Mugen MBX6
Hey will,
I'm the guy mal is talking about with the diff cases, upon further inspection it looks to be just a plastic strain on the lower wing mount screws as I had a problem with my very lowest screws holding rear shock tower to case coming loose an even out I think this is the main problem as when they strip the thread it will flex an break the top of the case.
The fix is to use longer screws on the bottom of the tower an put a nut on the end. I used some long mugen screws with savox servo loc nuts on the end and it even feels better now when you flex it by itself
will
could somebody please do me at favor and measure the width of there center diff mount i need center to center of the bolts top and bottom
Hi guys i have a question if someone could help me. I just bought a used mbx6r EU and i want to use the set up station of hudy that i already have. I should use the set up station straight or i have to use with a rim under the car to be the right way?
The car must be in the station without wheel under the chassis. And be sure that when you check your front camber the specific wheel is at zero toe.
Hello folks.. I might be getting a used MBX6R EU here soon...(yep - another one doing that, now that the 7 is out ha ha..) I've only ever run AE (and one Hyper..) - just sold my RC8.2. Is the MBX6R EU a good all-round buggy, that I can run in various conditions with a basic set-up? I don't race that much or seriously - I just want something neutral and solid, mostly for fun running on tracks with other like-minded types(competitive, just not organized...) and the occasional race..
What parts are good to have on hand?
Also, do I have to worry about the header fitting, as I've sometimes read about in connection with Mugens? Thanks..
Hi All!
I just purchased a used MBX6R. Once I get the car, my plan is to tear it down, and re-build it so I can learn the ins and outs of how the car goes together.
My question is for you seasoned 6R racers... is there anything I should do differently than the instructions state; any setup tips or advice I should follow when re-building the car?
Thanks in advance for any advice!
Rob
Rob
Anyone in need of one of the compact bend 41029 Novarossi headers for an MBX? I sold my MBX6R and I have one that I'll let go for really cheap if anyone wants it...+++SOLD to BLKNOTCH Thanks Man!+++ I can't believe that they are $40+ on a-main!
PM Sent, I'll take it
I have a whole ton of engines and pipes - I really don't want to have to buy new headers.
I assume I already need to buy a bunch of new clutch-bells.. All mine are 16T and 17T..
At the moment the supposed buyer for my RC8.2 has disappeared, so maybe I won't be joining the Mugen club just yet anyway..
Also - what are the exact differences (and advantages or disadvantages) of the EU version of the MBX6R? I'm operating on the assumption that the MBX6R EU is what I want.
Will most big bore springs fit? And what sway bars are best for an all-around type of set-up? Thanks..
WOW !!!! i buy it on 27 i think
I have a Mspec. I am unable to remove the screws holding the servo saver, both top and bottom even with good force. Are the thread locked from factory? Don't think as per manual. I already stripped one screw on the top.
