Like Tree12Likes
Tekno NB48
Old 08-26-2014 | 10:30 AM
  #2131
Graham11's Avatar
Although the tank may be the issue, I think the problem could be with your throttle linkage. Are you sure the throttle is closing fully when you are idling/braking?
Graham11 is offline
Old 08-26-2014 | 11:02 AM
  #2132
Originally Posted by ThreatRacing
My FTW body came in this afternoon so I slapped on a quickie paint job.
Is that the v2 motor?
masin14 is offline
Old 08-26-2014 | 11:43 AM
  #2133
ThreatRacing's Avatar
No its the 21XZ-B
ThreatRacing is offline
Old 08-26-2014 | 03:36 PM
  #2134
Originally Posted by JsK
I know both people that helped Mason on sat and both are experienced tuners. And since he had exactly the same issue with both engines I doubt it's a tune problem. It's the tank lid Mason, pull the tank and do a pressure test.
I just did the pressure test and there were no bubbles coming out or water inside the tank.
masin14 is offline
Old 08-26-2014 | 03:38 PM
  #2135
I'm pretty sure it's ok I will check to make sure.
masin14 is offline
Old 08-26-2014 | 03:41 PM
  #2136
Cappy's Avatar
Masin Make sure you dont have any Fuel lines being pinched to restrict the flow of Fuel.
Cappy is offline
Old 08-26-2014 | 03:48 PM
  #2137
OK I will look at that too.
masin14 is offline
Old 08-26-2014 | 04:29 PM
  #2138
I had one last question, do I use the heavy or lighter clutch spring on carbon clutch shoes?
masin14 is offline
Old 08-26-2014 | 04:58 PM
  #2139
I use the Losi clutch and it's green on carbon and gold on aluminum
Mo Denton is offline
Old 08-26-2014 | 05:52 PM
  #2140
Thanks I appreciate it.
masin14 is offline
Old 08-26-2014 | 06:26 PM
  #2141
madweazl's Avatar
Ran back down to Revelation to finish break in on the new engine and to test out the LRC block and wow, what a difference. Mo's setup works fantastic down there! It was 92°, I ran AE 47.5wt front and 40wt rear (613cst and 500 according to AE). The only other difference off the top of my head were droop (106/120), ride height 27/27, rebound at 10%, 5/5/5 diff oils, and the Ackerman washers are 4 over on the outside and 4 under on the inside. I would have left the washers but they rub on the front brace so I switched back and didnt notice any difference. I plan on trying 5/5/4 when the update diff shims arrive (hopefully tomorrow) but it is exceptionally good right now.
It carries a retarded amount of speed through corners. It literally seems like I'm watching a video of a race car in fast forward going around the corners (was laughing on the drivers stand). It changes direction on a dime and is super stable while doing it.
I ran AKA Impacts (soft) with AKA red foams but they werent as good as the Proline Blockade in M3. They did however last at least twice as long as the Prolines! I'm going to try the Gridiron IIs next time out but I think that is about the only other change for now. For not breaking anything, it was an expensive day blowing out 2 sets of tires tuning and testing.
Hmm, having trouble appending the setup sheet because the file size is just a touch too big. I'll work on that.
madweazl is offline
Old 08-26-2014 | 06:31 PM
  #2142
Graham11's Avatar
Proline Blockades in X compound. Lasts forevvvveeerrrr!
Graham11 is offline
Old 08-26-2014 | 06:32 PM
  #2143
Graham11's Avatar
And anyone looking for more durable clutch shoes, check out the dynamite max life shoes.
Graham11 is offline
Old 08-26-2014 | 07:01 PM
  #2144
madweazl's Avatar
What are the differences between X and M compounds?
madweazl is offline
Old 08-26-2014 | 07:02 PM
  #2145
DBL15's Avatar
could not agree more i did a test day with over a hour and 1/2 driving laps on track and checked shoes when i changed clutch bell bearing and there was only just a mark on them
and they felt great too
DBL15 is offline
