8T 2.0
Old 03-11-2011 | 12:19 PM
  #11686
air8's Avatar
LARS JOHNSON. Do you race at Burlington at all? Some of us from Hutchinson are thinking about running there a couple times before the RC PRo series race later this year.
Chris Pearce
air8 is offline
Old 03-11-2011 | 01:32 PM
  #11687
token's Avatar
Chris Pearce
Burlington is dialed, Owner is cool, track is awesome, you will enjoy it. Come out.
token is offline
Old 03-11-2011 | 01:36 PM
  #11688
Integra's Avatar
Originally Posted by MikeFriery
Yes that is the new front Center universal. I've been running them for awhile now. They work better and are more reliable. It seems they discontinued the old ones and made it a running change.
Interesting to know mike.
Integra is offline
Old 03-11-2011 | 02:19 PM
  #11689
Lars Johnson's Avatar
Chris Pearce
CHRIS! Come out and play, it's always a good time. May 20-22 is the Manufacturers Cup, the first big race of the year there. Not sure if he's running before then, but I'll see what I can find out.
The owner, Bill, is first class, he's done a LOT of work the last couple of years; the drivers' stand is huge, the layouts are always awesome - it is one of the best tracks in the state, no question. Plus, it's pretty much a party there the whole weekend.
Lars Johnson is offline
Old 03-11-2011 | 02:43 PM
  #11690
SuperSmoove's Avatar
Originally Posted by token
Isnt the stock shim settings 5 shims?
Might be, but whatever i was doing worked. Im not making this up guy!
SuperSmoove is offline
Old 03-11-2011 | 03:04 PM
  #11691
deadmancourt's Avatar
i still cant find out what was wrong with the 1.0 diff cases?.....i bough my truck used almost 1 year ago to the date and have completely changed everything except...Diffs and cases(with alluminum bearing inserts)and brake disks, rear 1.0 shocks went upfront,side gaurds and wheel hex's.....everything else is 2.0....but i have been running the same ring and pinion since i bought it...when i clean and refill the diffs i clean and regrease the r&p...no shims on the pinion...i was hearing the chrunch under braking, and was told it was my r&p and to change them...well i cleaned the rear and looked at the r&p and they are still perfect, hardly any wear at all...im not making this up...i will take my truck apart again and show you pics....the crunching, i am hearing is coming from the center diff...i think its the old brake disks( original 1.0)...i dont run lots of brake, so the slightly ovalized disks are just making noise as they are put under pressure.... its not loud.
deadmancourt is offline
Old 03-11-2011 | 03:12 PM
  #11692
tc5 man's Avatar
thats what some people who are having problems with the 2.0 t shimming should do.
get the 1.0 diff cases.
i never had one problem with my diff on the 1.0 t.
tc5 man is offline
Old 03-11-2011 | 03:20 PM
  #11693
i was looking for some..and they are pretty hard to find, cause they are discontinued
Old 03-11-2011 | 03:22 PM
  #11694
tc5 man's Avatar
oh dam thank god i got a diffrent truggy than !
is that just horizon who discontinued them ?
tc5 man is offline
Old 03-11-2011 | 03:47 PM
  #11695
JAMMINKRAZY's Avatar
Even on the 1.0 gearbox I shimmed my rear diff. The only advantage to the 1.0 gearbox is that they were made out of slightly stiffer plastic compound which made them more rigid. The 2.0 design is much better. With the 1.0 gearbox the non-pinion side bearing insert could spin inside the gearbox = very bad.
As long as you replace the gearbox every now n' then, use aluminum inserts and shim the diff tight, the 2.0 gearboxes work just fine.
JAMMINKRAZY is offline
Old 03-11-2011 | 08:10 PM
  #11696
sluggo_sx8's Avatar
How often should the case be replaced? once a season? every 2 or 3 gallons? Mine has about 4 gallons on it with the same R/P. I pulled it apart and changed all the bearings and reshimed but wondering if I should do the case as well now.
sluggo_sx8 is offline
Old 03-11-2011 | 08:12 PM
  #11697
Couple times in a race season is usually what I do. If you kill a R&P always replace it then as well.
Old 03-14-2011 | 06:48 AM
  #11698
siv06's Avatar
Ran this UJ the first time over the weekend - suddenly got a lot more off power steering, highly recommend this upgrade
siv06 is offline
Old 03-14-2011 | 08:03 AM
  #11699
teamlosi906's Avatar
It should last long enough that, that isn't an issue. You could really never get the CVD back to like new with a rebuild anyway.
Where can you buy the new center shaft ??
teamlosi906 is offline
Old 03-14-2011 | 08:23 AM
  #11700
token's Avatar
Team Losi Front Center Universal Driveshaft
[LOSA3588]
Amain $26.49
Limited Quantities
Available.
Horizon $28.49
token is offline
