8T 2.0
Old 05-25-2009 | 02:05 PM
  #2701
8&stuff's Avatar
changing my stock clutch now. replaced with 2 maxlifes, 2 composites and all 4 green springs...this be ok? dont have much cash to upgrade but this is whats left over after changing buggy clutch. just looking to make by for a gallon
8&stuff is offline
Old 05-25-2009 | 02:29 PM
  #2702
losi_racer's Avatar
Originally Posted by air8
Losi Racer--For this upcoming race have you done any cleaning/prep to the AVid bearings? Or do you plan to do any cleaning/prep to the bearings? Anything like pulling the seals to check for grease or adding oil? Just wondering to get an info for when you post back after the upcoming race.
all i do is when i clean my car, i clean it with simple green mixed with water, then i spray it off with a air compressor, is i spray the car down with wd 40 and i spray the bearings while there in the car with the wd 40 as well then spray it off again with the air compressor, i spray the bearings as well. i had one bearing fail in my old truggy(1.0) and i had that for about 5 months b4 the bearing failed. when i got the 2.0 i tore the 1.0 down and i still have all the bearins from that in my box because they were all still smooth but ill only use those in emergencies
losi_racer is offline
Old 05-25-2009 | 02:39 PM
  #2703
losi_racer's Avatar
you should make a gallon, what i have heard is those max life shoes last for ever but ive never used them so i cant say 100%. as far as the composites, i run 2 alum,2 comp, and 2 green, and 2 gold springs and my clutch last about 1.5-2 gallons. but going 2 gallons im at the limit, i measure my shoes after every race and i pull them when it measures 23.5 USUALLY, sometimes at 24.
one shoe i wanna try is the kings head, my dad has those in his buggy and truggy and his shoes are like brand new and he has like 1/2 to 3/4 of a gallon on them
Old 05-25-2009 | 02:53 PM
  #2704
pilotwings119's Avatar
Originally Posted by jewn_beef
get the ofna true start rear mount plate then mount it to your silver top box jsut did it today will post pics tommorow if get time
Yes please do when you get the chance! That sounds like a good idea. Do you have the part number?
pilotwings119 is offline
Old 05-25-2009 | 03:04 PM
  #2705
Integra's Avatar
Dynamite or any hard 7075 shoe will last multiple gallon's as long as you dont stall them too much....imo anything higher then gold and your asking for excessive heat and wear...if you cant make a gallon on a clutch your doing something else wrong....leaving 2 composite shoes in with 2 alum will also extend the life of the clutch significantly as the carbon's keep the aluminum from slagging on the bell and causing even more heat and slip....the measurement for the losi clutch is 23.4.....pulling the shoes at 24 is imo a waste...your leaving Alot of usable clutch material behind that can provide another couple race's worth of performance.
Integra is offline
Old 05-25-2009 | 03:15 PM
  #2706
8&stuff's Avatar
cool. the buggy clutch you helped me with works great now at about 1/2 gallon. figured go similar with truggy clutch but just try to get a little smoother. thanks
8&stuff is offline
Old 05-25-2009 | 04:11 PM
  #2707
shady3031's Avatar
The 23.4 that you speak of is that measurement the thickness of the shoe from inside to outside or what?
Currently I am using m2c racing reg med shoes with 2 green/2gold shoes and getting about 1.5 gallons per set
Jason
shady3031 is offline
Old 05-25-2009 | 04:39 PM
  #2708
Suspended
Your bearings should be failing if you are just spraying them with WD-40 and leaving them.
CodyRothe is offline
Old 05-25-2009 | 04:45 PM
  #2709
Integra's Avatar
Jason
this will tell you for sure if your shoes are on the way out and in need of replacement.
Integra is offline
Old 05-25-2009 | 05:22 PM
  #2710
Frank L's Avatar
I tried out king heads 6061 shoes rlthis weekend with all gold springs the clutch engaged great and the shoes barely wore after 40 min of practice, a 15 min main and 23 min of the a main. Best shoes I have tried so far.
Frank L is offline
Old 05-25-2009 | 07:08 PM
  #2711
I too just purchased a set of King Headz 7075 shoes. I heard that 2 of the KH and 2 of the Maxlife shoes work pretty good. Anybody know what springs I should go with for this combo? Anybody else tried it?
Can I use the same setup on my 8ight 1.0 buggy or should I use composite shoes mixed with KH or Maxlife?
Any help is greatly appreciated
C.Capelo is offline
Old 05-25-2009 | 07:23 PM
  #2712
pballer2777's Avatar
what part of the shoe r u guys measuring. from where to where. also i'm asuming the measurement is in mm.
pballer2777 is offline
Old 05-25-2009 | 07:25 PM
  #2713
sorry should have read further b4 posting
Old 05-25-2009 | 07:46 PM
  #2714
l3asher's Avatar
Default Shock Rebuild
I was changeing out the rear shock shafts. I was running the new shaft up and down when I noticed it was longer than the shock body. Is this normal?
l3asher is offline
Old 05-25-2009 | 07:55 PM
  #2715
Suspended
Yes, with the shock boot and cup on it doesn't allow the shaft to go up enough to be a problem.
