Mini-96 World Challenge
#137
I will try this out. I lost my Robitronic LapTimer, but ordered a new one. So I hope I get that in a week or two.
Have to get my RCP track back from storage and dust it off.
My parts are in the country, but not at my house.
Ordered some more parts, since I think money can make me win....yeah right
What I will be trying out is the "new" Porsche 911 GT3 RS, 90mm wioth RM configuration.
Running with PN Double A-Arm if I can make it work and just a DPS.
I got Marka tires right now, used for another great big track. Not sure if those are the best for my old worn track.
#138
GLR
Class-Open 2WD
Date-6/14/19
Location-Rotonda
Race Time-405.3
Fastest Lap-4.20
Chassis-GLR
Body-Mini Z McLaren
Wheelbase-98mm
Tires-PN Radial rears. Slick fronts
Motor-GL 3500kv
Batteries-GL 330 mah
Front Springs-stock
T-Plate-
Motor Mount-stock
Dampener (If applicable)-stock
Dampener Fluid (If applicable)-Kyosho 30,000
Gearing-10 t
Notes- My fastest lap to date.
Class-Open 2WD
Date-6/14/19
Location-Rotonda
Race Time-405.3
Fastest Lap-4.20
Chassis-GLR
Body-Mini Z McLaren
Wheelbase-98mm
Motor-GL 3500kv
Front Springs-stock
T-Plate-
Motor Mount-stock
Gearing-10 t
#139
GLR
Class-Open 2WD
Date-6/14/19
Location-Rotonda
Race Time-405.3
Fastest Lap-4.20
Chassis-GLR
Body-Mini Z McLaren
Wheelbase-98mm
Motor-GL 3500kv
Front Springs-stock
T-Plate-
Motor Mount-stock
Gearing-10 t
Class-Open 2WD
Date-6/14/19
Location-Rotonda
Race Time-405.3
Fastest Lap-4.20
Chassis-GLR
Body-Mini Z McLaren
Wheelbase-98mm
Motor-GL 3500kv
Front Springs-stock
T-Plate-
Motor Mount-stock
Gearing-10 t
#140
Class-stock 70t
Date-6/14/2019
Location-south nj
Race Time-7:24.39
Fastest Lap-5.34 avg 5.94
Chassis-MR-03 kt531p
Body- Audi r8 lms
Wheelbase-98mm
Tires-pn slicks front, radials rear
Motor-pn 70t
Batteries-duracel rechargeable
Front Springs-PN orange
T-Plate-PN Carbon #4
Motor Mount-Stock mm
Dampener (If applicable)-disk
Dampener Fluid (If applicable)-5000k
Gearing-stock geardiff, 8t pinion
Notes- on 2.5 chassis with bearings on the 129$ budget car from kyosho.
Also went to the matching offset wheels and narrow front end. Felt slow but was faster by a lot.
(Same setup from yesterday just changed battery and went)
Date-6/14/2019
Location-south nj
Race Time-7:24.39
Body- Audi r8 lms
Wheelbase-98mm
Motor-pn 70t
#141
Class-stock 70t
Date-6/15/2019
Location-south nj
Race Time-7:09.40
Fastest Lap-5.23 avg 5.74
Body- Audi r8 lms
Wheelbase-98mm
Motor-pn 70t
Gearing-stock geardiff, 7t pinion
Also went to the matching offset wheels in rear and 2.5 front and narrow front end. This is the fastest I've put down so far. Muscle memory is starting to come into play now and I'm running with out thinking to much harder now
Date-6/15/2019
Location-south nj
Race Time-7:09.40
Body- Audi r8 lms
Wheelbase-98mm
Motor-pn 70t
#143
Still having a hard time linking laps together going CCW but showing improvement.....it is hugely frustrating none the less.
Here is my Box Stock time sheet. With the exception of using a motor that I had “broken in” and my normal tire set up the car is truly Box Stock and I have not touched a thing yet. It actually feels pretty good with the exception of a big hop I get coming off the long straight.
With some more practice I should be able to get a 5.6’ish average.
Cheers,
Jim
Class-Box Stock
Date-6/20/19
Location-Norwalk CT
Race Time- 417.2
Fastest Lap- 5.21s
Chassis-MR03 RWD
Body- McLaren F1GTR
Wheelbase- 98mm
Tires- PN KS Radial Rear Soft/ PN KS Slick Front Med.
Motor- OEM Silver Can
Batteries- Amazon Basics
Front Springs- Stock Black
T-Plate- Stock Plastic
Motor Mount- Stock Plastic
Dampener (If applicable)-N/A
Dampener Fluid (If applicable)- TA 30K
Gearing-7T Pinion
Notes-
#144
Class-70t
Date-6/16/19
Location-south nj
Race Time-7:10.95
Fastest Lap-5.16
Average lap- 5.77
Chassis-mro3 pn.2.5
Body-mass concept
Wheelbase-98mm
Tires-radial rears kyosho front
Motor-pn 70t
Batteries-duracel
Front Springs-pn soft blue
T-Plate-pn #4
Motor Mount-stock mm
Dampener Fluid (If applicable)-tamiya 450 oil
Gearing-7t
Notes-450 fluid on king pin narrow front end with 2.5 offset fronts.
Nsx body feel more consistent than the r8 body for the way I drive but the canards are unforgiving when the tap the walls.
Date-6/16/19
Location-south nj
Race Time-7:10.95
Fastest Lap-5.16
Average lap- 5.77
Chassis-mro3 pn.2.5
Body-mass concept
Wheelbase-98mm
Motor-pn 70t
Batteries-duracel
T-Plate-pn #4
Gearing-7t
#145
Cheers,
Jim
Cheers,
Jim
#146
Starting to feel better, I had a fairly decent run with the Box Stock car this evening doing a 426.2s and am starting to turn some quick laps with both my 90mm and LM cars both with Pro Stock motors in them currently. I changed out the very noisy spur/pinion on my 90mm car and the thing feels like a different animal, I kept the FDR very close to what I had before bit the car just feels so much faster......and it is a bucket load quieter. I also ran the GLA and was turning quite a few laps in the 4.8X range but then would just have a bad lap after bad lap.
With that said can I ask you guys just to edit your original time sheets for each class when you want to post new times as well as not adding a time sheet that shows a slower time than you have already posted. If we start to get more participants and everyone posts a new time sheet every time they run the bookkeeping at the end of the month will be a nightmare.
Thanks.
Cheers,
Jim
Thanks.
Cheers,
Jim
#148
Class-Super Stock
Date- 6/20/19
Location- Norwalk CT
Race Time- 403.4.0s
Fastest Lap- 4.83s
Chassis- MR03 RWD
Body- Mazda 787B
Wheelbase- 102mm
Tires- F-PN KS Med Slick, R-PN KS Type Soft Radial
Motor- Atomic 130 48T
Batteries- Orion 1100
Front Springs- PN Purple
T-Plate- Kyosho 6mm Carbon
Motor Mount- Atomic LM
Dampener (If applicable)- Atomic AR-250
Gearing-4.15:1
Notes-
#149
Class-Stock
Date- 6/20/19
Race Time- 410.6s
Fastest Lap- 5.00
Chassis- MR03 RWD
Body- Porsche GT1
Wheelbase- 90mm
Motor- PN70T
Front Springs- Kyosho purple with MZW-416 dampeners
T-Plate- 3Racing 5.5mm LM
Motor Mount- Atomic 86/90 Rear Mount
Dampener (If applicable)- MZW-216
Gearing-4.15:1
Notes-
#150
Hello All,
I will fill in all the pertinent info in the morning.
I am finally feeling more comfortable going CCW. I got home to an empty house this evening and got quite a few laps in. First up was my Stock car which is a rear mount 90mm chassis and currently running a GT1 body. The PN70 has new silver brushes which were broken in and I switched over to 64P gears......the car feels fast power wise. Handling wise it still feel a bit nervous but can put down some fast laps when I stay clean but it is not easy to do, I need to do some more work to get the car more consistent.
Second up was my Pro-Stock car which is in LM Spec running an Atomic 130 48t motor and the 787 body. I have been running the LM wheels and tires and I was struggling with lap times but the car was super constistant. I switched to 20mm wheels and my normals tire set up and the car came alive and was still super consistent. I still had a couple errors but still the car felt great.
Lastly I had a another go with my Box Stock car. I did not have any fully charged batteries so the car was a bit down on power but it felt great tonight. I still have done nothing with the exception of tires. I shaved another few seconds off my time. Considering the fact that I have doe zero to this car except for tire, the front suspension feels like it has rock for springs and the rear feels like a wet noodle the car feels awesome.
Tonight was was fun ripping some hot laps and feeling more comfortable.
Cheers.
Jim
Cheers.
Jim
3035Likes
LOL
