Mini-96 World Challenge
#616
I cant wait to get a sensored motor so I can turn the turbo on for the straight at full throttle input. Right now my car has no timing in it and it feels so dead. I guess I'm just getting use to the glr with the faster speed that I'm trying to get it to mimic it. Especially with max gearing I can put on the car at 14x51
#617
#618
are u running a brushless board if u are i would look at the rocket motors. They are built copays of the pn v2 motor and cost 15 bucks. Just try and find a local seller in the states. And not anybody who drop ships it and says there in the states I got burned like that on ebay
#619
ExcelRC.com !!! They carry the motor and a tone of MINI-Z parts!
#620
#621
This is the pn car both the gl cars are all stock. No hop ups on it that's why I havent posted them
#622
there basic cars only one that has had a major over haul is the pn chassis car because of all the work done on it. That's the 1 thing I always forget to do when posting.
#624
Class: Pro Stock
Date: 18. january 2020
Race Time: 08: 12.621s
Fastest Lap: 05.073s
Chassis: PN2.5W
Body: Audi R8 LMS
Wheelbase: 98mm
Tires: Marka
Motor: PN 5600kv
Batteries: R1 Wurks 990mAh
Front Springs: Green
T-Plate: PN #5 Carbon
Motor Mount: PN MM
Dampener (If applicable): PN DPS
Dampener Fluid (If applicable): Dry
Gearing: 53/9T 64-pitch
Notes: My Stock car was not working correct. Used my ProStock that has been sitting for 2 years... God I'm rusty.... Can't remember what tires I have.
Chassis: PN2.5W
Body: Audi R8 LMS
Wheelbase: 98mm
Tires: Marka
Motor: PN 5600kv
Motor Mount: PN MM
#625
Glad you finally got everything you need to join us together and look forward to you getting your cars sorted and and putting up some real times.
I'm really enjoying the Mini-Z resurgence...
#626
I had some time last night, so I swapped the ATM 5500kv motor out of my PN2.5W/VE Pro car and replaced it with a Rocket 3500kv. The car is much easier to drive on the Mini-96 now. I had to make several ICS adjustments to the board, but it still rolls way too much off throttle. After a couple of runs, I'm down to a 5:11.881, still 13 seconds slower than my PN 70T car. This 3500kv motor doesn't have the acceleration or drag brake that my PN 70T car has, so I don't think I'll be any faster with it, but the biggest pinion I had was a 12t, so I was running 53/12 gearing. I prefer the feel of the brushed motors, but I just don't have much time with the brushless ones yet.
#627
Cheers,
Jim
#628
#629
me personally I run as lil drag brake as possible on by glr I have ot on setting 2 my gla has none and my home built evo has setting 2 on I would have to see how much that is. I rather use the tires to slow down and scrub speed in the corner or trail brake into the corner
#630
That's the other thing I'm not used to. These brushless motors seem to have very weak braking. I prefer brushed at the moment, and will likely stick with those for the M96WC, but will keep messing with the brushless to see how close I can get to the brushed times, and to see if I can get used to them. I remember EMU and others saying it took a while to adjust to brushless, and that switching back and forth between the two was not easy...
Esc100%-radio60%
3035Likes
