Mugen MBX6
got mine from amain too. I will call mugen tomorrow.
I have alu hubs on my electro Mugen and the bearing is even a little tight. I grease the outside of the bearing a little to get them out easier.
i need to replace the pins in my fly wheel and on my axels, what tool are people using to remove the pins and put them back in?
Thanks in advance.
Thanks in advance.
Hammer and something to heat the flywheel. Just buying a new flywheel and be done with it.
how much up and down play is acceptable on the servo saver? I was thinking about shiming it? or is the play they for a reason?
Great question
Email is a great way to communicate, however I have never had a response from Mugen.....It's like they don't exist.....
1. good tools last forever.....
2. with the price of the mugen bones it pays for itself the first time I replace all the pins as 6 bones are more expensive than the tool
I use the HARD replacement tool and it works great.
It is $10 cheaper than the hudy and you can replace the parts of the tools if they break or wear out. I have never used the hudy and i am sure it would be super high quality, just depends which way you want to go.
I think they sell them on the hard web site or www.rc-mushroom.com, not sure where else stocks them. I have never had a problem with mine and it works a treat
I use the inovative designs bonesaver to replace all of my pins. Its half the price of the hudy one and it works great
I use a chain breaker I bought of eBay. Less then 40$. I have replaced my pins many, many times. Break a pin and a new one is about 5 bucks. Heavy duty
