Mugen MBX6
#2341
blk transam if you are running at extreme, run the jason ashton setup, with 32.5 losi oil all the way around, 1st kit stock springs. which are one step stiffer than the new kit springs. I am running 5-7-5 in the diffs, pink taper pins, stock sway bars and my buggy is strapped. Also moved to the front ackerman setting and rear hubs in top whole.
Ashton setup
FRONT SUSPENSION
Front Kingball Spacer: 1
Camber Angle -2
Upper spacer 3mm
toe angle out 1 degree
Anti roll bar 2.3mm
Lower arm mount (kickup) 0
Lower arm plate: Center
upper arm plate Center
Lower arm spacer 2mm Behind Arm
Rebound stop 15mm
REAR SUSPENSION
Camber -2.5
Lower arm mount 0 3degree
Anti roll 2.7mm
Anti Squat Middle
Upright plastic
Wheel base Long
Lower arm spacer 1 in front of arm
upper arm position-tower: Middle
upper arm postition-hub: Middle
Upright pin posititon Bottom Hole
rebound stop 15mm
FRONT SHOCKS
Pistons stock
Fluid 400
Middle on tower/ Outer on arm
Spring: stock
ride height 31mm Front and Rear
Steering ackerman: middle
REAR SHOCKS
Pistons stock
Fluid 400
1 in from Middle on tower/ outer on arm
ride height 31mm
Gearing Stock
Diffs 5-7-5
Ashton setup
FRONT SUSPENSION
Camber Angle -2
Upper spacer 3mm
Anti roll bar 2.3mm
Rebound stop 15mm
REAR SUSPENSION
Camber -2.5
Anti roll 2.7mm
Anti Squat Middle
Upright plastic
Wheel base Long
rebound stop 15mm
FRONT SHOCKS
Pistons stock
Fluid 400
Spring: stock
REAR SHOCKS
Pistons stock
Fluid 400
ride height 31mm
Gearing Stock
Diffs 5-7-5
#2342
no I was not at extreme this week no racing due to crcrcrcrcrcrc lol raced at newberrys.
thanks for the set-up how do I set up rebound stop?
what did the front acerman hole do for you? more steering out of the turn?
#2343
Front ackerman setting seemed to smooth out the steering, less agressive initially, little less twitchy best way I know how to describe what it does
To measure rebound stop remove wheels and tires and set the buggy up on two rims
___________________ chassis
== ----------== rims
set the buggy on the edge of a flat surface where you can take a set of calipers and measure from the bottom of the rear hub to the flat surface and adjust the droop screws. Same with the front
______ bottom of hub
/\ 15mm
l
l
---------------- table
/\ 15mm
l
l
#2344
hey !!!!
we have sum hot new parts for the MBX6 Online.
Take a look........
We made the parts for the mbx5r last year. works fine. makes the diff change really fast......and changing the the setup will be easy !!!!
more parts coming.
watch out our homepage :
http://www.vita-tuning.de/
as promised here are more parts :
fuel tank holder........so the tank can not move around at the kardans or the muffler holder.........
a new Fast Engine mount system.
and a multi tool to press the bushes out of the tuning parts and to change
angles of e0808 Rear for example.
Take a look........
more parts coming.
#2345
thats what I thought but was not 100% sure. thanks for clearing that up! I have recieved several pm's with set-up info and appreciate it very much guys thanks for the advice on this car! if the rear end was not so aggressive I would be in love lol but its a toss up on my rc8 that car just drove great. I will give the mbx6 a few weekends and see what happends. I mean set-up is 90% of how a car drives. again thanks to the guys that have take a min to help me out!
is there anywhere to print off blank set-up sheets for this car?
#2348
Is it just me or is anyone else peeved who bought the kit when it first came out, what about 3 months ago, and now the new kit has so many different parts and changes that I have to buy. I'm a huge fan of the 5R but it's hard to keep up with a car that changes every 3 months.
#2352
Mine did that too.
I would much rather Mugen not update and improve the buggy, at least this way I wont have to keep up with the Jones's.
#2353
They also help the car jump a little better and higher.
Stiff springs are suited for high-traction tracks, which aren't too bumpy.
Softer springs are better for (mildly) bumpy tracks.
They can also make the car feel as if it has a little more traction in low-grip conditions.
the 6 skips out in the rear at times, so by adding softer springs will tame it down a bit. but you dont want to go too soft.
#2354
I am one of those people who have been running everything bone stock. I may have brought different springs and extra parts, but i have yet to sport any of the running changes.
You dont NEED any of the running changes, the only piece you really need is the front upper arm piece. besides that its dialed.
I also upgraded to the aluminum option parts, but they arent needed as well.
the newer kits will have everything in the box as is, which is a good thing. with other kits, the manufacturers wont make any running changes, so after you buy the kit, then you will have to spend a grip on upgrades. with this kit, you are dialed either way, but more inviting to the new customer, as he or she wont have to worry about upgrades, as the kit will already have them included.
jmho
jmho
#2355
Stiffer springs make the car feel more responsive, more direct.
