8T 2.0
Old 08-16-2009 | 03:39 PM
  #4186
Originally Posted by JAMMINKRAZY
Lots of on throttle landings. Big pointless ski jump in the middle that required constant throttle corrections. Brutal rythm section that only a select few could do consistantly. More about the design of the track than the surface.
I know what you mean i run two tracks often that have a lot of on throttle landings and its rough on r&p's, i put a set in 2 weeks ago after losing a set and they are already popping; any tips on tightening up mesh or something, can the alum inserts from the 1 be used, is the case worn etc..
randystang is offline
Old 08-16-2009 | 03:58 PM
  #4187
l3asher's Avatar
Will do! The parts should be to me tomorrow so I should be able to get them out to him soon after.
What parts are you trying to mod?
l3asher is offline
  #4188
JAMMINKRAZY's Avatar
I had mine shimmed perfectly with 2.0 aluminum inserts with all new bearings, and still lost a set. I really think it's just a case of a poorly designed pinion gear. I will let you guys know how my testing goes with the mod once I get it all done.
JAMMINKRAZY is offline
Old 08-16-2009 | 04:00 PM
  #4189
He is modding the bulkheads to accept the larger bearings required for the XT8 pinions. You also have to use a different driveshaft. I will post the specifics once I get my stuff back.
Old 08-16-2009 | 05:16 PM
  #4190
mrbusta's Avatar
Originally Posted by mattwoodcraft
all is set rite mate mods done ect they are the hitec 7955 servos not hitting any where rubbing on nothing epa set correctly whats happened is the servo still work but are louder than than truck driving past you man thay are loud , tix has heard them
man sorry to hear that champ they must be bloody loud if u can hear them over the car crikey i hope u get it soughted with that didnt bloody slow u down hahahahah
mrbusta is offline
Old 08-16-2009 | 05:35 PM
  #4191
l3asher's Avatar
Is it possible to use the 1.0 rear gear box and diff set up. i never blew a diff on the 1.0.
l3asher is offline
Old 08-16-2009 | 05:40 PM
  #4192
The diff setup is exactly the same between the two. You can use a 1.0 gearbox and bearing inserts if you want, but the 2.0 versions are better. I too never had issues with diffs on the 1.0, but I also never had outer bearing troubles, if you get my point. It's a different truggy, so it has different issues. I really don't think the gearbox is the problem. The guy that is doing the XT8 mods(Mark Mader) did some testing and decided the pinion was the problem.
Old 08-16-2009 | 06:07 PM
  #4193
jmackani's Avatar
Has anyone found 8t 2.0 arm guards for the rear yet without just re-drilling the 1.0 guards?
jmackani is offline
Old 08-16-2009 | 06:15 PM
  #4194
Integra's Avatar
Make your own.
Integra is offline
Old 08-16-2009 | 06:23 PM
  #4195
air8's Avatar
Yep. I make a set every now and then when I want the buggy to look pimpish and clean. Just so the lexan looks super clear.
air8 is offline
Old 08-16-2009 | 06:39 PM
  #4196
Integra's Avatar
CF guards are where its at.
Integra is offline
Old 08-16-2009 | 08:52 PM
  #4197
I know this may be the wrong tread, but i run a 2.0 with a os speed worlds 2 coming in the mail. I was wondering what pipe I should run with it, the os 2050 ot 2060? The track I run on is very technical with alot of s turns and a long straight with one big jump about 12ft in length. Thanks in advance for the input.
Measy is offline
Old 08-16-2009 | 09:06 PM
  #4198
Buzz3's Avatar
I didn't realize these were available. Any links while I hunt for them? Thanks
Buzz3 is offline
Old 08-16-2009 | 09:32 PM
  #4199
2060
underway is offline
Old 08-16-2009 | 11:24 PM
  #4200
cornerspeed's Avatar
2050, has better bottom end and mid-range.
cornerspeed is offline
