Offical ARRMA KRATON MT thread
#916
I run single 4s packs and dual 3s packs, I have installed a losi strap from my xxl2e to go lengthwise in addition to the two supplied straps. It works well, having the third strap is a big improvement. My problem with your batteries is not that you have 2 of them, it's the C rating, 35. That is not enough, I run 50c packs and they get hot. I recently bought a 75c pack from rcjuice and it is awesome, and runs cooler, its still warm when I take it out after a run. But not hot like my 50c packs. I can't imagine how 35c packs could hold up to the amp draw. My opinion. But I am planning on upgrading my battery packs to all 75c packs after I saw what the difference was. 50c minimum.
Are you dual hard case Lipo ? dual 5000 ?
#917
Yes I have dual hard case Lectron pro 5200mah 50c 2s and 3s sets. And 5200mah 50c 4s single packs. All fit fine, but I do run a third strap lengthwise, as otherwise the batteries come out of the truck. But with the losi strap installed, I've not had any issues. I can post pictures if you need.
#918
and YES post pictures please !
I am thinking I can wrap or glue the 2 hard cases together into a single rigid brick..... I can also make a better strap ..I even own a small injection molding machine so I could possibly make something suitable...obviously until its here I have no idea, so its purely spitballing right now !
#919
I'd be curious about the strap you're referring to, Trout. When searching I see several different losi straps. Thanks Sir.
#920
Okay ...awesome to hear that !!
Trout
#921
Parts
My Kraton should be in first of the week. Like a dummy I didn't check with the LHS's to see if they carry parts for it. So I'm trying to put together a list of the more common parts that break so I can order them so I won't be down a long time. Any help is greatly appreciated. I feel like an 8 year old waiting for Christmas. Lol.
#922
A better servo, inner and outer wheel bearings, truggy wheels and tires if you desire.
Nothing really breaks. The updated wing mount is proving to be very strong (as is the RPM mount) I finally cracked a rear LCA after 18 months of abuse, split along the inner hinge pin.
#923
@ Trout : Do you happen to know how long that strap is?
I could use that on my Muggy and Ten-T!
#925
#926
I'm partial to savox servos, 25 spline matches the stock arm as well. Anything 300in/oz ish, as fast as possible. I have the 1256tg in my kraton, works great.
I honestly wouldn't worry about spare arms, swap out all 8 wheel bearings and beat on it. Servo will be needed in a short amount of time.
#927
I've been beating the hell out of mine for the month I've had it. Front pillow ball teens to pull out from the upper a arm, stripping it in the process, so having a spare of those may be good. Broke the rear chassis brace last week, waiting for replacement now. Shock retainers tend to pop out, 3x so far, so I now have backups. Bent the bolt connecting the front shocks to the shock tower. That's my breaks thus far... but no complaints, because I'm pretty rough on it. Good luck!
Parts #s:
Upper a arm: AR330218
Shock tower bolt: AR330218
Chassis brace: AR320196
Shock retainers: AR330203
Maybe some of these are flukes.. Maybe I'm more abusive than I should be. Totally agree on the servo issues... Overall it seems fairly good compared to other RTR servos I've seen, just no long term dependability. Now have a hitec 7955. Tbone bumpers (front and rear) I'm convinced have saved me from more issues. Castle creations blower fan for motor, $10... but it's hot and humid in central Iowa so maybe I need it more than some others. Have noticed on the 3 Kratons I've seen, coming out of the box the motor wires leave some metal exposed so look out for that.
Parts #s:
#928
Parts #s:
Parts #s:
#929
Kratenwould be the best buy
