Mini-96 World Challenge >
Like Tree3035Likes
Old 11-29-2019 | 01:24 PM
  #466
Billy Kelly's Avatar
Originally Posted by CyberGeorge
Hi all,
I’ve been reading this thread from the beginning for a few days now since Jim told me on another forum. I’m half way, so not quite caught up with everything recent yet. I’m 47, live in St. Louis, MO and don’t have much experience with RC. I’ve been racing full scale cars in endurance and sprint races for a few years. I also got an XRay T4 to compete in 1/10 scale VTA class (indoor carpet).
I have a question from the past: Do you guys lift at all in Box stock on the first layout you ran here (plan A)? I have a few hundred laps on the Mini-96 now and it’s beyond me how you get under 6 sec/lap, let alone low 5s. I just installed a Kyosho 30 front slick and 20 rear radial and that helped, but I’m still around 6.5 without bumping into anything and for a couple of laps I didn’t lift at all. I’ve observed that hitting the apexes is more important than not lifting, but a full second or more is a lot of time.
So, can someone offer some advice? Is it batteries, springs, the line, lack of practice? How do you guys get that fast? Did you all start at 6-7 sec or am I doing something completely wrong? Also, on the 98mm bodies and since I presume we are all using the stick transmitter because I can’t seem to find a way to bind it to the EX-6R, what is your dual rate setting for steering? All the way up or fairly close to it?
Thanks for any advice and apologies for the long post.
It also depends on which side of the track is being used. When I ran the rough side, mid to low 5s were normal. Once switched to the smooth side. Same cars were in mid to low 6s. With an occasional sub 6 lap. Some cars dropped into the 7s.
Billy Kelly is offline
Old 11-29-2019 | 01:38 PM
  #467
NutDriver's Avatar
Default Tire question - Part 2
Jim,
On the 98mm car, I'm running a Mosler. I also have a 94mm car with a Lexus.
Scott
NutDriver is offline
Old 11-29-2019 | 01:40 PM
  #468
LJH
Bllly,
We are now running on the smooth side and regularly getting into the 4.7s range for average laps with fast laps in the 4.3’s with Box Stock cars.
Cheers,
Jim
LJH is offline
Old 11-29-2019 | 01:42 PM
  #469
LJH
Originally Posted by NutDriver
Jim,
Scott
I run a Mosler on my GLR, it is a pretty heavy body for a box stock car but I does play super nice with the rails.
2* fronts and 3* tears work great on that body.
Cheers,
Jim
NutDriver likes this.
LJH is offline
Old 11-29-2019 | 01:45 PM
  #470
Originally Posted by LJH
Bllly,
Cheers,
Jim
i know you have been on smooth side for awhile. I was referring to what most consider the standard mini96 layout.
Old 11-29-2019 | 05:44 PM
  #471
LJH
Billy,
Yes, the last two circuits have been a couple tiles short of the full 96 but they Still have the same length main straight and the same number of turns. I would be willing to put money on the fact the next time we run the “standard” Mini96 circuit that a box stock car will have an average lap time of under 5s and a fast lap time of under 4.5s. We have some seriously fast guys running and that helps make us all progress and get faster. I know I am a heck of a lot faster now then I was in my early days because there are Fast Mini-Z veterans running and if you want to be competitive you have to play with set up and practice.
I know you are running your big track but maybe you should change it up every now and then and run the M96WC, it may be beneficial and steepen your learning curve.
Cheers,
Jim
LJH is offline
Old 11-30-2019 | 01:03 AM
  #472
Originally Posted by zxcvb1t
Hi George
I don't run the world challenge but I think I can answer some of your question.
With box stock I don't think you need to use brake funtion. Much like a lot of faster drivers on black carpet, they only lift and let the drag brake do the job. The tire set up you used is a good starting point, but have you changed your spring or T plates? Personally I find the stock black spring and plastic t plates gives you a lot of push. Also what's the body you are running? Different bodies will make your car handles differently. 98mm is fine for the track though, I don't find the wheel base to be a problem on my EVA tracks.
Also, would you mind uploding a picture of your stock radio and car to the thread? Based on your description, you may try to bind your ex6r to a incompetable car. I don't recall Kyosho still produce ASF car readyset after 2013.
I have not yet messed with plates or springs. I ordered some and we shall see. They can’t make up for 1.5 sec though. These guys are doing 5s and I’m at 6.5 at best. My line is not perfect and I guess it matters because the motor does not have the torque to regain speed.
I run a MR03N 90mm Porsche GT3 and a MR03W 98mm McLaren. Bottle latest ones from Kyosho.
Yes, I don’t think the EX-6R is compatible with these cars. They are the latest, but I think the EX-6R is only compatible with the VE Pro and EVO.
I’ll post some pictures, yes.
CyberGeorge is offline
Old 11-30-2019 | 01:14 AM
  #473
Box stock is tough as any mistake is magnified because of the lack of power. Having done a bunch of full scale amateur car racing in my younger years you need to consider a box stock car very much a momentum car.
I find the PN KS tires to be faster than the Kyosho’s by a significant margin, on my box stock car I am running soft rears and firm fronts currently. Finding the correct tire combination is literally 85-90% of your set up.
as mentioned the box stock cars are pretty down on power so you need to do everything possible to extract all the BHP available. Break in the motor, keep the motor clean and use the Bachman brush lube, it works and lastly when you go for a fast stint charge your batteries at a bit higher rate to get some heat in them and lower the internal resistance, it makes a difference.
As far as driving goes, try to link turns together as much as possible, use as little steering as possible...every time you use steering you are slowing the car down. I have found that taking tighter lines refuses the distance travelled and saves significant time. I never use brakes and please experiment with how fast you can enter a turn using later and later “braking” points. Basically all the rules that apply to full scale hot lapping apply to these cars.
Lastly....practice, practice, practice. I would not worry to much about chassis set up yet, when you can do 75 laps and only have 2-3 errors then you can start worrying about fine tuning the balance of the car. While it can be frustrating at times having fast laps to chase will give you something to work towards and make you a better driver and And chassis engineer.
One thing I do recommend is spending some time on the front suspension and making sure everything moves very smoothly, this is hugely important in my eye. I am also a fan of doing inverted king pins. Some say it increases the unsprung weight of the front end but to me is just helps make a smooth front end.
great to have you on board.
Cheers,
Jim
Thank you, Jim. That all makes sense. I’ll treat the box stock as the Miata we use in endurance races and not the Porsche GT4 I have for sprints I think I’m figuring that out.
I’m not so sure how to break in or lube the motor but I’ll read up on that. I’m sure there’s a ton of info out there. May already be too late for that though
I’ll try the PN tires. I had gotten some of these at some point but I used them on the other cars. Some guy from DC who had a lot of Mini-Z YouTube videos had recommended them I think.
And yes, my front suspension is not smooth. I’ll have to break everything down and start sanding every part I guess. I can’t figure out exactly where it’s binding but it is. One of my other cars had issues like that as well, even though it was more expensive. I sort of fixed that one with some PN parts and polishing, but I still don’t get a very smooth feeling.
The times you guys do are crazy fast. Hats off.
LJH likes this.
Old 11-30-2019 | 01:22 AM
  #474
Rough (high friction). I haven’t even thought of attempting the smooth one. I have quite a bit of practice to do on the rough still...
Old 11-30-2019 | 05:00 AM
  #475
LJH
Actually, I would switch to the smooth side ASAP. No need to get the car sorted on the rough side and then have to start all over setting the car up for the smooth side.
I actually found the smooth side offered more traction than the rough side. I had my cars fairly well sorted for the rough side and when we went to the smooth side it was traction roll city for me.
Cheers,
Jim
LJH is offline
Old 11-30-2019 | 06:41 AM
  #476
Cheers,
Jim
Interesting. That’s not how it’s supposed to be. I haven’t quite caught up with the entire thread yet; still on page 17. You guys are running on smooth now and you are never going back to rough?
Old 11-30-2019 | 10:06 AM
  #477
Can't believe I missed all these recent posts. For some reason I wasn't getting email notifications like I normally do. I'm really excited to see some new guys planning to join in the Mini-96 challenge and hope we have better participation going forward.
November was a busy travel month for me workwise, so I haven't been able to get many runs in and doubt I can improve on my times today, which is the deadline for posting results. If I have any faster runs than those I already posted, I will upload them today, but look forward to having more time in the next few months to get more practice in on those layouts and some faster times.
Traveler2 is offline
Old 12-01-2019 | 11:01 AM
  #478
LJH
Hello All,
I will publish results tomorrow but wanted to let you know that we will be running the same circuit in December as November but running Counter Clockwise.
Cheers,
Jim
Traveler2 likes this.
LJH is offline
Old 12-01-2019 | 01:51 PM
  #479
Originally Posted by ewashburnaf
I am in the Goldsboro area. Mostly racing at RC Hobby Nook in Smithfield
I’ve been there a few times. This is Marwan. Have we met?
Old 12-01-2019 | 03:19 PM
  #480
ewashburnaf's Avatar
I started going three weeks ago... Been there every Saturday since. Also, Sensational RC Tracks in Fayetteville is running on Fridays now. They're on Facebook too. I don't think we've seen each other yet... Hope to see you at the track someday soon.
ewashburnaf is offline
