Mini-96 World Challenge
#1366
February 22' Stock
Class- Stock 3500
Date- 28 February Location- NH, USA
Race Time- 378.701s
Fastest Lap- 4.500s
Chassis- PN 2.5W
Body- Jomurema Wheelbase- 98mm
Tires- Kyosho 10 Rear Radial, kyosho front radial 20 Motor- Excel 3500kv
Batteries- Orion900hv
Front Springs- Nexx white (Nexx V-line front)
T-Plate- Nexx #4
Motor Mount- Nexx 98-102mm set at 98mm
Dampener (If applicable)- Nexx Disc damper top disk only and Nexx rear shock (yellow)
Dampener Fluid (If applicable)- N/A
Gearing- 9/53
Notes- didn't have much time this month, got some tuning and a couple runs in on the last day. Overall I think this is my best time to date. Still trying to figure out where to get quicker laps.
My goal next month is to run closer to a 5min total race time.
Class- Stock 3500
Race Time- 378.701s
Fastest Lap- 4.500s
Chassis- PN 2.5W
T-Plate- Nexx #4
Gearing- 9/53
#1367
Class- 2wd Open
Date-2/27/2022
Location-Kenosha, WI
Race Time-295
Fastest Lap-3.62
Chassis- GLR-GT, Reflex 505 Brass chassis
Body-GL Ferrari 488 GT3
Wheelbase-98mm
Tires- PN KS-M Medium, Marka V1R05 rears
Motor- GL 3500vk
Batteries- Fantom 360mah lipo
Gearing- 64p 10/53 Ball diff
Date-2/27/2022
Race Time-295
Fastest Lap-3.62
Wheelbase-98mm
Motor- GL 3500vk
#1368
Class-Box Stock
Date-2/27/22
Location- Kenosha, WI
Race Time-308.6
Fastest Lap-3.71
Chassis-MR-03 LM
Body- Sauber Mercedes
Wheelbase-102mm
Tires- PN Racing KS-M Medium fronts, PN Racing KS-M soft rears
Motor-Stock
Batteries- PN 750
Front Springs- Stock
T-Plate-Kyosho Carbon Med
Motor Mount-Stock MM
Dampener (If applicable)-None
Date-2/27/22
Race Time-308.6
Fastest Lap-3.71
Chassis-MR-03 LM
Wheelbase-102mm
Motor-Stock
Batteries- PN 750
#1371
2wd open
Date-2/28/22
Location- California
Race Time-397.70
Fastest Lap-4.267
Chassis-GLR
Body- Mazda 787B
Wheelbase-98mm
Tires- Unknown
Motor-3500KV
Batteries- 2S lipo
Need to put in some practice and hopefully post some better times next month.
Date-2/28/22
Race Time-397.70
Fastest Lap-4.267
Chassis-GLR
Body- Mazda 787B
Wheelbase-98mm
Tires- Unknown
Motor-3500KV
Batteries- 2S lipo
#1372
Class- Open 2wd
Date- 15FEB
Location- MD, USA
Race Time- 269.791s
Fastest Lap- 3.331s
Chassis- GLR- GT
Body- Jomurema with lexan roof
Wheelbase- 98mm
Tires- Marka v1 r5, Marka v6 r25
Motor- PN sensored 3500kv
Batteries- lipo, GL 360
Front Springs- reflex racing side damper springs. Silver
T-Plate- N/A
Motor Mount- GL
Dampener (If applicable)- Reflex
Dampener Fluid (If applicable)- 15-25k all around. Unfortunately I did not write it down and I added this back in November/December
Gearing- 14/53
Notes: I initially could not get the feel for this car because it seemed too unstable and aggressive compared to my stock PNR 2.5 chassis. I wrecked a whole lot and initially had to go to a loose ball diff to keep prevent oversteer despite having Marka 5's on the rear. I actually Ironed it all out in my transmitter settings. I am using -40% expo for steering and -50% for throttle. In addition I have my throttle rate set to 53% and the channel speed for throttle is set to a 0.2s buffer (if my finger could instantly apply full throttle, the transmitter would ramp it up over 0.2 seconds). This last bit helped eliminate oversteer and enabled me to return to using the PN gear diff without concern of oversteer.
Date- 15FEB
Location- MD, USA
Race Time- 269.791s
Fastest Lap- 3.331s
Chassis- GLR- GT
Wheelbase- 98mm
T-Plate- N/A
Motor Mount- GL
Gearing- 14/53
#1373
Class- Stock
Date- 15FEB
Location- MD, USA
Race Time- 277.303s
Fastest Lap- 3.415s
Chassis- PNR 2.5/ PN AA front
Wheelbase- 98mm
Tires- Marka v1 r10, PN Firm , cut/worn to 22.2mm
Motor- kyosho 4100 kv
Batteries- TRP747
Front Springs- green
T-Plate- Wolfram CF #5
Motor Mount- Stock
Dampener (If applicable)- kyosho CF
Dampener Fluid (If applicable)- silicone oil from 3 months ago. I do not recall what weight, probably 200-400
Gearing- 11/53 (PN Gear Diff)
I do not change much with my stock car because it is so stable and reliably good performing. I geared up in an attempt to get my total time under 270s but gave up after realizing that I would have to be machine-like in my consistency to accomplish this with my stock car. That or
hunt for more speed somewhere.
Date- 15FEB
Location- MD, USA
Race Time- 277.303s
Fastest Lap- 3.415s
Wheelbase- 98mm
Batteries- TRP747
Motor Mount- Stock
#1374
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
We had several new racers, with 9 total posting this month in 6 classes. There was some really close racing, with a difference between 1st and 2nd place in Stock and Open 2WD of only 0.1 seconds! Where are all the other guys that have a Mini-96 and are turning laps? You'll get faster if you start posting. I know I did! But if you are not convinced, check out the improvement between January and February for a couple of the new guys like TAMAK, PoorBoy and DoubleDarth.
Box Stock
1st - Traveler - 295.4/3.72s
2nd - TAMAK - 308.6/3.71s
3rd - Bmr4life - 394.9/4.52s
4th - PoorBoy - 398.1/4.67s
Porsche Cup
1st - Traveler - 318.7/4.00s
Stock Class
1st - Traveler - 277.2/3.45s
2nd - Chemnut220 - 277.3/3.42s
3rd - DoubleDarth - 315.6/3.84s
4th - MIchael - 378.7/4.50s
5th - PoorBoy - 401.2/4.73s
Pro Stock Class
1st - Traveler - 271.3/3.40s
Open 2WD
1st - Chemnut 220 - 269.8/3.33s
2nd - ChamDas 269.9/3.22
3rd - TAMAK - 295.0/3.62s
4th - TomtheGeek - 358.0/4.34s
5th - PoorBoy - 397.7/4.27s
Open 4WD
1st - DoubleDarth - 314.4/3.71s
2nd - PoorBoy - 396.9/4.40s
FTM goes to ChamDas in his Open 2wd car with a 3.22 fast lap.
Please check my tabulations and let me know if I made any mistakes or missed anyone.
New layout clockwise for March posted. Drive fast!
Cheers,
Traveler2
Box Stock
Porsche Cup
Stock Class
Pro Stock Class
Open 2WD
Open 4WD
Cheers,
Traveler2
#1377
I got the track out last night, but runs were not worth reporting :P Too long a break I guess. New layout looks fun!
Did I also see that there is going to be a dnano class? I'll have to setup laptrax or something else as the trackmate transponders are too big for dnano.
3035Likes
