Mini-96 World Challenge >
Like Tree3035Likes
Old 11-19-2019 | 05:17 AM
  #451
LJH
Originally Posted by elk
I'm waiting for my Mini 96 to arrive and have cleaned out a portion of the basement to run in. Is it advisable to run plastic sheeting under the track or simply set down onto the bare floor?
If you are setting up on a poured concrete floor I do not think it would be a bad thing to have a vapor barrier between the track and the floor. Even something like a thin plastic drop cloth just so the moisture can't transfer from the cement to the track.
I did not get to set up my tack this past weekend but hoping to do so this weekend.
Cheers,
Jim
LJH is offline
Old 11-19-2019 | 05:30 PM
  #452
Scionara05's Avatar
Class-awd
Date-11,19,19
Location-basement track
Race Time-5:16.74 (316.74)
Fastest Lap-3.80
Chassis-gla
Body-marka lexan
Wheelbase-98
Tires-10 radial slicks rear 20 fronts
Motor-gl 3500kv
Batteries-nanotek 300
Front Springs-gl green
rear springs-gl red
Gearing-Stock spur, 16t pinion
Notes-nothing crazy just running with the timer on and pulled a rabbit out the hat
Scionara05 is offline
Old 11-20-2019 | 08:57 AM
  #453
Scionara05's Avatar
Class-stock
Date-11,19,19
Location-basment
Race Time-5:18.63
Fastest Lap-3.96
Chassis-pn2.5w
Body-12c gt3 mclaren
Wheelbase-98
Tires-pn ss rear kyo 30 low height
Motor-pn 70t
Batteries-pn750
Front Springs-pn orange
T-Plate-pn fiberglass #4
Motor Mount-pn 93-102
Dampener (If applicable)-pn double spring also has pn side shocks with pn center shock springs in purple on it Dampener Fluid (If applicable)-dry
Gearing-52x10
Notes-aw grease in side dampness with purple springs
Old 11-22-2019 | 11:23 AM
  #454
ewashburnaf's Avatar
Ordered a Mini96 track today... can't wait to join in on the fun here. Also have two kids that will join me and hopefully put up some times.
ewashburnaf is offline
Old 11-25-2019 | 04:19 AM
  #455
Same for me! - I started clearing out my basement so I can set up the track (still waiting for it). I grabbed a car for my son last week and looking to grab another for my daughter.
I am looking forward to it, next thing i need to sort out is lap timing software.
thisjoeg is offline
Old 11-25-2019 | 04:24 AM
  #456
Billy Kelly's Avatar
There a free LapTracker app for iPhone that a lot use.
thisjoeg likes this.
Billy Kelly is offline
Old 11-25-2019 | 05:17 AM
  #457
LJH
Nice to see some new faces and see some old peeps turning some laps.
I have to apologize for not being a good supporter this month. I am flat out at work and the weekends have been full of all sorts of things. December is going to be hard as well because the Christmas Tree goes in living room where I set up my track. With that said once the holidays are behind us I will get plenty of time running laps.
Keep at it boys and drive fast.
Cheers,
Jim
LJH is offline
Old 11-25-2019 | 06:06 AM
  #458
Thanks very much, I will give it a shot!
thisjoeg is offline
Old 11-26-2019 | 04:05 PM
  #459
Sweet. Where in NC are you?
Traveler2 is offline
Old 11-27-2019 | 12:53 PM
  #460
I am in the Goldsboro area. Mostly racing at RC Hobby Nook in Smithfield
Old 11-29-2019 | 04:23 AM
  #461
Default Introduction and a question
Hi all,
I’ve been reading this thread from the beginning for a few days now since Jim told me on another forum. I’m half way, so not quite caught up with everything recent yet. I’m 47, live in St. Louis, MO and don’t have much experience with RC. I’ve been racing full scale cars in endurance and sprint races for a few years. I also got an XRay T4 to compete in 1/10 scale VTA class (indoor carpet).
I have a question from the past: Do you guys lift at all in Box stock on the first layout you ran here (plan A)? I have a few hundred laps on the Mini-96 now and it’s beyond me how you get under 6 sec/lap, let alone low 5s. I just installed a Kyosho 30 front slick and 20 rear radial and that helped, but I’m still around 6.5 without bumping into anything and for a couple of laps I didn’t lift at all. I’ve observed that hitting the apexes is more important than not lifting, but a full second or more is a lot of time.
So, can someone offer some advice? Is it batteries, springs, the line, lack of practice? How do you guys get that fast? Did you all start at 6-7 sec or am I doing something completely wrong? Also, on the 98mm bodies and since I presume we are all using the stick transmitter because I can’t seem to find a way to bind it to the EX-6R, what is your dual rate setting for steering? All the way up or fairly close to it?
Thanks for any advice and apologies for the long post.
CyberGeorge is offline
Old 11-29-2019 | 05:50 AM
  #462
Hi George
I don't run the world challenge but I think I can answer some of your question.
With box stock I don't think you need to use brake funtion. Much like a lot of faster drivers on black carpet, they only lift and let the drag brake do the job. The tire set up you used is a good starting point, but have you changed your spring or T plates? Personally I find the stock black spring and plastic t plates gives you a lot of push. Also what's the body you are running? Different bodies will make your car handles differently. 98mm is fine for the track though, I don't find the wheel base to be a problem on my EVA tracks.
Also, would you mind uploding a picture of your stock radio and car to the thread? Based on your description, you may try to bind your ex6r to a incompetable car. I don't recall Kyosho still produce ASF car readyset after 2013.
zxcvb1t is offline
Old 11-29-2019 | 07:17 AM
  #463
LJH
Box stock is tough as any mistake is magnified because of the lack of power. Having done a bunch of full scale amateur car racing in my younger years you need to consider a box stock car very much a momentum car.
I find the PN KS tires to be faster than the Kyosho’s by a significant margin, on my box stock car I am running soft rears and firm fronts currently. Finding the correct tire combination is literally 85-90% of your set up.
as mentioned the box stock cars are pretty down on power so you need to do everything possible to extract all the BHP available. Break in the motor, keep the motor clean and use the Bachman brush lube, it works and lastly when you go for a fast stint charge your batteries at a bit higher rate to get some heat in them and lower the internal resistance, it makes a difference.
As far as driving goes, try to link turns together as much as possible, use as little steering as possible...every time you use steering you are slowing the car down. I have found that taking tighter lines refuses the distance travelled and saves significant time. I never use brakes and please experiment with how fast you can enter a turn using later and later “braking” points. Basically all the rules that apply to full scale hot lapping apply to these cars.
Lastly....practice, practice, practice. I would not worry to much about chassis set up yet, when you can do 75 laps and only have 2-3 errors then you can start worrying about fine tuning the balance of the car. While it can be frustrating at times having fast laps to chase will give you something to work towards and make you a better driver and And chassis engineer.
One thing I do recommend is spending some time on the front suspension and making sure everything moves very smoothly, this is hugely important in my eye. I am also a fan of doing inverted king pins. Some say it increases the unsprung weight of the front end but to me is just helps make a smooth front end.
great to have you on board.
Cheers,
Jim
LJH is offline
Old 11-29-2019 | 09:02 AM
  #464
NutDriver's Avatar
Default PN tires
Jim,
I saw your post about the PN tires. I went on the Kenon site and was flabbergasted by all of the choices. A friend told me +2 fronts and +3 rears for my MR03 98mm car, but I'm still perplexed by which tires. He said super soft rears and soft fronts, but only found threaded rears. Can someone provide part numbers for the preferred tires?
Scott
NutDriver is offline
Old 11-29-2019 | 12:33 PM
  #465
LJH
Originally Posted by NutDriver
Jim,
Scott
I personally do not think a Box Stock car needs super softs in the rear and I would also run a firmer tire in the front.
I would go with the KS2024 in the rear and either the KS1038 or KS1042 in the front. I am running the McLaren F1 LM body which is 0/0 offsets on a wide chassis and was traction rolling with mediums fronts so I went to firms which helped a lot. If you just want to try one sets I would lean towards the mediums first.
On the wheels, what body are you running? Depending on the body it may be beneficial to run a 1mm narrower wheel in the front so they do catch on the rails.
Cheers,
Jim
LJH is offline
