Like Tree396Likes
Tekno MT410
Old 06-21-2017 | 03:25 PM
  #841
0verkill's Avatar
Check out the new stuff from M2C Racing.
M2C Racing Front Upper Support Block m2c760 TEKNO MT40 FRONT UPPER SHOCK TOWER BRACE
M2C Racing Rear Upper Support Block m2c 6761 TEKNO M40 REAR SHOCK TOWER SUPPORT BRACE
vettehigh likes this.
0verkill is offline
Old 06-21-2017 | 04:42 PM
  #842
vettehigh's Avatar
Thumbs up
Now that is major overkill..., parts look damn good, but I'm done adding to my MT410 and I think you would never need to use these in the first place unless I'm missing something
vettehigh is offline
Old 06-21-2017 | 06:23 PM
  #843
chainsaw10's Avatar
I'm not sure I understand what these are for, or why someone would want these? I think I'm missing something. Is anyone breaking or bending shock towers? These won't make body mounts or posts any stronger?
chainsaw10 is offline
Old 06-21-2017 | 07:17 PM
  #844
0verkill's Avatar
0verkill is offline
Old 06-21-2017 | 08:46 PM
  #845
chainsaw10's Avatar
Ahh..now that I see them installed I see that they extend far and support the plastic body mount post holders. Yeah they'll work. ....but not as good as my body mount setup.
Thanks for pics Overkill
Old 06-22-2017 | 07:22 AM
  #846
vettehigh's Avatar
Thumbs up
Show a pic once you have it all together...thanks
Old 06-22-2017 | 08:43 AM
  #847
0verkill's Avatar
Not my pictures, but I'm sure you'll see some more soon.
0verkill is offline
Old 06-22-2017 | 07:25 PM
  #848
vettehigh's Avatar
Questions?? HW EZRUN MAX 8 COMBO PROGRAM CARD
I looked at the HW program card and noticed there are 11 settings (5 basic and 6 advanced). The only setting I have set is the forward/brake/reverse for my MT410. I'm only using 4S. Should I change anything on the program card?
I have this combo below:
https://www.hobbywingdirect.com/coll...ant=6409672516
Old 06-22-2017 | 09:09 PM
  #849
EbbTide's Avatar
I would just double check that the LVC is set for 4s instead of using the auto calc setting. Otherwise you should be fine without changing anything else
EbbTide is offline
Old 06-23-2017 | 04:41 AM
  #850
vettehigh's Avatar
Questions??
So change ITEM 2 to VALUE 4 correct? Thanks
Also, where can I order the 3-wire male/male plug for hooking the programmer to the ESC?
Old 06-23-2017 | 06:12 AM
  #851
EbbTide's Avatar
That would be correct
And I think this is the type of cable you need?
https://www.amainhobbies.com/protek-...k-5313/p186194
EbbTide is offline
Old 06-23-2017 | 02:39 PM
  #852
vettehigh's Avatar
Questions?? BEC Voltage for servo
Think I should change ITEM 7 to VALUE 2 (BEC Voltage)?
My servo is the Hitec HSB-9380TH Brushless Digital Ultra Torque w/PAD
TowerHobbies.com | Hitec HSB-9380TH Brushless Digital Ultra Torque w/PAD
Old 06-23-2017 | 02:43 PM
  #853
EbbTide's Avatar
That would be okay to do with that servo. It'll give you better efficiency and torque/speed
EbbTide is offline
Old 06-26-2017 | 01:20 PM
  #854
vettehigh's Avatar
Questions?? Final program values
Still wondering if I have ITEM #3 correct?
*Ended up with these values*
1) 2
2) 4
3) 3 (?)
4) 1
5) 1
6) 1
7) 2
8) 3
9) 1
10) 3
11) 1
Old 06-27-2017 | 05:14 PM
  #855
EbbTide's Avatar
1) 2
2) 4
3) 3 (?)
4) 1
5) 1
6) 1
7) 2
8) 3
9) 1
10) 3
11) 1
Everything looks good to me you can mess around with the punch settings if you feel it's too quick or too slow off the line
EbbTide is offline
