Like Tree12Likes
Tekno NB48
Old 03-09-2015 | 08:46 AM
  #3181
Originally Posted by pballer2777
where a good starting point for the diffs on a rough med to loose track. box set up seems kinda high.
I like to go to 543 or 554 on slick rough tracks. 775 on high bite.
masher81 is offline
Old 03-09-2015 | 08:56 AM
  #3182
pballer2777's Avatar
i put in 553 to start and lets see what happens.
pballer2777 is offline
Old 03-09-2015 | 09:03 AM
  #3183
That is a good starting point for sure.
masher81 is offline
Old 03-11-2015 | 07:44 AM
  #3184
CnR's Avatar
CnR
What starter box works best with the NB48 ?
CnR is offline
Old 03-11-2015 | 08:00 AM
  #3185
Big Will's Avatar
OFNA blue (truggy) starter box. Don't worry about it ever. The thing is bullet proof.
Big Will is offline
Old 03-11-2015 | 10:06 AM
  #3186
Spyder Eye's Avatar
I have an issue, sometimes the fuel tube inside the tank can get out of position and end of the tube can face the front of the tank. It will then prematurely run our of fuel as the end is sitting higher than the fuel.
Has anyone experienced this and have a quick tip on how to keep the fuel line and filter from getting out of position?
Spyder Eye is offline
Old 03-11-2015 | 10:36 AM
  #3187
FastPete's Avatar
Sounds like the old first tank. The revised one wont do that.
FastPete is offline
Old 03-11-2015 | 10:37 AM
  #3188
FastPete's Avatar
+1 Love that one
FastPete is offline
Old 03-11-2015 | 10:38 AM
  #3189
masher81 is offline
Old 03-12-2015 | 08:34 AM
  #3190
I have received revised one but issue is not gone.
xtaiji is offline
Old 03-12-2015 | 11:51 AM
  #3191
Spyder Eye's Avatar
I agree because the tank I have is the revised one.
Old 03-12-2015 | 12:17 PM
  #3192
Change the fuel line and the problem will go away. I use the TLR fuel line
flap jack is offline
Old 03-12-2015 | 12:22 PM
  #3193
Spyder Eye's Avatar
That seems like a good idea, I feel like the stock line is smaller in diameter than the Dubro line I get a the local HS.
Old 03-12-2015 | 01:59 PM
  #3194
Retired09's Avatar
I have been using the new tank for sometime. I use the thick blue Kyosho fuel line, but know a lot of people that use DuBro.
Tank has been flawless since doing this.
Retired09 is offline
Old 03-12-2015 | 02:01 PM
  #3195
Harrison477's Avatar
Spyder, I was having a similar issue, even with the revised tank. I switched the stock fuel line to the Dubro line and my problem was solved
Harrison477 is offline
