Mugen MBX6
#4621
Are you talking about the screw that tightens the carb? The one directly under it that when loosened alows you to move the carb? Sorry just wanted to make sure im thinking of the same thing.
I really dont want to think anything is wrong with tank , not to worry lol...i just want to figure out what the issue is as i am about as lost as possible. Thanks for the tips.
#4622
#4623
Well i want to say that my car seems to hold its tune pretty well.
Sooo, what do you guys think would cause the car to dump the fuel back in the tank when it flips over? Like seriously as soon as it flips over it shoots the fuel back into the tank and will run for like 2 seconds after its flipped back over before its cuts off.
Just saying that, what could be causing this etc.
Could the tank lid thing actually cause this since the car is running fine until it flips?
#4624
#4625
yeah i will check on the lid, but just trying to ask all the questions i can to figure out this problem. Sorry for being so annoying lol
#4626
I'm not getting how fuel is dumping back into the tank, are you saying that the fuel is going backwards from the carb? If so, could be a lid problem. I guess something could be causing you to lose tank pressure when the fuel hits the lid (upside-down) but the car would rev momentarily if this was the case because it would go lean when feed pressure was lost. If everything is working right, the engine will eventually starve of fuel when it's upside down (fuel pickup is at the bottom/rear), your situation almost sounds like it's drowning out. If you have an extra fuel filter around, try taking the guts out and putting it in line on your pressure line. This is something guys have had good luck with if they're having problems with their engines flooding out right after pit stops.
#4627
#4628
#4629
It adds extra volume to the pressure line, like running the line really long. The theory is that when the tank is filled to the top, when the lid closes and the driver applies the throttle, the pressure spike that occurs floods the engine. This is likely partially caused by a rick bottom/lean top tune that's pretty common. I've had an engine or two that would only make good power this way but didn't idle well.
#4630
Yes fuel will go backwards from the carb when flipped over, when i try and get going again once flipped back over it will cut off after about 2 seconds and then it takes a long time to start it back up because it takes forever to get fuel back to the carb. I havent had issues with pit stops or just driving, only when it flips. Basicly if i dont get flipped back over within 1-2 seonds, its over.
#4631
#4632
#4633
Well your fuel line routing looks fine. Unfortunately you are just going to have to play process of elimination. I would first take out the tank and pressure check it. I would next check all fuel lines and fuel filter for any clogs or ruptures. Next I would inspect your engine completely, checking for any leaks, torn orings, any screw that may have been loose, etc. I would seal the motor up to while you are putting it back together. Once you have all of these things checked and cleared put in a new plug and retune. It has to be something simple, there is only so much it could be. My problem ended up being a small piece of fuel tubing stuck in the high speed needle. Good luck.
#4635
yeah i guess i will just have to go from there lol ...the pressure line was longer today but i went back to how the manual showed it since nothing seemed to change.
Thanks for the input guys, like i said its just weird that the fuel seems to dump back into the tank when its flipped....maybei i should just learn how to drive rigth side up 100% of the time and i would be good to go lol
