Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-11-2015, 12:19 PM
  #18886
am
Does this one fit TKI3?
http://www.amain.com/rc-cars/protek-...0-s-2s/p233424
am is offline
Old 05-11-2015, 12:52 PM
  #18887
Trader Rating: 42 (98%+)
Originally Posted by am
not 100% sure but i know the 1900 does
RockStar_199 is offline
Old 05-11-2015, 12:54 PM
  #18888
Moderator
WYLDTHING's Avatar
Trader Rating: 159 (99%+)
Yes, they fit perfectly and work great. Been using them for over a year now.
Thanks, Brad
WYLDTHING is offline
Old 05-11-2015, 05:34 PM
  #18889
coneman's Avatar
Originally Posted by max92804
So the bearings for the brake plate are a direct fit and I wouldn't have to modify any thing????
yes.
coneman is offline
Old 05-11-2015, 09:44 PM
  #18890
KyoshoRed's Avatar
Originally Posted by jaron_cc
No you'll have to run the Reds clutch bell.
Any idea if they wear as good as the Kyosho bells? Trying to figure out what its gonna take to run this setup every week before I buy it.
KyoshoRed is offline
Old 05-12-2015, 05:39 AM
  #18891
Has anybody seen a set up sheet from Tebo when he won at PNB ?
Eastside777 is offline
Old 05-12-2015, 09:43 AM
  #18892
Winner's Circle's Avatar
Check his website. He has the set-ups for PNB for all his cars.
Lee
Winner's Circle is offline
Old 05-12-2015, 05:25 PM
  #18893
carpet Carlos's Avatar
Originally Posted by KyoshoRed
Anyone running the Reds racing Quattro clutch on their MP9? If so does it work with a stock Kyosho clutch bell?
Or the losi bell
carpet Carlos is offline
Old 05-12-2015, 09:02 PM
  #18894
golferdude1971's Avatar
Trader Rating: 18 (100%+)
it works with the Kyosho bell.
golferdude1971 is offline
Old 05-13-2015, 06:35 AM
  #18895
Not my kyosho bell you can still see the shoes
Old 05-13-2015, 02:18 PM
  #18896
Trader Rating: 16 (100%+)
Here you go mate: https://jtprc.files.wordpress.com/2015/02/mp9-2015-pnb.pdf
aaron125 is offline
Old 05-14-2015, 01:06 PM
  #18897
It looks like 1.5x5 is the new tHiNG to run.
My ST-RR EVO is offline
Old 05-14-2015, 02:54 PM
  #18898
Trader Rating: 17 (100%+)
Sure is coupled with the orange springs, im gonna make up some 1.5x5's this weekend and give it a shot... But Tebo drives so calm and relaxed, I've never had much luck with his setups.....
jaron_cc is offline
Old 05-14-2015, 03:25 PM
  #18899
What Exactly is needed to make up 1.5x5 pistons and what weight oil are most people running in them generally
C.moore is offline
Old 05-14-2015, 03:38 PM
  #18900
Holmberg418's Avatar
Get the 5x1.4 pistons and drill them out to 1.5 . kyosho will be releasing the 1.5 pistons soon. 40 front 30 rear is a good place to start.
Holmberg418 is offline
