Mugen MBX6
#1081
Has anyone tried a Proline low-pro filter foam in the Mugen filter body? They look similar.
#1082
Hi All,
I am designing an upper plate that replaces the top diff mount for the MBX6 for an electric conversion. The purpose of this tray plate is the following:
* mount a cooling fan above the motor. This system is designed to support both 30x30mm and 40x40mm fans
* mount personal transponder
* mount receiver
* mount ESC
* mount misc. items
YES, YOU WILL BE ABLE TO MOUNT ALL OF THIS WITH MY DESIGN!!!
With this design, you will make your electric conversion simple, neat, and centering your components in the middle of your car.
These pictures are the prelim of the design and will be fabricated in aluminum and possibly carbon fiber. I have not yet determined a price per unit, but I will sometime next week. If there are a lot of interest in this design, I will fabricated across other models of buggies like Xray, Losi, and Kyosho.
Here of some photo's of the prelim design. Please PM if interested in one of these units. I am guestamating I can have them shipped by mid to end of next week.
* mount receiver
* mount ESC
* mount misc. items
#1083
#1084
This looks like a good kit but you think overkill for a newbie i really like what is being said about this kit. I have been jumping from jammin 2 rc8 and mugen and even the O'Donnell (499.99 at amainhobbies)
#1085
Well folks, I dont want to start a p$ssing match or try to say I told you so but I have a proline shift body that I just sprayed and mounted and it fits pretty darn good. I bought 2 of these and after hearing all the negative remarks I chose not to have them painted. My painter gave me my kit body and my 2 shifts back last night and 1 of the shifts was already masked so I figured what the hell. I did cut the body holes first and the front hole is quite a bit off but from what I have read you can rotate the front body post or just simply cut your holes before you paint as I did. Once everything was dry I finished trimming the body and my steering servo does not rub or hit, and my throttle linkage does not hit either while at full brake or wot. I think one of the biggest variables is the type of servo horns you use and how much epa your servos have that will determine if you are going to have issues or not. Only time will tell but so far so good.
#1086
front droop ?
hi, how much droop setting are you guys setting ? my rear am able to get 12mm but my front droop the lowest i can go is 18mm ! thought saw some setup with droop 12mm in the front.
the droop is set with 2 standard size buggy wheels underneath the buggy right ? many thanks..
#1087
Anyone here notice the rear droop screws are only half touching the chassis ? They are right out on the edge and are half hanging off ?
I just got my X6 Thursday and finished building it today and while looking it over I flipped the car upside down and noticed the rear droop screws are only just catching the edge of the chassis. I think Mugen could have made the chassis just a touch wider in the spot.
#1088
#1089
Has anyone attempted to use MBX5 mud guards and body? I like a JP2 pipe on some of my engines but it probably isn't going to fit under the body.
#1090
Ive experimented with header pipe combos and found a JP3 pipe with a 2050 header fits perfect in the car and Makes a ton of power with my Speeds.
#1091
#1095
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
yes a 14t clutch bell helps the x6 out alot. you don't loose any low end. it makes the car easier to drive. might try a 15t when i get a chance to run the car again. jeremy
