T/E Maxx Thread >
T/E Maxx Thread
T/E Maxx Thread
Old 06-29-2002 | 12:54 AM
  #181
New Jack's Avatar
Talking Re: is it worth upgradin chassis?
Originally posted by Anthrocide
is it worth upgrading my stock chassis to a dynamite chassis. i could get it for cheap. waht other upgrades can i do to help my car out. so far skidplates, lower chassis braces, rpm arms, new springs, aluminum bulkheads front only, mip cvds all around, dynamite pipe, titanium turnbuckles, what else should i upgrade?
Anthrocide: It sounds like you've done quite a bit of upgrading already!!! I would probably recommend: Pro-Line Suspension kit, Traxxas Forward only conversion #4994X, Dynamite Alum. steering bellcranks DYN7608B (blue), Steel or Titanium screws, better shocks unless you have the Big Bores, High TQ/Speed steering servo, other than that it sounds like you have it pretty much covered!!! As for the chassis I don't see anything wrong with the stock one unless you run a .21 engine!!!!
New Jack is offline
Old 06-29-2002 | 04:42 AM
  #182
coastaltony's Avatar
Anthro
Sounds like you got it going on!
Are you racing on-road, or off-road?
I can help for on-road
coastaltony is offline
Old 06-29-2002 | 04:50 AM
  #183
Anyone
Help, I need some aluminum bumpers for
this monster. The stock bumpers
s*&k, Trinity blue bumpers don't cut
it, I need some
orange ,
orred aluminum
bumpers for this beast.
Every time I look at it, it says "help
me"
Old 06-29-2002 | 11:27 AM
  #184
New Jack's Avatar
Thumbs up
CoastalTony: You're right that thing does look Sweet, I haven't found any orange or red bumpers of any kind or any material from plastic to titanium, mostly either silver/chrome or blue!!!! I will definately be on the look out & let you know if I find anything!!!!
Anthrocide: One more thing I forgot to mention, that is if you race off-road anyways pick up a good set of Rubber Sealed Bearings (they are about the best you can get for offroad, no gritty feeling from dirt getting into them!!!), you can get a good set from www.teambluestar.com , but I would mention to you to try & win them off of ebay, much cheaper that way!!!!!
New Jack is offline
Old 06-29-2002 | 07:49 PM
  #185
Default Coastaltony!!!!!!
this is my onroad t-maxx. i have the rad rc 3 speed in it right and runninng 1/8 scale tires. what tips could you give me? i have sway bars, the bell cranks you mentions but no upgraded shock plan on getting some soon, and a high torque steering servo.
Anthrocide is offline
Old 06-29-2002 | 10:26 PM
  #186
Anthro
Read back into the thread
The Pro-Line suspension kit, tires,
and good shocks are the key.
I have a spare set of AE blue shocks
if you want them.
I also have a set of pre-mounted
slicks for sale:
Old 07-02-2002 | 10:15 AM
  #187
LouisB's Avatar
I'm getting the traxxas forward only shaft but what improvements do you notice? I'm going to race it (as soon as I upgrade my engine) so will the forward only conversion make my lap times go down.
At this moment my LHS is fitting a hotbodies .18 into my T (crank cutting, flywheel etc) I chose the .18 because it's half way between a .15 and a .21 and doesn't require a conversion or different chassis, anyone else tried the HB .18?
I will be racing on grass (short) with very few jumps but plenty of corners, what should I change about my setup, ride height, oil .....
thanx
LouisB is offline
Old 07-02-2002 | 10:33 AM
  #188
New Jack's Avatar
Thumbs up
LouisB:it will be plent of extra punch as all the centrifical force will be going forward only at all times, not to mention the extra weight you will lose when pulling out all those uneeded gears from the tranny!!!! You should use some heavy weight shock oil, not too heavy if you have jumps though other wise you will be bouncin' like Tigger !!! Get some better shocks as well if you can afford it!!!! Also a Pro-Line suspension kit a MUST HAVE!!!!!!!!!
New Jack is offline
Old 07-02-2002 | 10:46 AM
  #189
LouisB's Avatar
Thanks,
I've just spent loads on spares, engine, fuel etc etc etc and don't have much left at present. I have put metal shock caps on and have big bore shocks from my now retired electric rustler. I have some 70wt oil from tc racing and it shold be OK, there's usually only 1 jump (small) and a rumble strip. I have trinity stiff springs.
Do you think that the stock shafts would survive the power of a .18 and te Maxx Performance kit? or should I use CVDs
LouisB is offline
Old 07-02-2002 | 10:59 AM
  #190
New Jack's Avatar
Thumbs up
LouisB: The Big Bores should be just fine with the Pro-Line suspension kit!!!! As for the CVD's I recommend but you might be able to get my with stock for now, check out Dynamite they have set of cheaper CVD's than MIP, that should be just as good also they have CVD's for the Driveshafts for the same price $37.99 versus $55.00 from MIP, just go to www.horizonhobby.com & for name brand put in Dynamite then Nitro truck & car & search through there, it's in there some where!!!!!!
New Jack is offline
Old 07-02-2002 | 12:05 PM
  #191
LouisB's Avatar
I'll go for low ground clearence to stop rollovers on the high grip grass tracks because the stocktires really dig in, do you think that proline road tires would work on grass to give more predictable handling?
There's a good UK (where I live) company that sells T-Maxx hop ups and they have drive shafts for £25, that's $39 (without the expensive shipping)
They are universals, not cvds but look pretty strong.
Check them out at www.cmldistribution.co.uk/fast_trax.htm
LouisB is offline
Old 07-02-2002 | 04:21 PM
  #192
New Jack's Avatar
Thumbs up
LouisB: The Pro-line suspension kit will most definately give you low ground clearance with better handling, it makes your truck an inch to an inch & a half wider for better handling, not to mention it also comes with Lunsford Titanium tie rods!!!! As for the Pro-line road rages they should work if it is a high bite track!!!!!
New Jack is offline
Old 07-03-2002 | 02:13 PM
  #193
LouisB's Avatar
New Jack: would the dynamite driveshafts work with the Pro-line kit, i thought that the shafts had to be a different length and only MIP made the right ones?
What type of rechargable receiver pack should I get, 3x2 or 5 in a row and which company makes the best ones?
I'll tell you how my Maxx goes once I've got it back and broken in the engine
LouisB is offline
Old 07-03-2002 | 04:03 PM
  #194
Louis8
Stock shafts work fine. I still have
them on mine. Look back at this thread
Old 07-04-2002 | 01:14 PM
  #195
New Jack's Avatar
Thumbs up
LouisB: As far as the technical On-road T-Maxx, I would say Coastal Tony is your Advice man, I have mine set up for off-road racing!!!! I'm not sure but Sway bars me even work Also I'm not sure about the Dynamite driveshafts, I'm glad you asked!! I will contact them & find out!!!!!
New Jack is offline
