Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-27-2012, 12:15 AM
  #11236
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by buchanan88
I have a D8 hara, just wondering if anyone can compare the two...
Your wallet will be comparably lighter
rallyebmx is offline
Old 08-27-2012, 07:29 AM
  #11237
buchanan88's Avatar
Yea I really dont care about that!
buchanan88 is offline
Old 08-27-2012, 12:38 PM
  #11238
KarBro's Avatar
This is from my maiden voyage with the MP9 TKI3, It had been raining al morning so the track was really soft and slippy. But it was great to get the feel of the car. So now its not so new any more This weekend coming I hope to get to a track that is in good shape.
KarBro is offline
Old 08-28-2012, 01:38 AM
  #11239
ben73's Avatar
Trader Rating: 40 (100%+)
Well I am back from the FEMCA asian championships at Pattaya. Great event. Won by Kyle with the MP9 and Wataru came in third with the MP9. The Car was great there.
I got to rebuild my car on saturday with the legend Kanai as he had flown in to support us. Prior to the semi we rebuilt my car totally and I thought I would share a few tips I got from the master.
1. When building the diffs smear the grubscrew that seals the housing in grease so it seals perfectly.
2. Before you build the diff take the plastic half and you will see that its got a circular line where the outdrive bearing meets the plastic case. On both inside and outside seal this with a drop of CA and run it around the join line
3. Kanai smeared the diff gasket in grease to form a perfect seal also
4. Use a small amount of shoe goo when installing the side plates to the chassis, this keeps out water if/when you clean the car
5. With a sharp x-acto blade you remove a tiny amount of plastic from the inner edge of the steering rod ends. Kanai had the knife at a 45 degree angle when doing this and removed probably 1mm all the way around. The ball popped in nice and easy when this was done.
6. When we built shocks he did not fill them all the way to the top, probably about 3-4mm from the top. doing this we bled less oil and the rebound was perfect each time.
thats about all we did that was different to a normal build.
enjoy
ben73 is offline
Old 08-28-2012, 01:49 AM
  #11240
rallyebmx's Avatar
^good stuff thanks
Any reports of breaking the updated TKI3 outdrives?
Im gonna have to replace my Agama outdrives soon and contemplating putting on my updated Kyosho ones, but ive seen several TKI2 outdrives break here and it doesnt give me much confidence
Old 08-28-2012, 04:42 AM
  #11241
ben73's Avatar
Originally Posted by rallyebmx
^good stuff thanks
totally forgot to ask.
I have never had one break and I did not see one break all week. and I have never experienced a track with grip like pattaya had last week. way more grip than the worlds in 2010.
the new HD center shafts are really nice, and Kanai had the 93mm HD front shafts for us also as a precaution
ben73 is offline
Old 08-28-2012, 08:25 AM
  #11242
Coach Townsend's Avatar
http://www.neobuggy.net/modules/news...?storyid=12485
Can someone tell me whats good on Agion's car other than the car itself.
Coach Townsend is offline
Old 08-28-2012, 08:51 AM
  #11243
KarBro,that track is supposed to be that way or its just lack of running?That color scheme really works well.
30Tooth is offline
Old 08-28-2012, 09:23 AM
  #11244
Happy Meal's Avatar
enjoy
Im suprised that the main isnt posted on youtube yet...quals and interviews, but no main....anyone have it yet?
Happy Meal is offline
Old 08-28-2012, 11:08 AM
  #11245
CJ RC's Avatar
As Ben said what a great FEMCA event put on by Charlie very professional and the parts support from Kanai was fantastic good job Kyosho! with the high grip most of us run setups we never experienced before I think we all can say we had great cars at this event and big congratulations to Kyle and Scott McBride on back to back FEMCA Championships
CJ RC is offline
Old 08-28-2012, 11:50 AM
  #11246
305M3's Avatar
Trader Rating: 43 (100%+)
It's awesome you and Ben got to race at the event. Can you post your setups for curiosity sake?
305M3 is offline
Old 08-28-2012, 11:55 AM
  #11247
KarBro's Avatar
The track sadly isnīt run on that much anymore, but there is a new one getting built not so far from it. The car looks great, feels great, it was a blast to drive it even if the track was awful.
Iīm hoping for a rain free weekend coming up, and that I find some time to get to a better track!
KarBro is offline
Old 08-28-2012, 01:36 PM
  #11248
morocho1979's Avatar
hello i will buy a new TKi3 but i have to wait tou buy the 93mm shaft so any advise for using 91mm shaft Stock in the front i dont want to race and pop out
morocho1979 is offline
Old 08-28-2012, 04:53 PM
  #11249
For that type of surface I have a set of Medial Pro Turbo Rats that work pretty good and act as lawn mowers too .Tracks like that are the norm around me so you have to bring a set of grass tires and then when it's just dirt is so compact that you can almost run slicks.
O another thing I want to improve on my K,the brakes are not linear,they're too strong now and can't use EXPO.Using 10mm of fuel tube,should use springs instead?
30Tooth is offline
Old 08-28-2012, 05:17 PM
  #11250
lewis4x4's Avatar
We kept having outdrive issues until we were told to use the 93mm shaft. Since we changed, no more issues...
lewis4x4 is offline
