8T 2.0
#7622
I found the v2 rear tower at ebay.hope i helped you.
http://cgi.ebay.com/LOSI-LOSA1741-RE...#ht_1578wt_913
#7628
Hey guys, I just picked up a losi 8t 2.0 and I need some advice. I use a servo that is not listed in the book as far as using the spacers for it. I use a ACE 1015 servo for throttle/brake. Do i need the shims??? I also use a jr 8711 for steering, are spacers needed for that also??
#7629
#7630
It's pretty easy to tell if you need them or not. When you install the servos, check to see if they are rubbing the chassis. If they rub, you will need a set of spacers. If not, you're good to go. As long as the bottom of the servo isn't rubbing the chassis there is no need for them.
#7632
well i cant speak about the 2.0 t , but on my eight -t 1.0 ive tried the long and short ackerman rack and the short rack feels better to me you get more turn in and more steering throw its quick though lol .
but i whould just use it on a big track that has tight techinal turns.
you might like it it takes time to, get used to it can get you off guard when your driving.
#7633
) so it may take a bit of getting used to. It makes the truck feel a lot more like a buggy in the turns, but still remains planted.
#7634
thanks jammin i'll have to try it this week, i tried a setup last week and had crazy onpower and loved it, but i lost a lot of offpower and turn radius, what can i do to regain some of that. i put the front camber link in lower hole, i'll put on short ackman, bumpsteer up? etc....
#7635
