Mini-96 World Challenge
#166
#167
The first line of the race information has what class that race is for. I noticed that T2 started listing the class in the subject line and I started putting it in bold on the very first line of a post. This is still a work in progress so bear with us and if you have any ideas on how to make this cleaner please feel free to speak up.
Cheers,
Jim
#168
Open AWD
I finally got the GLA going alright. I have kind of a love hate relationship with this car, it can be VERY fast but it can also make you feel like you have never driven a car before. I think I have to rebuild the rear crown gear and pinion again as it can skip a tooth and the thing is VERY loud. With that said the car was pretty quick this evening and I pulled off a new track record for me of 3.61s.
Class- Open AWD
Date-6/25/19
Location-Norwalk CT
Race Time- 382.3
Fastest Lap- 4.62s
Chassis-GL GLA
Body- Audi R8LMS
Wheelbase- 98mm
Tires- PN KS Radial Rear Soft/ PN KS Slick Front Med.
Motor- GL 3500kv
Batteries- 300mah 2S
Front Springs- Stock
T-Plate-
Motor Mount-
Dampener (If applicable)-N/A
Dampener Fluid (If applicable)- TA 30K
Gearing-13T
Notes-
Class- Open AWD
Date-6/25/19
Location-Norwalk CT
Race Time- 382.3
Fastest Lap- 4.62s
Chassis-GL GLA
Body- Audi R8LMS
Wheelbase- 98mm
Motor- GL 3500kv
T-Plate-
Motor Mount-
Gearing-13T
Notes-
#169
What are you having a problem with?
Cheers,
Jim
Cheers,
Jim
To see what I can compare too. And how people have improved in one single class.
I get easily confused.... :-D
I do not have a suggestion on how to make it better or different yet, so no worries. I just was frustrated i thought I was looking at Stock, and I thought it was really fast, but then I found out it was SuperStock. hihi
#170
Oh don't get me wrong. I just try to figure out what Stock racers have gone from and too.
#171
Box Stock is of no interest to me.
Stock- Any 4AAA Nimh Chassis , OEM or 70T brushed motor or 3500kv Brushless motor, Autoscale/White body.
Pro Stock-Any 4AAA Chassis , 48/50T Brushed motor or 5500kv brushless motor, Autoscale/White body.
These are the ones I probably can do on a Mini-96. Leaning towards just Stock
#172
#173
4 full days left of the June Series so get your fast times in.
Cheers,
Jim
#175
Jim,
I'm getting ready to build a new car with an Evo board. If I use aftermarket screws on the chassis, were does that leave me for classes? Can I still run it in box stock if I meet the other requirements? Or would I be limited to the other classes? Not trying to start a controversy, just don't want to build it and then find out I can't run it in certain classes.
#176
Jim,
Cheers,
Jim
#177
Hope the July layout is on the smooth side!
#178
So tonight I decided to give the 911 GT1 another try with different front tires, otherwise the set up was the same as before, and on three consecutive runs, I improved my time each run. First run was on old K30 slicks, then on way old PN20 slicks and finally on brand new K30 low height slicks. Not sure if the tires contributed to the improvement each time, or if was was just getting better, but this will be it for Box Stock for June. I'll try to get some final runs in on other cars tomorrow!
Class-Box Stock
Date-6/29/2019
Location-Winston-Salem, NC
Race Time-6:30.725 (390.725)/6:25.937 (385.937)/6:22.723 (382.723)
Fastest Lap-4.786/4.803/4.669
Chassis-MR-03 ASF
Body-911 GT1
Wheelbase-90mm
Tires-See above for fronts, K20R rears
Motor-Stock
Batteries-TRP 747s
Front Springs-PN Blue Super Soft
T-Plate-PN Carbon #4
Motor Mount-Stock RM
Dampener (If applicable)-None
Notes- I'm running on smooth side, not rough so results are not comparable.
First run
Second run
Third run
Class-Box Stock
Date-6/29/2019
Chassis-MR-03 ASF
Body-911 GT1
Wheelbase-90mm
Motor-Stock
Batteries-TRP 747s
First run
Second run
Third run
#179
I feel that the low profile 30 slicks have more traction at similar diameter to the old 30 slick. I think the large heat cycle to cut down the old tires removes some traction, however over long stints, the old 30 seem to maintain traction without changing quite as much.
those PN20 still work? I remember the PN18 which was one of the best front tires to be on...
#180
3035Likes
