8T 2.0
Old 07-08-2009 | 01:36 PM
  #3466
mattwoodcraft's Avatar
maybe its because they dont stick outof the body as much not sure , i guess it could have something to do with the length of the cable tie ?
mattwoodcraft is offline
Old 07-08-2009 | 01:53 PM
  #3467
pballer2777's Avatar
i failed to mention that i did open up the hole on the body alittle bit. but i did this b4 i got the rtr tank puller.
pballer2777 is offline
Old 07-08-2009 | 02:01 PM
  #3468
marccaracer's Avatar
Regional Moderator
The issue is the 2.0 stock body being so short and slanted in the front. When upside down there is no place for the zip tie to hide. Just using the flat tie works the best but is not 100%. The JConcepts body has a better area for the tie to hide and not get pulled on the dirt.
Thanks for the shim help. I understand I need some good slop. Perhaps my bearing seats got a tiny bit deeper when I had them bored out for the bigger outer bearings.
marccaracer is offline
Old 07-08-2009 | 02:11 PM
  #3469
JAMMINKRAZY's Avatar
I haven't had an issue with the fuel thing. Running a zip tie with short(about 1/2 inch) piece of tubing on the end. I als enlarged the hole in the body quite a bit. I have noticed fuel inside the body, but have yet to run out of fuel early, so I figure it's just from a messy pit. I always check my fuel level in the tank after a run, and it has always been constant even if there is fuel on the inside of the body. I may look into the fuel tank pulls. I know the buggy ones look awesome.
JAMMINKRAZY is offline
Old 07-08-2009 | 03:09 PM
  #3470
im surprised that losi just dont make the tank pullers a standard item on the race rollers thay are dam good idea anyway thay are very cheap to buy but im sure they wouldnt make the car that more expensive
your rite the buggy ones are awsome
Old 07-08-2009 | 03:40 PM
  #3471
shady3031's Avatar
Originally Posted by marccaracer
Looking for shims to go between the rear axels and the hexes to take out a bit of slop. Anyone know where to find some?
This past weekend I swapped out my wheel hubs with some buggy hubs a bud had think they were cen and it made a HUGE difference-i'm talking about the part that the wheel nuts screws onto. It seems they have a ton of slack even more than the 1.0
shady3031 is offline
Old 07-08-2009 | 04:16 PM
  #3472
Well, I just got done tinkering. I went to the camber link setup posted by Casey Peck a few pages back. I also went to the 2.0mm sway bar. Instead of cutting the stock rear links to work, I ordered a set of front links, which are the perfect length. I haven't run it yet, so I have no idea what the results of the changes are, but I wanted to get it out there that you can use front links without cutting to get the correct length. I figure most guys want to have a standard and short set on hand anyway(I do), so it works out perfectly. I used the rod ends included in the front link kit because I don't have any rear outer ends on hand, so we will see how that works out. I really don't know why there is a dog leg in those links anyway, as they don't even come close to rubbing without it. It may have been for the buggy. Anyway, I just wanted to let you guys know.
Here is a link to the links I used...
http://carolinasrc.com/Webstore/Scri...dproduct=12314
Old 07-08-2009 | 05:01 PM
  #3473
Frank L's Avatar
Has anyone tried the new TKO special clutch bearings in the 8ight cars?
TKO Special Inner Clutch Bearings
TKO Special Outer Clutch Bearing
Frank L is offline
Old 07-08-2009 | 06:05 PM
  #3474
I haven't run them yet personally, but have heard awesome reviews on them. Some of the guys at my track have run them with great results.
Old 07-08-2009 | 06:14 PM
  #3475
Frank L's Avatar
Thanks i am going to try them this weekend. I have liked the losi HD bearings so far, been on the same bearings for 3 months (racing 2-3x per month). I always like to try something new.
Frank L is offline
Old 07-08-2009 | 07:04 PM
  #3476
Integra's Avatar
ive ran them....the 5x13's are pretty stout...they last a LOT longer then 98% of other bearing's ive tried.....were you the one who backorder'd them off A-main Frank ? 4 of those were supposed to be mine.
the 5x10's seemed to be on par with my 10$ a pop Full compliment Boca ceramics....but didn't last AS long.
Integra is offline
Old 07-08-2009 | 07:11 PM
  #3477
J-DUB's Avatar
Default chillin
whats up everyone its been awhile but im back now lol. frank l your trucks looks dope and hope the spindles and hubs work out for you and for everyone goin to nats good luck and j-dub out like a fat kid in dodgeball lol
J-DUB is offline
Old 07-08-2009 | 10:19 PM
  #3478
aaron joy's Avatar
Boca Bearings ceramic full compliment 5x10 are awesome! Im not just saying that because Im a driver for them. I have a set that have been thru at least three gallons in my buggy and I had a set in my truggy that even lasted thru a clutchbell that got shredded from a rock or chassis flex. They are worth their weight in gold!!
http://www.bocabearings.com/main1.as...=SMR105C-ZZ/FC
aaron joy is offline
Old 07-09-2009 | 12:44 AM
  #3479
i have looked at the tko clutch bearings i will have to try some ...
when you clean your ceramic bearings what grease are you using to lubricate?
Old 07-09-2009 | 02:55 AM
  #3480
fleggasaurus's Avatar
Hey Matt
I have 10 pairs of those TKO's if your wanting some for the nationals. I personally haven't tried them out yet as I get good mileage out of $1 throw away ones. I mainly got these tko's for super big events such as the Australian truggy nationals.
Good question though about what you repack them with.
I have white lithium grease here, Would that work????
fleggasaurus is offline
