8T 2.0
Old 05-25-2009 | 07:55 PM
  #2716
Originally Posted by l3asher
I was changeing out the rear shock shafts. I was running the new shaft up and down when I noticed it was longer than the shock body. Is this normal?
Integra asked The Drake about this in another thread. His response:
Originally Posted by Adam Drake
Integra- It's not a concern. When you have the shock boot and cup on the shaft the piston won't go up to far.
-Howard
pur3evil is offline
Old 05-25-2009 | 08:09 PM
  #2717
l3asher's Avatar
Originally Posted by pur3evil
-Howard
Thanks man.
l3asher is offline
Old 05-25-2009 | 08:23 PM
  #2718
Integra's Avatar
Very nice Pure thank you.
way2fastrcz
for your clutch in truggy....motor will really say what spring's you need...and for buggy i would Always leave a pair of composite's in....you really dont need the excessive wheel spin that 4 alum shoes will offer over 2.....and the composite's help lube the clutch and keep everything lasting just that much longer....i would Never spring up the composite's higher then green and unlees you absolutely HAVE to i would stick to gold on the alum shoes....silver springs eat shoes for breakfast...they are imo too stiff for most any race .21
Integra is offline
Old 05-25-2009 | 08:30 PM
  #2719
Thanks Integra!
For my 2.0 truggy I'm currently using a Jammin JPX .28 but I just ordered a Werks B7 .21 08 spec from Amain this morning.
What would you recommend for both of those?
Thanks for your help...greatly appreciated!
way2fastrcz
C.Capelo is offline
Old 05-25-2009 | 08:39 PM
  #2720
Integra's Avatar
Originally Posted by way2fastrcz
Thanks Integra!
wowzer's i hope you geared your truggy accordingly to match the .28........either way.....is the werks to replace the JPX ? if so they will require different clutching....for the .28 you need the Hardest shoes you can get....IE 7075 either KH or M2C and you need the lightest spring's......28's make up for any clutch bog with sheer low end power...so running all 4 alum shoes on black's or even green's would be just fine....i personally run a M2C clutch in truggy as i find the losi is more suited to buggy.....PM me with more Q's
Integra is offline
Old 05-26-2009 | 12:33 AM
  #2721
losi_racer's Avatar
Originally Posted by CodyRothe
Your bearings should be failing if you are just spraying them with WD-40 and leaving them.
na cody, im not just leaving the wd 40 in the bearing, dirt would be filled in the bearing. i clean the car then spray wd 40 over it to give that new look and i spray the bearings as well. then i use a air compressor and spray out the bearings and spray off the car as well.
losi_racer is offline
Old 05-26-2009 | 06:24 AM
  #2722
Suspended
That will remove any grease and oil from the bearings. No lubrication = bearing failure.
CodyRothe is offline
Old 05-26-2009 | 06:47 AM
  #2723
Integra's Avatar
X2.
Integra is offline
Old 05-26-2009 | 07:11 AM
  #2724
jldjlaudio's Avatar
I do this same thing but I dont blow the bearings out I leave them as they are with wd40 in them and so far my stock bearings are tight on mine. This is how I have done every R/C i have had for the last few years and not a problem. They wear out over time but beyond that no problems!
jldjlaudio is offline
Old 05-26-2009 | 08:55 AM
  #2725
shady3031's Avatar
Integra-what m2c setup are you using on your truck. Do you use the m2c flywheel also or just the shoes. I have been using mitchs stuff for going on 2 years now and love it. Currently I have losi wheel with reg med shoes 2 green/2 gold. I am running grp 21's, was thinking of trying 4 gold springs to get just a bit more punch.
Jason
shady3031 is offline
Old 05-26-2009 | 09:10 AM
  #2726
Integra's Avatar
Jason
on truggy i run the m2c flywheel with Reg hard's and Med lites on .9's...for buggy i run the losi set-up with a variety of shoes....but i always leave a pair of composite's in with buggy.
Integra is offline
Old 05-26-2009 | 12:56 PM
  #2727
losi_racer's Avatar
i dont think i get 100% of the wd40 out which will still lube the bearings, so far the only bearing to fail were the stock 8t 2.0 rear hubs which lasted 1 race. so i didnt even touch them
Old 05-26-2009 | 05:41 PM
  #2728
sugelle's Avatar
most run a 3/3 rear end....but the stock sheet that is included with the kit is wrong....here are the proper #'s.
Rear Toe-In adjustment
Position....Insert #....total toe-IN....REAL total
Inside........1.............1............1.65
Inside........0.5..........1.5.........2.15
Middle........0.............2............2.70
Outside......0.5..........2.5..........3.25
Outside......1.............3.............3.80
Rear Anti adjustment
Position....Insert #....total Anti....REAL total
UP..........1...............3............3.15
UP.........0.5.............2.5..........2.60
Middle......0.............2.............2.05
Down.......0.5.........1.5...........1.50
Down.......1.............1.............0.95
I have the adjustable Front and Rear hinge pin braces....but reading your post above...how would I get to true 3/3 set up on rear? Also, what is the set up for the front to mimic the stock trucks set up?
sugelle is offline
Old 05-26-2009 | 06:02 PM
  #2729
Integra's Avatar
zero's up front should give you the stock anti .....and you cant run a 100% 3/3 rear...you have to settle for either higher or lower...i run lower till i feel the need for more. ..but when guys are refering to the 3/3 rear end they would be saying go with the 3.80 toe and 3.14 anti
Integra is offline
Old 05-26-2009 | 06:08 PM
  #2730
sugelle's Avatar
Thanks man...you're fast! I just got my 8T 2.0 the other day and I'm in the process of going through everything and also taking the upgrades off my 8T 1.0 and putting them on.
Another question: I see people mention using longer screw on wing mount and upper camber links. The camber link was obvious and I took care of that but I'm a little confused on exactly which screw(s) is the issue on the wing mount????
sugelle is offline
