8T 2.0
#7593
no both arms being the same level, but token said its fine i can get the ride gauge to side and touch under the front end, but in the rear when i try to set it to 38mm it wont touch at all i side it right in the middle.
no matter what preload i have, im using the losi ride height gauge.
Man is it hard to understand some of your posts.
When setting ride height you want to set it so that the gauge will just barely touch the bottom of the chassis. That will give you an accurate setting. If you are saying you can't get that in the rear end, it sounds like you have too much ride height/preload. Also use 1/2 tank of fuel not a full tank when setting ride height. And lastly, for the setting to actually be accurate, you should wait till right after a run to set your ride height. This allows the suspension and shock oils to reach they're "running temperature" and gives you a true ride height setting. If you set ride height while sitting in your cool house and take it out to a track on a hot day, your settings will be off. Best way is to set it right after a run. If you can't do that, at least set it trackside in the ambient temperature of that race day. Some good ride height setting 101 for you there.
I still don't fully comprehend your issue.
#7594
[QUOTE=JAMMINKRAZY;7498584]
: Man is it hard to understand some of your posts.
oh ok yea i was measure the ride height with a full tank at my house.
sorry for not saying clearly what im talking about i was trying too.
#7600
#7604
jammin,integra,frank &others you guys on point...this thread is over 500 pages of infomation on the truggy inside out ...when i use to run my crt x2 i just run but switch to losi and read this thread every other hour or so you guys helped out alot making me understand the technical stand point of the truck ..so guys i wanna say thanks
#7605
Not a problem man! That's what we're here for.
