Tekno NB48
#1173
I had a good setup going with the car in midmotor and liked it ALOT. Then just for shits and giggles i changed to rear motor .. but left everything else alone...god the car was horrible lol. Now i feel like the car is the best its ever been
#1175
Ready for it's first run at opening day at Family Hobbies, Vineland NJ. The longest running track in the US (opened in 1983). Body by Mels Shells
Attachment 1186218
Attachment 1186218
#1179
What kind of clutch bell bearings are folks using after the stock ones go bad? I'm only getting 1 race day out of a set of clutch bell bearings as I run on some very dusty tracks and would like to know if there are better alternatives out there. Thank you.
#1182
2 bucks a throw to change clutch bearings is not a bad price at all.
I have always changed them before a main. Then they stay in there through practice sessions,quals and then they get changed again before mains.
Its been Looong time since i lost a clutch bell bearing using this system. There is a lot of different variables that determine how long bearings last.
Shim it to tight and it will eat bearings. To loose and they go quick also. Heat kills em just as fast as a bad shim job so make sure you bed the shoes
in and dont let them mushroom out and hang up.
So to answer your question in a round about way I personally think how you
treat them is more important than any "special" bearings. You can kill a set of
TKOs just as fast as regular bearings if you don't treat them right.
As a word of caution the only bells I have ever seen "walk" off the end of the
crank and take out the fuel tank, spur and bell are the larger bearing ones. I
have never seen a 5x10 bell do that. So 2 dollars is cheap insurance.
Get the shimming down, and change them on a regular schedule and the
dollar ones will be fine.
#1183
Thanks for the feedback gents. I will start to employ the replace clutch bell bearings before each main technique. It sounds like my problem is that I have it shimmed slightly too tight, as when I go to replace the bearings the shields are popped off of 1 or both of the bearings.
#1184
Are you prepping them at all? Metal or rubber seals? Best bearing Ive found so far are the TKO.
#1185
Hey guys, I have found what I believe to be a really good starting setup for the NB48. I have tried the setup on extremely Loose / soft outdoor track and high bite indoor track. Simple droop and ride height adjustments seem to be key to fine tuning it to track conditions. I know that everyone drives different but for me this is the best the car has felt and i thought i would share.
http://michaelsasher.com/Michael_Ash...ring_Setup.pdf
12Likes
