Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-05-2012, 04:37 PM
  #10381
Trader Rating: 18 (100%+)
Originally Posted by 1evo RRR Driver
is there a reason why most are not using the sp tapered or the standard tapered?
I think the main reason is because that most of the setups online from Jared and Cody use the "normal" pistons instead. A fellow K-car driver at my track uses them [the tapered] and really likes 'em.
KSimmonds is offline
Old 06-05-2012, 04:43 PM
  #10382
1evo RRR Driver's Avatar
are you running 1.3 fr/rear because of a tebo king setup?
1evo RRR Driver is offline
Old 06-05-2012, 04:46 PM
  #10383
Yep, I am. Jared runs at my local track and was nice enough to share his setup there as a starting point for me as I just moved to the Kyosho car a few weeks ago.
Old 06-05-2012, 04:52 PM
  #10384
thanks for sharing the info with me, so i guess 1.3 non tapered it is!!! but they are still running lighter oil in the rear??
Old 06-05-2012, 04:56 PM
  #10385
Seems to be the case under normal conditions so I'm told.
Old 06-05-2012, 05:07 PM
  #10386
oghobavo's Avatar
Do you mind posting what Tebo told you regarding his setup?
oghobavo is offline
Old 06-05-2012, 05:15 PM
  #10387
where did u find non tapered piston for Kyo big bores?
Old 06-05-2012, 06:27 PM
  #10388
Sorry, I worded that poorly. What I run are tapered, but I was referring to the SP tapered hole pistons which come with the TKI3 which I replaced.
Old 06-05-2012, 06:46 PM
  #10389
ok thanks, next issue........i purchased tki3 rear shocks and mine came with flat bladders, a buddy of mine built a tki3 kit and his had dome bladders, i also purchased strr evo shocks and they also have the domed bladders!!
what was in Ur tki3??
Old 06-05-2012, 06:47 PM
  #10390
All I really got from him was the shock set up, which was 45wt losi in front, 30wt losi in back using the 1.3x8 non-SP pistons all the way around. He did mention that a lot of people like to run heavier oil than he does as he has a certain feel to his cars that he prefers.
I suspect that his car may be lighter than mine as well due to the ti screws it appears he is using throughout. He did say that he runs a 48t spur with a larger than required spacer under the center diff mounts for extra clearance.
Just from looking at other settings on his car, it appears to me that it is very close to the setup online from the NEO 2011 race.
Old 06-05-2012, 06:48 PM
  #10391
Mine were of a flat variety as well.
Old 06-05-2012, 07:27 PM
  #10392
Trader Rating: 25 (100%+)
Originally Posted by Coach Townsend
Its abouot damn time!!!
Congratulations, you gotta be happy with that
smelly62 is offline
Old 06-05-2012, 08:13 PM
  #10393
Default Nice!
Great to see the Kyosho on the podium! Congrats!
dirtn is offline
Old 06-05-2012, 08:29 PM
  #10394
oghobavo's Avatar
Thanks bro. I was just curious if he was running a similar setup to Cody because we don't see his setup sheets as often as we see Codys.
oghobavo is offline
Old 06-05-2012, 08:45 PM
  #10395
CALVIN THINMAN's Avatar
IN CONSTRUCTION
YOUR CAR, I PLAN ON GETTING A REVOLVE CAR STAND, AND A PIT TOWEL. ARE THINGS LIKE HUDY SET-UP SYSTEM A WASTE OF $$$$$$. ALL ADVICE IS APPRECIATED!!!1
CALVIN THINMAN is offline
