Tekno NB48
#1188
#1190
Another one radiotray suggestion: screws to secure top covers are way too short, inner ones doesn't grab enough plastic to lock firmly. Replaced all inner and batt.lid screws (5 total) to something like 10mm long and it holds much better.
#1196
#1197
You can use other clutches it just requires you to shim the flywheel about 3mm.
You will also need a deeper step washer like the OFNA or Kyosho ones.
Or you can use the aftermarket clutch and use the Tekno long bell.
#1199
I don't have rear traction issues so I only run the front mount on both buggy and truggy
#1200
Not a huge difference, but noticeable. Other than your body, it doesn't take that much to convert it so I strongly suggest giving it a try. You can use the same starter box for buggy and truggy, but you will probably have to remove the rear pegs.
12Likes
