Mini-96 World Challenge >
Like Tree3035Likes
Old 05-04-2021 | 08:47 PM
  #1201
Originally Posted by chemnut220
At the time I wanted a 5xxx kv motor as I was building this car for larger tracks. They were all sold out - but are in stock now. I don’t mind the 7000 kv motor as I can just turn the rate back on the Tx. I also have a 3200 kv in an AMZ that I will play with this month.
I went ahead and back ordered a ready set. Who knows when it will get here but I would like to play with 2wd. While I have finally gotten my Atomics set up nicely, I’m not a fan of a lot of the design decisions that went into these things. They come across as cheap and lazy... so for RWD I will just wait for Kyosho to come back in stock...
can I put the module in the ready set and use my TX for box stock (NB4) or do I have to use the stock TX?
You can't use the Noble on the RTR. Your options are the stock TX (kt531) or the Kt432.
Lucky Lou is offline
Old 05-06-2021 | 08:21 PM
  #1202
I am still running the April layout with my Box Stock... I will be excited when I can get 1 lap at the average time of some of you.
chjosi is offline
Old 05-07-2021 | 11:49 AM
  #1203
lol I unbackordered the rtr and have an evo on the way. Should be good for stock when my white body gets here.
chemnut220 is offline
Old 05-07-2021 | 11:52 AM
  #1204
I definitely understand that feeling. Some days I can only get in 20 minutes of track time and others I manage over an hour. It feels like every day the movements become more automatic and I am able to get better times with less intense focus.
but yeah some of these averages being put up are really impressive. I know I have my work cut out for me haha.
Old 05-08-2021 | 12:59 PM
  #1205
Default April Results
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hello All,
Only had 6 drivers last month, but because they took the time to post results I decided to compile them. Hope participation will pick up soon.
Box Stock
4th-MileHighRC- 339.6s/3.79s
3rd-TomtheGeek- 326.0s/3.76s
2nd-FastJew- 300.0s/3.67s
1st-Traveler- 276.7s/3.43s
Porsche Cup
2nd-MilehighRC- 335.9s/3.96s
1st-Traveler- 281.2s/3.49s
Stock Class
3rd-MilehighRC- 320.2s/3.76s
2nd-Medo998- 266.1s/3.29s
1st-Traveler2- 259.0s/3.23s
Pro Stock Class
1st-Traveler- 258.7s/3.28s
Open AWD Class
1st-Chemnut220- 341.2s/4.08s
FTM goes to Traveler and his Stock car with a 3.23 fast lap.
Cheers,
Traveler2
chjosi, tomthegeek and MileHighRC like this.
Traveler2 is offline
Old 05-17-2021 | 08:34 AM
  #1206
Anyone have initial times on the May layout?
I am averaging 4.2s with only one lap under 4s, with a Stock class setup.
chjosi is offline
Old 05-17-2021 | 08:53 AM
  #1207
I took my “stock class” car and slapped a wide lexan body bumper on it to protect the front end. I did this because the post office may have lost the body I ordered and I just wanted to run some laps. After a ton of runs I managed a 283.28/3.43 run. It won’t count for stock class until I can (hopefully) reproduce it when my McLauren body finally arrives (if it does at all...). I will attempt to 3D print an R8 shell with ABS if I don’t get the body by this weekend. It will be ugly I’m sure....
for open AWD - I’ve logged a 275.34/3.30 with the BZ3. I put a 3500 kv motor in it (replacing the 7000) and it runs a lot cooler and I get 3 runs per pack instead of 2...
If others wish to post their times, I will leave that to them but I know on FB, some have reported times from the 260’s to the low 300’s.
what setup are you running for the stock car?
Old 05-17-2021 | 03:01 PM
  #1208
MileHighRC's Avatar
Do we have an official layout for May? Anyone heard from Jim, hope he is well.
ae4ever likes this.
MileHighRC is offline
Old 05-17-2021 | 04:28 PM
  #1209
The official layout went out in the Facebook page - but not here.
MileHighRC likes this.
Old 05-18-2021 | 04:44 PM
  #1210
Yes. Jim is ok and hope he’ll be back soon. He asked me to fill in for him and I’ve asked LuckLou to back me up. Thanks ChemNut for posting the layout here for those not on FB.
Old 05-25-2021 | 12:47 AM
  #1211
Default May 2021 Box Stock
Class- Box Stock
Date- 31-May-2021
Location- Redondo Beach, CA USA
Race Time- 268.061
Fastest Lap- 3.267
Chassis- Kyosho MR03 RWD
Body- Audi R8 LMS
Wheelbase- 98mm
Tires- (F) Kyosho 30 Deg Slick, (R) Marka V1 10 Deg Slick
Motor- Kyosho Stock
Batteries- PN 750 mah
Front Springs- PN Red
T-Plate- PN Carbon 3
Motor Mount- Stock MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- N/A
Gearing- 7T/Stock Diff
Notes- Car drives well. Did not spend enough time this month. Setup will be a good baseline for June.
Old 05-25-2021 | 12:48 AM
  #1212
Default May 2021 Stock
Class- Stock
Date- 31-May-2021
Race Time- 242.209
Fastest Lap- 3.153
Chassis- PN 2.5W
Body- Kyosho Audi R8 LMS
Wheelbase- 98mm
Tires- (F) Kyosho 30 Deg Slick, (R) PN KS Super Soft Radial
Motor- PN 3500 kv
Batteries- PN 750mah
Front Springs- PN v4 AA blue
T-Plate- PN G10 3
Motor Mount- PN v5 LCG
Dampener (If applicable)- PN dsd (green/green)
Gearing- PN 64P LSD 53/10
Notes-
Initial run was 4 min 31 sec - PN AA v3 green front springs, PN G10 5 T-plate
1st setup change from PN 64P 53/14 to 53/10 - 4 min 23 sec
2nd setup change to current less PN v4 AA front suspension - 4 min 11 sec
3rd setup change to current - 4 min 6 sec
4th setup change - changed body from Kyosho Mclaren 12c to Kyosho Audi R8 LMS
Car was happy at 3.1xx/lap. Had several bad laps on submitted run. Could have been sub 4 min.
Old 05-25-2021 | 12:49 AM
  #1213
Default May 2021 Porsche Cup
Class- Porsche Cup
Date- 28-May-2021
Race Time- 255.438
Fastest Lap- 3.169
Chassis- Kyosho MR03 EVO
Body- Porsche 911 GT3 RS
Wheelbase- 90mm
Tires- (F) Kyosho 30 Deg LH slick, (R) Marka V1 10 Deg slick
Motor- PN 3500 kv
Batteries- Kyosho SpeedHouse 800 mah
Front Springs- PN purple
T-Plate- PN G10 5
Motor Mount- PN reconfigurable carbon
Notes- Changed from Nexx RM to PN configurable carbon motor mount
On this layout, there were days that I felt like this would be my submission for the stock class.
Car can be driven harder.
Old 05-30-2021 | 03:57 AM
  #1214
Default May Box Stock
Class-Box Stock
Date-5/24/21
Location-Winston-Salem, NC
Race Time-260.297
Fastest Lap-3.157
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Tires-K30LH fronts, Marka V1R10 rears
Motor-Stock
Batteries-TRP 747s
Front Springs-Kyosho Orange
T-Plate-Kyosho Carbon Med
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-No changes this month, car transitions quickly and is easy to drive.
Lucky Lou likes this.
Old 05-30-2021 | 03:58 AM
  #1215
Default May Porsche Cup Class
Class-Porsche Cup Class
Date-5/30/21
Race Time-265.546
Fastest Lap-3.153
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-K30Flat fronts, Marka 10 rears
Motor-ATM 3500
Batteries-Kyosho SpeedHouse 800s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6S
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-1300 Silicone Oil
Gearing-PN 64p 13/53 Ball diff
Notes-No changes from last month. Only a couple of runs on 5/30. Challenging but fun to drive.
