Inferno MP9 thread
#9631
been told to build mine full, turn the gears when filled to release any trapped air within the diff casing then fill just below level and wait for the air to escape, when you drop the top gear in oil should be flush if not top up, when the crown gear is screwed down it should bleed any excess oil out the screw holes,the reason for this I have been told is to make sure there are no air pockets inside, if you have air it heats up and then expands faster than the oil and can force the oil out faster making the diff become inconsistent, TBH I have only built mine once so cannot say any other way works better or worse but that is the advice I was given.
#9632
Have to say that's a very strange way to set the oil level in a diff. And being so far off the method all manufacturers and a vast majority of pro level racers use, I really have to question it's value. I've certainly never heard of anyone ever bleeding oil from their diff or being so concerned about air pockets. If the air was such a huge problem, or even a little problem, surely the manufacturers or at least some pros would mention it, but haven't ever heard it talked about before, and the pros are going to be the kind of driver who is able to feel when their diff goes off during a race, not slow coaches like you and I, so is there really any need for all that hassle and mess when the "fill to just above cross-pins/small gears" method is SO much faster and easier to do and seems to be working perfectly for everyone from beginners to WC levels drivers?
Just my 2c.
Just my 2c.
#9633
How full your diffs are is only important for your OWN records. You just need to be consistant with what you use as a full mark so when you make changes you will be able to feel the difference. The amount of fluid will make a differenc in how the diff feels.
I guess the only time knowing what someone else is doing is if you are trying to duplicate their setup My 2 cents.
Scott
Scott
#9634
I personally do not fill my diff to the top. Also, I am more concerned about a good seal (o-rings/outdrive/gasket) vs. air bubbles although one can argue that air bubbles could be a byproduct of a bad seal or faulty build. With the higher viscosity diff oils, I think it's important to allow enough time for it to settle into the diff case before measuring the oil level. You should turn the outdrive a couple of times (make sure to hold down the top gear down snug against the crown gear with a small hex driver) and let it settle again. Repeat until you feel that the oil is completely settled in, you shouldn't see bubbles at this point. I'll also put a drop or two of oil on the gear side of the diff to ensure that the o-rings form a good seal with the outdrive.
I didn't see anything about sanding the diff case or doing anything special with the gaskets on the K car. I guess these don't require any special attention.
I was looking through the TKI2 manual and noticed that the center diff is larger than the front and rears.
So I guess (5)-(5)-(3) in Cody's setup is more like (5)-(5+)-(3)
#9635
For me personally this is the best way, I have been doing it this way for years as it is more Consistant.
#9636
Just my 2c.
Just my 2c.
#9640
Well they need to hurry up and ship mine to me so I can put my buggy back together
#9641
I was told by my local hobby shop that all of my upgrade items shipped (3.5 HD shafts, towers, radio tray, battery box etc) Hopefully this is accurate and it was not a mistake and it's all on back order .
#9642
New Ride
Heres a Few pics Of my new ride!! And Happy To Own Kyosho Products, bar none they are the best !!!!
#9643
does anyone have a set of ft and r light blue spring they want to sell
