Tekno MT410
#856
Outerwears Company, Inc is sending me a prototype that is being built for no charge and I will in return give them feedback on final fitment, performance, and overall rating of the product
Product is chassis protector/cover with velcro closure (shroud - i.e. Dusty Motors)
#857
I need a few of the 4mm bullet plugs that are on the end of the motor wires (Hobbywing EZRun Max8 Waterproof Brushless ESC/Motor Combo 2200kV). I want to make my motor wires shorter and I do not want to reuse the existing ones.
My ESC/Motor combo below:
https://www.amainhobbies.com/hobbywi...010401/p520594
I was thinking these?
https://www.amainhobbies.com/protek-...k-5035/p177896
#858
#859
#860
#861
Where will I find 6.3mm connectors??
#862
https://www.amainhobbies.com/castle-...0009-00/p34184
#863
That makes more sense. In that case, these castle connectors are gonna work out for you. It's basically exactly what HW uses from the looks of it.
#864
Of definitely, there are big holes on top of each bullet for 10ga wire. Those little holes on the side I believe are for the solder iron tip so it doesn't get in the way of the wire when pushing it in from the top.
#865
I have the Hobbywing EZRun Max8 Waterproof Brushless ESC/Motor Combo (2200kV) and I would like to know if I could solder the motor wires directly to the Max8 ESC and bypass the bullet connectors?
#866
I wouldn't try it personally. You'd need a ton of solder to fill that thing. The bullets would be ideal.
#868
#869
#870
396Likes
