Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-31-2015, 11:35 AM
  #18736
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by sn47som1
Effects of added weight, I dont think DF comes into play, that's different.
Like I said, take off the wing and body and add weight and go racing.
SEF is offline
Old 03-31-2015, 11:45 AM
  #18737
aloksatoor's Avatar
Trader Rating: 43 (100%+)
The weight of a wing is negligible compared to that 7.5 pound car if thats what you are saying ~3% assuming a wing is ~100grams (bit on higher side). I can't feel the weight of the fuel between when the cars almost empty and cars full (full tanks around 100grams assuming pure methanol 125cc).
aloksatoor is offline
Old 03-31-2015, 12:12 PM
  #18738
sn47som1's Avatar
Wing and body.... but ya still not alot of added weight there.
Intersting idea tho- take off the body/wing, but add weight. Ill have to try that!
sn47som1 is offline
Old 03-31-2015, 03:56 PM
  #18739
houston's Avatar
Trader Rating: 96 (100%+)
youre nuts if you dont think the weight of a big plastic wing being that far over the CG of the car heighth wise doesnt play a huge factor in handling characteristics . i want to switch to the new lexan wing but i love the look of a colored wing
houston is offline
Old 03-31-2015, 04:00 PM
  #18740
aloksatoor's Avatar
haha yeah but the effect of downforce is way more than the weight. I wont last 2 laps with that lexan I destroy the plastics every two races weekends .
Old 04-01-2015, 10:33 PM
  #18741
KyoshoRed's Avatar
Anyone running that Reds Quattro 4 shoe clutch setup on their MP9? If so what you think?
KyoshoRed is offline
Old 04-02-2015, 12:55 PM
  #18742
sn47som1's Avatar
^^ what he said
and wats this about a new lexan wing?! :0
Is it the Proline one?
sn47som1 is offline
Old 04-02-2015, 03:08 PM
  #18743
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
+1
I noticed a difference (with the lexan Trifecta Wing) in handling the tight twisty sections (where there isnt much speed required) yet the car seems more planted and reactive in the rear end than with the Plastic Wing. This is on both my MP9 and MP9e. It makes a noticable difference. It may seem negligable yet I can tell, and the rear is not as quick to break loose it seems, and that it reacts quicker to brake and throttle inputs in flight (may or may not be the aerodynamic effects of the wing) yet I am pleased with it.
Just take a 4wd 1/10 car remove the lexan wing and install one of those plastic wings (I think Academy had one for their 4wd car) - I am sure it would be even more noticable, where the heft and weight of a 1/8 chassis is not as extreme.
I for one like it and run a softer sway bar now in the rear.
Just my 2 cents worth.
Last edited by 1/8 IC Fan; 04-03-2015 at 06:28 AM. Reason: bad grammer & missing info
1/8 IC Fan is offline
Old 04-03-2015, 05:08 AM
  #18744
sn47som1's Avatar
I want to try the regular plastic mold trifecta wing. Its got a lower deck height which is nice.
sn47som1 is offline
Old 04-03-2015, 05:11 AM
  #18745
sn47som1's Avatar
I haven't, but to be honest I would try the Novarossi buggy clutch before the Reds. just my .02
sn47som1 is offline
Old 04-03-2015, 06:39 AM
  #18746
Trader Rating: 21 (100%+)
Does anyone happen to have any info on Tebos set up he ran in
the main at Silverstate?
rcmoe is offline
Old 04-03-2015, 06:52 AM
  #18747
ale_huelva_02's Avatar
You could find the setups at JTP blog.
ale_huelva_02 is offline
Old 04-03-2015, 06:58 AM
  #18748
sn47som1's Avatar
Not sure, try to find set up sheets for him online
sn47som1 is offline
  #18749
Moderator
WYLDTHING's Avatar
Trader Rating: 159 (99%+)
Here ya go...
WYLDTHING is offline
Old 04-03-2015, 07:06 AM
  #18750
Thanks!
rcmoe is offline
