8T 2.0
Old 07-06-2009 | 06:10 AM
  #3436
chickenfarmer's Avatar
Originally Posted by CaseyP
I run a 3-3 block almost everywhere. Here is a clip of my truggy today with the set up we are talking about. The track was good wet and got pretty loose when it dried out
click here
nice place! I love the sound of the 4strokes in the background! lol
chickenfarmer is offline
Old 07-06-2009 | 01:42 PM
  #3437
i had some with the rear kicking up hard on a some jumps at a track last week, is it just the jump or the rear and can i do something for this without affecting it too much on the rest of the track. I ran the stock setup last week
randystang is offline
Old 07-06-2009 | 02:33 PM
  #3438
CaseyP's Avatar
Originally Posted by TIX
casey when you run 3-3 on the rear do you run 1 up and .5 out of 0.
the arguement has always been that the adjustables losi braces are out and that 0's are 2.7 and .5's out are 3.25
so which ones do you run to get 3 degrees of toe in
I hear ya not sure where all that started. If you want to copy a set up off of the losi site 3-3 will be 1's up for the anti squat and 0's for the toe you can also go as far as 4 deg anti squat by using 1's up and a stamped rear 3-3 plate
This is what all of the losi guys will be refering to when you read a set up
CaseyP is offline
Old 07-06-2009 | 03:58 PM
  #3439
nats time Casey! You ready?
What tires you going to take?
ABURTON is offline
Old 07-06-2009 | 04:39 PM
  #3440
mattwoodcraft's Avatar
if your happy with the oil and spring set up you can reduce your droop abit , or what i done because my truggy doing same thing , white springs 27.5 wt oil i reduced my droop to 125mm
mattwoodcraft is offline
Old 07-06-2009 | 06:26 PM
  #3441
what about front, also i just realized i had 0 in front and rear, would the 2deg antisquat have anything to do with that
Old 07-07-2009 | 05:10 PM
  #3442
pballer2777's Avatar
awhile back i saw a pic of how to measure the clutch. i can't seem to find it. could some one repost the pic or send me in the rite direction. thanx
pballer2777 is offline
Old 07-07-2009 | 05:19 PM
  #3443
digital vernier gauges and measure accross the face of the shoe that makes contact with the clutch bell , 24.3min although people do replace at 24.4 ..
i cant find the pic either maybe someone else knows what page its on
Old 07-07-2009 | 05:38 PM
  #3444
Integra's Avatar
Integra is offline
Old 07-07-2009 | 05:41 PM
  #3445
Frank L's Avatar
Originally Posted by Integra
Yep thats it and the magic number is 23.3 mm as per Adam Drake
Frank L is offline
Old 07-07-2009 | 05:54 PM
  #3446
thanx
Old 07-07-2009 | 08:46 PM
  #3447
CaseyP's Avatar
I hear its what ever will last. Can't wait sounds like silvers and or m2-xtr
CaseyP is offline
Old 07-08-2009 | 04:39 AM
  #3448
marccaracer's Avatar
Regional Moderator
Looking for shims to go between the rear axels and the hexes to take out a bit of slop. Anyone know where to find some?
marccaracer is offline
Old 07-08-2009 | 04:58 AM
  #3449
aznitronut's Avatar
Amain hobbies Team Losi Gearbox Shims (8ight 2.0)
aznitronut is offline
Old 07-08-2009 | 05:27 AM
  #3450
TIX's Avatar
TIX
the gearbox shims wont work
you need to get kyosho 8x10mm shims they come in a pack with .1's .2's and .3's
i shimmed mine up once and it made the car really twitchy and hard to drive.
losi's are designed with slop and drive best with it.
it takes some getting used to the theory that the slop helps but IMO there cars are a POS when the slop has been shimmed out
im at the point now where i would like to rebuild my car for the nationals but dont want to do it because i will loose all the slop and the car will need to be broken in again
TIX is offline
