New XRAY 808
w/c of the werks clutch fits on the stock xb808 clutch bell, 32mm or 34mm? thanks for the info..
almost done, onto electronics next
7f/10c/5r
12degree blocks with 5degree king pin knuckles
--2mm bump steer under linkage at knuckles
Aluminum Steering Plate-middle position
front shocks-550/front violets/ 25% rebound/ 1/16 drilled cap with foam
rear shocks-475/front purples/25% rebound/ 1/16 drilled cap with foam
Jason Branhams hinge pin settings (his most recent setup sheet)
OS .19, Ascendancy 2x.9 carbons, 2x1.0 aluminum
7f/10c/5r
7f/10c/5r
7f/10c/5r
Nice!
7f/10c/5r
7f/10c/5r
Who has the 5 deg kingpins in stock?
anyone got a setup for a rutted dirt track on the 11 spec?
tried grizzs setup with the 1.1s in the back and the car was gettng fired all over the place,mainly the rear end getting bucked up in the air.
haha i see you too....get back in your own forum lol
Guys what does the lower holes on the shock towers do?I have front grey springs on the rear and i cant seem to get the ride hight were i want it, so I thought about dropping to the lower holes.The shocks are in the stock holes now.
Lower holes in both F and R towers are for when you use the outer holes in the A arms for the lower shock mounting...otherwise you won't get anywhere near full droop.
Oh yea thats right.Well anybody have any tips on getting good ride hight out of this setup?The most I get is arms level which is around 27mm using a losi ride hight gauge.
How much distance do you have between your shock cap and upper spring retainer? 28 -29mm is the norm.
I would think going back the bigger piston holes of the kit set up would be the go on a track like that. 1.3 x 6 holes or similar all round - oils not sure. Maybe someone can give us a good Losi oil set up for kit 1.3 x 6 pistons all round ?
