The Drift Thread
#1321
you don't. some people prefer the feel of a double over a single. personally I like a single because of the snap.
#1322
Does anybody do any drifting in the Chicago area??
#1323
i have been doing RCdrifting for over 5 years, and here is my newest body...
i am a session organizer in tampa florida and contribute heavily to:
groovydrift.com
sflrcdrift.com
rcdriftcentral.com
if you register to any, let them know silverhkswrx referred you!
this is my R32...
the chassis is a rayspeed converted mr4-tc see here:
i am very knowlagabe in the ways of drift, please let me know if my knowledge can assist you.
groovydrift.com
sflrcdrift.com
rcdriftcentral.com
this is my R32...
#1324
groovydrift.com
sflrcdrift.com
rcdriftcentral.com
this is my R32...
groovydrift.com
sflrcdrift.com
rcdriftcentral.com
this is my R32...
I jump on the r/c band wangon in Oct 08. I have a T/C and a HPI Sprint 2 Flux. Well both of my cars are FULLY UPGRADED. And I'm using the HPI to drift. Can you help??
#1325
greetings
Greetings:
Does anyone drift in the Houston area?? I'd love to come out and practice with you!
#1327
#1328
What are the set-ups that drifter use??
Brush/Brushless? brushless but no lower turn than 6T brushless it is too much power,(mainly used for the faster response and e-brake feature.
ESC? the esc that is made for the brushless motor
Ball/Gears Diff? this is HIGHLY debated. the most poupular options are:
ball up front, ball in the rear;
solid rear, ball front;
ball front, solid rear;
one way front, solid rear
one way front, ball rear.
front one ways are a love/hate type of thing. on a VERY tight course, they can be beneficial. but 98% you wont use it. primarily if there is ANY flaw in your suspension setup, the ball diff will magnify it.
i personally run a ball up front and solid rear with a center one way.
Springs? medium or soft wth soft oil (i run titanium medium yokomo springs, with 35wt oil.) this gives great traction on all surfaces when softer springs will grip too much on a perfectly smooth surface.
biggest mod that made the best benefit to me was the tires. even with friction dampers, stock springs the t-drifts had me sliding with more control.
#1330
i'd like to add "Spool front/rear and center one-way", thats the current setup of my moore speed ... it just handles better for me that way.
btw, we find Tamiya Drtiftech tires to be more cost effective and superior on our tracks and its conditions. the T-Drift has less traction on an indoor track we run on. T-Drifts are not solid tire so lifespan is shorter ... also its also more expensive here, about 300 more than the driftech. the license makes it more expensive but it sure looks pretty!
#1331
so many options that it all boils down to how you drive.
#1334
Hello guys. I need few basic tips about drifting at all.
I have HPI super RS4 electric with ESC Novak TC2 and trinity 13x3 motor.
I have several options for gear ratio, but mainly use 81 spur/27 pinion.
My questions are the following. Please give me advice, because I never tried drifting before. Tires will be customised, because I havent seen drift tires, with that size. (35x72mm)
1. I can choose from 280mm or 300mm wheelbase - which one is better for drifting?
2. Should I lock front/rear differentials?
3. Should I remove the front belt so it becomes only rear wheeldrive?
4. Should I watch for any center of weight - more heavier rear or front?
5. Will be very happy to receive any additional tips.
Thanks,
Stanislav
Thanks,
Stanislav
#1335
Thanks,
Stanislav
Thanks,
Stanislav
this is the one thing i have never tried. i woudl assume longer wheel bases give better sliding but shorter gives better control.
by lock i assume your kit comes with ball diffs. i prefer ball up front and solid(locked) rears.
big time no-no. you do it, you will have no control at all.
rear weigh allows the rear to stay planted and slide less. weight up front gives more nose dive and allows the rear to lift more causing more sliding.
on a course with alot of sharp turns, i put about 30 grams up front. on long courses i only use 10 up front.
brushless was the best mod any drifter can do...
