Mini-96 World Challenge >
Like Tree3036Likes
Old 06-12-2019 | 05:15 AM
  #121
Originally Posted by Billy Kelly
What did you hit to break that? Had to be something solid.
"Racing incident" LOL! But seriously, the plastic front clips do break pretty easily if you are running with other cars and are involved in a wreck. I have a bin full of broken ones...
Traveler2 is offline
Old 06-12-2019 | 05:21 AM
  #122
Billy Kelly's Avatar
9 months of racing. Haven’t broken one yet. Think I’ve seen one in super Stock class. Too many cartwheels off the track.
Billy Kelly is offline
Old 06-12-2019 | 05:25 AM
  #123
Originally Posted by LJH
T2,
The sporting nature of the Box Stock class is really to be able to pull the car out of the box, charge batteries, swap tires and run some hot laps. Having tires, springs, and T-bars open allow some tuning and helps a newbie learn how the chassis reacts to changes. The wing/body rule is to prevent a body being modified for an advantage i a, fine with not running a wing at all Lastly the 20mm wheels rule is just to keep life simple and not feel the need to buy more stuff. As for the front clip I do not think stock ones will be an issue on the M96 track. If we start allowing more and more aftermarket stuff we lose the nature of the Box Stock class.
Goot to have ave you on board.
Cheers,
Jim
Thanks for the welcome Jim! Right now I'm just getting used to running on the Mini-96. Quite different from the big track experience, but still fun!
I understand and appreciate your take on box stock, so my question is which of the classes would my 911 pictured above fit into? Stock? If so, I will edit the post to change the class.
I look forward to participating with the correct surface once the July layout is announced!
Old 06-12-2019 | 07:17 PM
  #124
Originally Posted by Mattdaddy1974
June Layout
Class-Box Stock
Date-6/9/19
Location-Rotonda
Race Time-449.1
Fastest Lap-
5.10
Chassis-MR03 Sport
Body-McLaren F1 GTR
Wheelbase-98mm
Tires-stock
Motor-stock
Batteries-Orion 900hv
Front Springs-stock
T-Plate-stock
Motor Mount-stock mm
Dampener (If applicable)-stock
Gearing-6t
Notes-Much more difficult for me vs CW
Update
Mattdaddy1974 is offline
Old 06-12-2019 | 07:18 PM
  #125
GLR
Class-Open 2WD
Date-6/13/19
Location-Rotonda
Race Time-408.1
Fastest Lap-4.54
Chassis-GLR
Body-Mini Z McLaren
Wheelbase-98mm
Tires-PN Radial rears. Slick fronts
Motor-GL 3500kv
Batteries-GL 330 mah
Front Springs-stock
T-Plate-
Motor Mount-stock
Dampener Fluid (If applicable)-Kyosho 30,000
Gearing-10 t
Notes-Starting to get use to going CCW.
Update
Old 06-12-2019 | 07:30 PM
  #126
EMU's Avatar
EMU
I would personally be open to permitting the carbon front body clip in all classes, as well as permitting reinforcement for the body. Many often double dip bodies if they run on larger tracks, and the stock front clips break if you look at them wrong. A carbon or alternative front clip is not a performance enhancing part, but increases the reliability of the car. Much in the same way as permitting the aluminum t-plate mount, it prevents wear and tear on the chassis when changing bodies and body clips. I usually use long machine screws with a nut on top to secure my body clips, which prevents it from stripping out the holes in the chassis, but also makes it difficult to swap stock body clips when needed.
as for wheels in the box stock class, these should be 20mm only, as it is within the spirit of the rules to stay with stock size wheels in that class. The stock class should permit 17 to 22mm wheel size of appropriate width for front or rear. Stock class has a more open upgrade option, but box stock is minimal in performance upgrades and really only permit reliability upgrades to keep cars on track.
Billy Kelly likes this.
EMU is offline
Old 06-13-2019 | 06:08 AM
  #127
LJH
T2.
I feel the same way EMU feels, the front clip is not really a performance enhancing part but rather a reliability enhancing item. Being a Newbie I was not aware that the front clip is a failure point....to be honest I am shocked I did not break one running hot laps in the kitchen as I had some seriously hard hits. I will make an amendment to the rules to allow aftermarket nose clip.
With that said your chassis looks like it is pretty darn close to Box Stock with the exception of the top shock which I believe is the Kyosho "oil" shock? Using that top shock puts you into the "Stock" class.
Cheers,
Jim
LJH is offline
Old 06-13-2019 | 06:50 AM
  #128
T2.
Cheers,
Jim
Thanks for adding aftermarket front clips. Think everyone will appreciate it once they break the stock plastic one!
Yes, that is an oil shock, so I will edit the post to change the class to "Stock". But since that car runs so well on my Mini-96, I'm going to switch it back to the stock top shock and see if its just as good, in which case it will become my "box stock" car for this series going forward...
Thanks again!
EMU likes this.
Old 06-13-2019 | 06:26 PM
  #129
Scionara05's Avatar
Class-stock 70t
Date-6/132019
Location-south nj
Race Time-7:45.02
Fastest Lap-5.41
Chassis-MR-03 kt531p
Body- McLaren f1 longtail
Wheelbase-98mm
Tires-pn slicks front, radials rear
Motor-pn 70t
Batteries-duracel rechargeable
Front Springs-PN orange
T-Plate-PN Carbon #4
Motor Mount-Stock mm
Dampener (If applicable)-disk
Dampener Fluid (If applicable)-5000k
Gearing-stock geardiff, 8t pinion
Notes- on 2.5 chassis with bearings on the 129$ budget car from kyosho.
Scionara05 is offline
Old 06-13-2019 | 07:44 PM
  #130
Where's all the times at? I can't be the only one to be running. I had a chance to run the GLR tonight and improved by a few seconds. I'm out of town next week so I'll be unable to run on the Mini96. I have to get my Super Stock MR03 fixed and on the track. I dropped it the other day and the MMII mount broke at the disc mount so I'll be ordering another.
Old 06-13-2019 | 07:58 PM
  #131
Scionara05's Avatar
Class-stock 70t
Date-6/132019
Location-south nj
Race Time-7:28.64
Fastest Lap-5.39
Body- Audi r8 lms
Wheelbase-98mm
Motor-pn 70t
Also went to the matching offset wheels and narrow front end. Felt slow but was faster by a lot.
Old 06-14-2019 | 02:12 PM
  #132
Default My Revised Box Stock 911 GT1
Class-Box Stock
Date-6/14/2019
Location-Winston-Salem, NC
Race Time-6:36.134 (396.134)
Fastest Lap-4.818
Chassis-MR-03 ASF
Body-911 GT1
Wheelbase-90mm
Tires-K40R fronts, K20R rears
Motor-Stock
Batteries-TRP 747s
Front Springs-PN Blue Super Soft
Motor Mount-Stock RM
Dampener (If applicable)-None
Notes- So I ditched the oil top shock and replaced it with stock shock. Also noticed I was running an 8t pinion, so switched to a 7t for "Box Stock", and the thing is faster than before. p.s. I'm running on smooth side, not rough so results are not comparable.
Old 06-14-2019 | 02:23 PM
  #133
Is there any "results" sites? Like who is #1 in each class?
So I could compare to those I should be comparing to when I get going?
NoBrainer is offline
Old 06-14-2019 | 02:28 PM
  #134
Class-Stock
Date- 4/22/19
Location- Norwalk CT
Race Time- 435.6 (7:15.6)
Fastest Lap- 5.25
Chassis- MR03 RWD
Body- 911 GT3 (991)
Wheelbase- 90MM
Tires- F-PN KS Med Slick, R-PN KS "F" Type Soft Radial
Motor- PN70T
Batteries- Amazon Basic 750mah AAA
Front Springs- PN Purple with Kyosho MZW-416 Inner tube front Dampeners
T-Plate- PN 4MM Carbon Long
Motor Mount- Atomic RM
Dampener (If applicable)- Kyosho MZW-216
Dampener Fluid (If applicable)- 20wt
Gearing-11T Pinion on OEM Gear Diff
Notes-
is this a wide or narrow front?
What offset are you using on your rims?
Old 06-14-2019 | 02:40 PM
  #135
Oh no! Not you! You are too fast for this group! LOL
