PDF version of Mo's setup.
File Type: pdf
madweazl is offline
Old 08-14-2014 | 11:11 AM
  #1973
Bernard_Jr's Avatar
I would just get a second body. I started with the kit setup and have since settled a rear motor setup that I really enjoy. I did have to put more steering back in after making the switch but it seems easier to drive fast now.
Bernard_Jr is offline
Old 08-14-2014 | 04:11 PM
  #1974
madweazl's Avatar
Kit arrived, time to start building. If things go well I may just run this at JBRL this weekend.
madweazl is offline
Old 08-14-2014 | 05:56 PM
  #1975
madweazl's Avatar
I love the brake setup! Hope it works as well as it was engineered.
madweazl is offline
Old 08-14-2014 | 07:53 PM
  #1976
DBL15's Avatar
brakes are very strong on this buggy and truggy to be honest
takes a bit to get how you want them but no problems after that even in 1 hour long mains no brake fade at all
DBL15 is offline
Old 08-14-2014 | 11:31 PM
  #1977
madweazl's Avatar
Length of the front turnbuckles for the kit setup sure doesnt make for an easy build; killed a ballcup in the process. Is there a shorter set of turnbuckles that would be a more appropriate fit up front? What is the length of the rod (minus ballcups) supposed to be?
madweazl is offline
Old 08-14-2014 | 11:50 PM
  #1978
JsK's Avatar
JsK
R/C Tech Elite Member
Yeah the factory's have to give you enough length to run all the possible locations and yet make them short enough also. The tekno ones can be a bit tight because of the extra length. Use a body ream to chamfer the rod ends before you screw in the turn buckle and use some Chapstick or other lube.
JsK is offline
Old 08-15-2014 | 06:44 AM
  #1979
madweazl's Avatar
Those are all things I do on every build, still a pain in the butt to thread an inch of rod in each cup. Hopefully I can find some ballcups locally (hoping Revelation has some).
On the plus side, the 17mm servo saver nut was brilliant!
madweazl is offline
Old 08-15-2014 | 08:12 AM
  #1980
I started out midmotor for the winter indoor season. I then went to rear motor when we went outside BUT with the setup i have now i ended up going back to midmotor. I think that midmotor is where its at with this car when you get the setup right. I have been on some really low traction tracks and still have more than enough grip.
masher81 is offline
