Offical ARRMA KRATON MT thread
#196
#197
What piniones is everyone using? Anybody using a pinion other than the ones specifically for the Kraton? I put my 20T on from my eMaxx and it doesn't look like it meshes very we'll. looks like the pitch of the teeth are different. So if anyone knows any other brand pinions that will work let me know. Or if arrma has pinions other than the 12 &14T
#198
Don't own a Kraton but most 1/8 stuff run MOD 1 pinions so the E-Maxx pinions which are 32 P will not mesh.
Tekno(my preference), Novak, RRP, just to name a few all make MOD 1 pinions for 5mm shaft.
Whatever you buy make sure it's a "hardened" pinion as well and you should be good to go.
20T is a big jump up over stock, you may run out of room with motor mount and stock spur gear and watch your motor, esc, and batt. temps gearing that high and keeping stock tires.
#199
#200
It depends what surface your running on. Truggy track tires get terrible traction in the grass and loose dirt. I put a set of them on my MT4 and was highly disappointed. They grip the pavement well which is like most off road tracks these days that have the dirt packed down so tight it's like concrete. If your looking for an awesome truggy bashing tire check out the Proline Badlands 3.8. They are what I run on my RC8t for bashing.
#201
#202
Truggy "bashing" tires is hard IMO, at least for me, since I run a lot on concrete. Badlands are great, but I wouldn't run them on concrete too much. It's ruin them fast..
Which is why I like MT4 G3 stock tires best. Good enough off-road, but hold up on pavement. Kind of a big for a truggy, but I guess you can always just regear it.. I have balded out truggy tires on my MT4 G3 right now, which if fine for pavement, but offroad they suck... Hard to find the right mix..
#203
Can't really say. I believe 14T is stock on the Kraton? I'd get a 15T & 16T and a $20 hardware store temp gun and start gearing up and monitoring temps of your electronics. Ambient temp is going factor in as well, so what works in the winter may run too hot in the summer and what works in New York may not work in Arizona. Hope that helps.
#204
I myself prefer 5S. More air control than 4 and feels more lively, but not quite as fast as 6. I prefer it for all around driving.
#205
I was kind of thinking the same thing... In addition to this Kraton build I am working on I also have an FLM emaxx with 1/8 diff conversion and I was always a little nervous to run 6S, and 4S was getting a little bland. Maybe I will have to grab a couple 3S batteries to go with my 2S's and run 5S in both trucks. Thanks.
#207
#208
manual only states 4-6 cell lipo @ 3.2v per cell
Either that or
turn it off and have No Cut Off with 12v minimum
Best to just do first run with a lipo cell alarm meter on it set for 5 cell and see if
esc cuts out when the voltage is hit
Either that or
#209
That would be stupid if it detects 4 and 6 cell but not 5 cell. I think the manual is probably saying "4 TO 6 cell" Not 4 OR 6 cell. But yea I would use the LVD alarm to be sure. Glad I am running mamba 2 in mine. when you hook up a lipo in the castle system it beeps the number of cells it detects. I always run with a LVD anyways just to be on safe side. But only because I didn't have the castle link previously to go into the esc an bump up the cut off. I always stop running at 3.4-3.5 volts/cell. Not 3.2 like mamba 2 is programmed to. I was told a long time ago by the guy that does the SPC batteries that anything below 3.5 is causing some kind of damage to the battery. Its probably not a big deal but I just do 3.5 to be safe.
