Mugen MBX6
I run only run Hitec. I run 7955's and 7954's on lipo direct. I've had all of them fail. I set all my end points well short of full throw and still had them fail......8lbs buggy traveling 35+ miles an hour puts a lot of strain on them. it happens. Good thing about Hitec is their warranty best in the bizz if you ask me. I do agree running strait lipo is hard on servos HV or not you are running a componet at is max.
How long did you use them before they failed? I ran my Hitec 7954SH for a year in my elektro mbx6 and it's still in great shape imo. No play or weird noises.
I use a 6v/5amp protek regulator (for some reason the link says product not found)? I hope they keep making it, its super small and I've used the same one the past year and half in my buggies.
http://www.amainhobbies.com/product_...ducts_id/13509
and this is the reciever battery
http://www.amainhobbies.com/product_...-Balancer-Plug
bearing question?
Hey guys, what's a good set of replacement bearings? The stock bearings are great, but they don't quite freespin. Im looking for an upgrade. Maybe the advantage ceramics? Or should i just clean and relube the stockers with oil intsead of grease?
Oh, and Chad, You the man!
AVID BEARINGS, you can't beat them $1 bearings. Clutch bell bearings last easily a gal, and wheel bearings can go longer.
or TKO bearings are priced cheap as well.
avid. 'nuff said.
I'm an avid user too. They are very good imo. I bought other brand bearings too in the LHS for my other cars, but they are all crap. The only good bearing I have used to far are Mugen, Xray and Avid bearings. I hear good things about TKO too, but never tried them. Avids are too good to make me change
i use these, worked great for me: http://www.4chobbysupply.com/servlet...Bearing/Detail
http://racemugen.com/catalog/product...roducts_id=209
If your going to be around this weekend I would like to stop by racemugen.com and pick up some things.
Thanks again, Mike
Chad, the link will not work for me and I did a search on A-mains site and could not find it. Do you happen to have a part # that I could possibly search for, or can you suggest another product? I take it by your post that you would recommend using a regulator. I will run the lipo you posted with a Specktrum SR3100 pro receiver, a high voltage Hitec 7940 throttle/brake servo and a Hitec 7955 (which I am told will operate using a lipo) steering servo. Or should I just run a standard 6V flat pack? Thanks for all of your help.
Thanks again, Mike
Thanks again, Mike
