June Stock Results
Class- Stock
Date-6/27/2021 Location- Elkton MD Race Time-230.26 Fastest Lap-2.88 Chassis-PNR 2.5, EVO board Body- GL R8 with lexan roof (less than 26g!) Wheelbase-98mm Tires- MZW39-40 front (23.1mm, 2 very small grooves), Marka V1R5 rears Motor- kyosho speed 4100kv BL Batteries- Orion 900HV Front Springs- PN Green (PN v4 front end) T-Plate- wolfram CF #5 Motor Mount- MZW309 Dampener MZW310 Dampener Fluid 15k atomic Gearing- stock 9/44 Notes: I won’t bother with the grooves in the future. MZW39-40 tires need a few runs to scrub in and wear slower than The 30’s. They also seem to need a few laps to build heat/traction. Next month I will start with a fresh set on 19mm rims with little to no truing. the vid isn’t my fastest run, - I think it was a second and some change slower. https://cimg2.ibsrv.net/gimg/www.rct...191ab8ef09.png |
June box stock
Class-box Stock
Date-6/30/2021 Location- Elkton MD Race Time-259.30 Fastest Lap-3.16 Chassis-MR-03 Body- AMG gt3 Wheelbase-98mm Tires- MZW39-40 front (22.7mm), Marka V1R5 rears (taken from stock car) Motor- box stock Batteries- Orion 900HV Front Springs- kyosho Green T-Plate- wolfram CF #3 Motor Mount- MM Dampener Box stock Dampener 10k grease Gearing- 7t Notes: If I wasn’t such a noob this car could have delivered me times in the 240’s, but I spent almost all my time trying to beat Lou in stock haha. I spent at least an hour per day (track time) driving this track with my stock car. Switching back to box stock was a tough transition, and I spent a fair bit of time swearing at myself as I plugged the car nearly into the walls… M96 world challenge is a sick addiction… https://cimg8.ibsrv.net/gimg/www.rct...ed368e2ce1.png |
Class- Box Stock
Date- June 20, 2021 Location- Madison, WI Race Time- 313.98 Fastest Lap- 3.65s Chassis- Kyosho MR-03 Body- McLaren 12C GT3 Wheelbase- 98mm Tires- Marka v12r25, Marka v01r05 Motor- White endbell MZ9P Batteries- 800mah Nimah Front Springs- Red T-Plate- Carbon Stiff Motor Mount- MM2 Gearing- 7t w/stock diff Notes-I would have posted this sooner but was hoping to get a better run in. I did actually beat this one with a 310s and 3.2 fast lap run but didn't save the screenshot unfortunately. Had to repair the transmitter so glad I was able to compete at all. The spring on the wheel broke so I had to pull it all apart and fix that. The tension is a little weak now and not sure I like it, may put a stronger spring in. Car was driving really well after an afternoon of tuning. New tires, springs and T-plate have it driving on rails. If I can do my part this car can do some fast laps. Cannot believe I've gotten an unofficial 3.2s fast lap. https://cimg2.ibsrv.net/gimg/www.rct...f3a333181.jpeg https://cimg4.ibsrv.net/gimg/www.rct...eff782235a.jpg |
Jun-2021 Box Stock
Class- Box Stock
Date- 10-Jun-2021 Location- Redondo Beach, CA USA Race Time- 255.783 Fastest Lap- 3.186 Chassis- Kyosho MR03 RWD Body- Audi R8 LMS Wheelbase- 98mm Tires- (F) Kyosho 30 Deg Slick, (R) Marka V1 10 Deg Slick Motor- Kyosho Stock Batteries- PN 750 mah Front Springs- PN Red T-Plate- PN Carbon 3 Motor Mount- Stock MM Dampener (If applicable)- Stock Dampener Fluid (If applicable)- N/A Gearing- 7T/Stock Diff Notes- No setup changes from last month. Was able to spend more time driving the car. Overall, car is balanced and easy to drive. https://cimg5.ibsrv.net/gimg/www.rct...89a96e6aa7.jpg |
Jun-2021 Porsche Cup
Class- Porsche Cup
Date- 24-Jun-2021 Location- Redondo Beach, CA USA Race Time- 243.999 Fastest Lap- 3.009 Chassis- Kyosho MR03 RWD Body- Kyosho Porsche GT1 Wheelbase- 90 mm Tires- (F) Kyosho 30 Deg Slick, (R) Marka V1 10 Deg Slick Motor- PN 3500 kv Batteries- PN 750 mah Front Springs- PN V3 AA Arm Green T-Plate- PN G10 5 Motor Mount- PN reconfigurable mount set to 90mm RM Dampener (If applicable)- PN dsd Dampener Fluid (If applicable)- N/A Gearing- 11T/Kyosho ball diff Notes- First entry on this chassis. Very surprised with the performance. May put in the PN 90mm MM motor mount and use as a stock class car. https://cimg1.ibsrv.net/gimg/www.rct...1edf1e9d6e.jpg |
Jun-2021 Stock
Class- Stock
Date- 24-Jun-2021 Location- Redondo Beach, CA USA Race Time- 234.699 Fastest Lap- 2.951 Chassis- PN 2.5W Body- Kyosho Audi R8 LMS Wheelbase- 98mm Tires- (F) Kyosho 30 Deg Slick, (R) PN KS Super Soft Radial Motor- PN 3500 kv Batteries- PN 750mah Front Springs- PN v4 AA blue T-Plate- PN G10 3 Motor Mount- PN v5 LCG Dampener (If applicable)- PN dsd (green/green) Dampener Fluid (If applicable)- N/A Gearing- PN 64P LSD 53/10 Notes- https://cimg5.ibsrv.net/gimg/www.rct...6f42b8a99e.jpg |
June Box Stock
Class-Box Stock
Date-6/19/21 Location-Winston-Salem, NC Race Time-255.469 Fastest Lap-3.178 Chassis-MR-03 ASF Body-McLaren F1 LM Wheelbase-98mm Tires-K30LH fronts, Marka V1R10 rears Motor-Stock Batteries-TRP 747s Front Springs-Kyosho Orange T-Plate-Kyosho Carbon Med Motor Mount-Stock MM Dampener (If applicable)-None Dampener Fluid (If applicable)-K 15k grease on top shock Gearing-Stock Gear Diff/7T pinion Notes-No changes this month, car transitions quickly and is easy to drive. Not much time to run this month, but beat my May time by almost 5 seconds. https://cimg5.ibsrv.net/gimg/www.rct...1014bf7868.png https://cimg2.ibsrv.net/gimg/www.rct...57f69d435.jpeg |
June Stock
Class-Stock GT 70T
Date-6/10/2021 Location-Winston-Salem, NC Race Time-244.165 Fastest Lap-2.936 Chassis-MR-03 ASF Body-Ferrari F-430 GT Wheelbase-94mm Tires-K30 radial fronts, Marka V1R10 rears Motor-PN 70T Batteries-R1 990 Front Springs-PN Purple T-Plate-PN CF #4 Motor Mount-PN 94-98mm v2 Dampener (If applicable)-PN DDS Dampener Fluid (If applicable)-None Gearing-PN 64p 9/54 Ball diff Notes-Changed back to 10t pinion and beat my best May time by only 2/10 of a second. Just didn't have much time this month to try to get under 4 minutes. https://cimg3.ibsrv.net/gimg/www.rct...f4ad31f13e.png https://cimg7.ibsrv.net/gimg/www.rct...79efb33f0.jpeg |
June 2021 Results
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hello All, We only had 4 racers this month, but some close racing, so I hope participation will pick up soon. Box Stock 1st - Traveler - 255.5/3.18s 2nd - LuckyLou - 255.8/3.19s 3rd - ChemNut - 259.3/3.16s 4th - TomtheGeek - 314.0/3.65s Porsche Cup 1st - LuckyLou - 244.0/3.01s Stock Class 1st - ChemNut - 230.3/2.88s 2nd - LuckyLou - 237.7/2.95s 3rd - Traveler - 244.2/2.94s Pro Stock Class Open AWD Class Some really close racing in Box Stock class, with 1st and 2nd separated by only 3/10 of a second and 3rd only 3.5 seconds back, and an upset in Stock with the new kid on the block ChemNut leapfrogging LuckyLou and Travel to take first, while ChemNut and LuckyLou were both running sub 4 min times. FTM goes to ChemNut and his Stock car with a smoking 2.88 fast lap. Please check my tabulations and let me know if I made any mistakes. Drive fast! Cheers, Traveler2 |
July 2021 Layout
We are going with the original Mini-96 Plan A layout running clockwise for July. Drive fast!
https://cimg1.ibsrv.net/gimg/www.rct...33dbdde57.jpeg |
Hi Traveler2,
I got my track setup and my old trackmate system going, but I'm trying to figure out what class I qualify for. It's been close to a decade since I ran the car :) I think it's either stock or pro stock? Also, I was trying to figure out what times to shoot for, but it's pretty hard to find the last time this layout was run, any thoughts on a good starting point? I backordered a red audi mr03 for box stock class, hopefully it won't be an age until I get it. Also, anyone aware of bluetooth (added BT serial module to trackmate timer) capable android lap timing apps? I don't want to have to pull out the laptop for practice laps :) Thanks!
https://cimg6.ibsrv.net/gimg/www.rct...324643f1ce.jpg https://cimg8.ibsrv.net/gimg/www.rct...5ee53ca343.jpg |
Class- Box Stock
Date- July 30, 2021 Location- Madison, WI Race Time- 383.54 Fastest Lap- 4.66s Chassis- Kyosho MR-03 Body- McLaren 12C GT3 Wheelbase- 98mm Tires- Marka v5r20, Marka v01r05 Motor- White endbell MZ9P Batteries- 800mah Nimah Front Springs- Red T-Plate- Carbon Stiff Motor Mount- MM2 Gearing- 7t w/stock diff Notes- Went to v5r20 in the front for more grip since half the course is hairpins. I'm at like 80% dual rate and have more than enough steering now. It's sort of surprising how much tuning the car needs between track layouts but it can make a huge difference. Car was very jumpy at the end of the run harder to keep it from traction rolling. https://cimg6.ibsrv.net/gimg/www.rct...c758b7f78.jpeg https://cimg5.ibsrv.net/gimg/www.rct...30245b2db0.jpg |
Originally Posted by cdog4w
(Post 15803978)
Pulled the motor, it's an AWD XSpeed V [part # MDW023]. Can't find the turn count anywhere. I'm guessing it throws me into pro-stock unless I change the motor.
(Post 15803984)
Pulled the motor, it's an AWD XSpeed V [part # [color=black]MDW023]. Can't find the turn count anywhere. I'm guessing it throws me into pro-stock unless I change the motor.
The X-Speed is a 50T motor and would put you in Pro-Stock, as you suspected. Switching to the stock white end bell motor will make you legal for Stock. Those tires look like Kyosho treaded tires. Look on the outside sidewalk to confirm it says Kyosho, and the inside sidewall for the shore embossed there. They are probably 20 or 30 deg. Some people can be competitive with the AWD, but I never could be. Glad you ordered a RWD. Will be interesting to compare the two platforms. If you are on FB, some of the guys have posted some early times. I hope to get some laps in this weekend. |
| All times are GMT -7. It is currently 04:31 PM. |
